- 123
- 396 小时
- 2020-8-31
- 50
- 40737
- 124
- 123 点
- 123 ¥
- 2008-4-18
回复 5# ztd
我也很怀疑,输入如果是110U,尺寸有点不对吧,这颗电容和后面那颗WIMA比较差不多大小
谁翻译一下:The values of the resistors are: Rg: 22k, Rf: 22k, Ri: 680. The gain is 33. All resistors seem to be carbon film types. Tolerance is 5 %.
There is no way to identify R0 or the capacitor values. At least, we can determine the dimensions of the components. The Cs caps have a diameter of 15 mm, Ci of 5.4 mm, the dimensions of Cz are 2.6 mm x 7.5 mm. Judging by the color, they may have used a WIMA 100 nF polyester cap for Cz. 100 nF is the value specified in the LM3886 datasheet and the WIMA measures 2.5 mm x 7.2 mm, which fits very well. Maybe someone can identify the makes of the other caps according to their size (let me know if you do). The value of the Cs caps is 1000 uF for the 25 + 25 W version and 2200 uF for the 50 + 50 W version. |
