[DIY制作] 对Quad606研究后的一点果实
  [复制链接] 查看: 342726|回复: 924
1584 点
1568 ¥
发表于 2012-4-14 11:15 | 显示全部楼层
我有quad520; 支持出好声~
     http://quadrevisionspot.blogspot ... n-of-quad-520f.html
1584 点
1568 ¥
发表于 2012-4-14 11:38 | 显示全部楼层
Thursday, December 03, 2009
Quad 306 - 606 Monoblock & Virtual Earth
       http://quadrevisionspot.blogspot ... -virtual-earth.html
Corected version 20-02-2010
A Quad 303 or 405 power-amplifier can be easily converted to a parallel monoblock that will deliver more power to speakers with a lower impedance, will be more stable at higher volumes and can handle difficult loads like ESL speakers in a better way.
All you need are a trimmer potentiometer to divide the signal between both channels and (for the 405) some 0,3R 5W resistors to connect the outputs together. The Quad monoblock instructions are available in the Download-section.
In the 606, 707, 909 it is more complicated.
These amplifiers have a non-conventional power supply with a “virtual mass”. The advantage is that no DC power can go to the output so the clamp-circuit is no longer needed and that you will only need one fuse to protect the power-supply.
Both channels in are completely separated, the power-supply as well as the earth. Normally this technique is only used in professional audio. In the 606 the masses of both speaker-outputs (the black binding-posts) are connected… via the preamplifier, we may consider this a serious design-error!
Fortunately the virtual mass circuits in the separated power-supplies in both channels will keep the power-supply voltage at the correct level.
But when converting to monoblock we don’t want separate voltage regulation in both channels.
Another issue is that both safety-circuits (R32 and C12) are now in parallel between the signal-earth and the chassis, resulting in an impedance that is too low. When converting a 606 to monoblock those components will have to be removed in one of the channels. In the 306 they are only mounted once so they don't have to be removed.
Because of the separate power supplies both channels in the monoblock will not always react the same way. We will have to remove one of the regulation circuits and connect both power-supplies together. Also we have to remove one safety coupling. Look at the specific diagram's.
The 306 has a slightly differant layout, the mass of the two channels is allready conected together and there is only one safety coupling to mass.
To modify the amplifier to a monoblock , this is what we have to do:
Connect C10 (positive tag) in both channels in parallel by soldering an isolated copper wire between them on the copper-side of the Printed Circuit-board.
Do the same with C11 (negative tag).
In one channel remove the regulator circuit by removing R28, R29, R30, R31, T11 and T12.
Now the amplifier has one power-supply (with twice the power), and one regulator-circuit. We can now replace the RCA or Din input(s) by one new input, add a trimmer to divide the signal between both channels like in the 303 or the 405 monoblocks (tip: Glue the multiturn trimmer to the inside of the back-panel beside the RCA input) and the resistors between the outputs of both channels and the red binding-post. If you want to retain the input connector (Din or RCA) which is directly connected to the PCB, than connect the output wires of the pot to R1 in both channels and solder the input of the pot to the connector.
Stefaan & Joost
posted by Stefaan @ 4:30 PM
252
2万
超级版主 当前在线
如果拥有金耳朵,只能花更多金钱 ¥ $去折腾.
24561 点
23038 ¥
 楼主| 发表于 2012-4-14 20:15 | 显示全部楼层
Quad 606原理图
等待验证会员 当前离线
1911 点
1901 ¥
发表于 2012-4-14 20:40 | 显示全部楼层
回复 43# mxwmke1
加油,希望mxwmke1老师用灵活实用的方法使其早日出声。
1105 点
1094 ¥
发表于 2012-4-14 21:16 | 显示全部楼层
这个机器建议楼主还是别玩了.
国内除了一两个人外,包括湖泊之战也仿制不出来的.
照原机抄板那更是拿钱去丢的...
参与人数 1魅力 +3 收起 理由
mxwmke1 + 3 这话确实给我不少动力!
2万
超级版主 当前在线
24561 点
23038 ¥
 楼主| 发表于 2012-4-14 21:22 | 显示全部楼层
这个机器建议楼主还是别玩了.
照原机抄板那更是拿钱 ...
大神1981 发表于 2012-4-14 21:16
是否可以具体说说,是什么原因仿不出来?
1105 点
1094 ¥
发表于 2012-4-14 21:26 | 显示全部楼层
是否可以具体说说,是什么原因仿不出来?
mxwmke1 发表于 2012-4-14 21:22
具体原因我也不太清楚.只听到XX说过问题现象.你如果有示波器看一下就知道了.
252
2万
超级版主 当前在线
24561 点
23038 ¥
 楼主| 发表于 2012-4-14 22:41 | 显示全部楼层
大神1981 发表于 2012-4-14 21:26
查了一下帖,做不好的原因应是他当时没有合适的关键元件.
6452 点
6141 ¥
发表于 2012-4-15 01:21 | 显示全部楼层
支持楼主继续努力!
661 点
633 ¥
发表于 2012-4-15 02:35 | 显示全部楼层
支持LZ继续努力,早日定版!
眼见为虚,耳听为实
4470 点
4137 ¥
社区贡献 论坛贵宾 DIY大赛亚军
发表于 2012-4-15 18:12 | 显示全部楼层
支持mxwmke1 兄,我认为仿名机出来的声音不会差,声音肯定上档次
122
6118 点
5575 ¥
论坛贵宾
发表于 2012-4-15 19:37 | 显示全部楼层
标题
mxwmke1 发表于 2012-4-14 22:41
    具体原因不太清楚就能断定国内只有一两个人能做出来?有点莫名~相信楼主可以做到,支持~
2180 点
2139 ¥
发表于 2012-4-15 20:02 | 显示全部楼层
蓝调太子 发表于 2012-4-15 19:37
    那一两个能做出来的,我知道肯定让论坛封了的牛大王
(特别能吹)
730
1649 点
1110 ¥
发表于 2012-4-15 20:06 | 显示全部楼层
(特别能吹)
WKJ 发表于 2012-4-15 20:02
    他不去做广告台可惜了
252
2万
超级版主 当前在线
24561 点
23038 ¥
 楼主| 发表于 2012-4-15 20:25 | 显示全部楼层
(特别能吹)
论坛有关Quad606的资料确实不多,而且发现有一帖的原理图是错误的,即使网上可参考资料也不多,看原理图也并不算复杂,不知有些人为何觉得此机神秘,既然已决意要仿,是好是坏也要得出个结论来.
2180 点
2139 ¥
发表于 2012-4-15 20:27 | 显示全部楼层
支持mxwmke1 。相信可以做的出来
1592 点
1626 ¥
发表于 2012-4-15 22:10 | 显示全部楼层
6229 点
6137 ¥
发表于 2012-4-15 22:26 | 显示全部楼层
回复 57# 磁铁
    ,我有说我有405的套件卖吗?
149
2257 点
1848 ¥
DIY大赛获奖
发表于 2012-4-15 22:33 | 显示全部楼层
回复 48# mxwmke1
关键元件是那2个恒流管吗?
其实 JiangWZ 有关于QUAD707的帖子,而且还有制作过程  http://bbs.hifidiy.net/viewthread.php?tid=29004
QUAD606和后来的QUAD707、QUAD909以及他们的小弟弟QUAD306,其实是同一个电路,只是限流不同。
49
935 点
887 ¥
发表于 2012-4-16 03:03 | 显示全部楼层
好东西要支持阿!前面第一那个原理图正确无误吗?继续关注....
GMT+8, 2025-12-4 08:03 , Processed in 0.151549 second(s), 7 queries , Gzip On, Redis On.
