577 点
577 ¥
发表于 2012-4-2 01:02 | 显示全部楼层
标题
回复 20# 巡视员
    没接负载的时候是这样的,但接了负载后就不同了。
就楼主这个图 如果要在32欧的负载上要得到10V的电压,根据欧坶定律 I=U÷R,需要大概300毫安的电流。
假设三极管的放大倍数为100。那么Ib需要3毫安。计算得到偏置电阻大概是800欧坶。
100 点
100 ¥
发表于 2012-4-2 10:19 | 显示全部楼层
回复  巡视员
就楼主这个图 如果要在32欧的 ...
石投 发表于 2012-4-2 01:02
要获得较大的输出电压幅度,改变偏置是一种可能的途径,但电源电压限制了输出的动态范围,同时还应提高电源电压。
5672 点
5633 ¥
发表于 2012-4-2 13:01 | 显示全部楼层
millwood的三处发言很中肯,我把它配上中文一并贴在这里。
D1/D2 is used to bias the idle current in Q1/Q2: Idle current = (Vfwd1 + Vfwd2 - Vbe1 - vbe2) / (R3 + R4).
D1/D2被用来偏置Q1/Q2的静态电流=(Vfwd1 + Vfwd2 - Vbe1 - vbe2) / (R3 + R4).
if you reduce the value of those two resistor, you increase the current going through the diodes, thus increasing the voltage drop over the two diodes -> increasing idle current in Q1/Q2.
如果你降低这两个电阻的阻值,你就升高通过两个二极管的电流,结果两个二极管的压降)增加Q1和Q2电流
if Q1/Q2 is under-biased, you would reduce its cross-over distortion.
如Q1/Q2是低偏置的,你将降低交越失真。
if Q1/Q2 is properly biased, you would increase its distortion through gm-doubling.
如Q1/Q2是合适偏置的,你将通过倍增跨导而增加它的失真。
in general, you want to bias Q1/Q2 so that the voltage drop on the Re resistors is about 25mv each. in this case, that means a bias current of about 1.2ma.
一般来说,你想要偏置Q1/Q2以便降落在Re电阻的压降大约各自25mv。在这例子,那就意味偏置电流大约1.2mA。
not exactly.
不够准确。
when the input signal approaches its positive peak, the voltage drop over the top resistor R6 approaches its minimal, thus the current sourced by R6 approaches its minimal -> R6 has the least capability to drive the output transistor Q1.
当输入信号到达它的峰值,电压降落在上电阻R6到达它的极小值,这样由R6而来的电流到达它的极小值
〉R6有最小的潜力驱动输出晶体管Q1。
Unfortunately, that's precisely when the voltage across the load approaches its maximum -> Q1's Ic approaches its maximum and Q1 needs the most Ib.
不幸的是,那是正好在通过负载的电压到达它的最大值〉Q1的Ic到达它的最大值这时Q1需要最多的Ib。
the same thing happens on the negative cycle as well.
同样的事件一样发生在负半周。
5672 点
5633 ¥
发表于 2012-4-2 13:13 | 显示全部楼层
上一楼的文字是LZ在这里http://www.ourdev.cn/thread-5441893-1-1.html讨论时,millwood 的回帖。
5672 点
5633 ¥
发表于 2012-4-2 14:12 | 显示全部楼层
回复 1# XChuda
5672 点
5633 ¥
发表于 2012-4-2 14:20 | 显示全部楼层
回复 1# XChuda
或者这样就更加理想了。
5672 点
5633 ¥
发表于 2012-4-2 14:24 | 显示全部楼层
OK
5672 点
5633 ¥
发表于 2012-4-2 14:26 | 显示全部楼层
It's end
93 点
94 ¥
 楼主| 发表于 2012-4-2 15:12 | 显示全部楼层
5672 点
5633 ¥
发表于 2012-4-2 15:17 | 显示全部楼层
回复 29# XChuda
如果完全按照原电路,我做出来也是13vp-p就开始失真,一样的啊。
5672 点
5633 ¥
发表于 2012-4-2 15:25 | 显示全部楼层
回复 29# XChuda
不过,BC337-40/327-40的HFE很 高的,最高的达600~700左右。
111
4868 点
4434 ¥
发表于 2012-4-2 15:29 | 显示全部楼层
俺对三极管也只是一知半解,楼主这个电路是否因为用的管子Ic饱和所致?PN结的所有载流子都参与导电了,也只能在32Ω的负载阻抗上产生这些压降?
5672 点
5633 ¥
发表于 2012-4-2 15:52 | 显示全部楼层
没有自举时是只有13vp-p。
5672 点
5633 ¥
发表于 2012-4-2 15:56 | 显示全部楼层
加自举。
5672 点
5633 ¥
发表于 2012-4-2 16:02 | 显示全部楼层
啊啊,28 楼的是假象啊,不好意思了,我是在做出变形的正弦波后加上电容在点击的结果,因为那是电容充电的瞬间带来的结果,当我用Stop Time:100ms,Time to start Saving Date:90ms,就没有那么高输出的结果了,最多就上一楼的结果。
5672 点
5633 ¥
发表于 2012-4-2 16:06 | 显示全部楼层
5550/5401就不行了。
5672 点
5633 ¥
发表于 2012-4-2 16:09 | 显示全部楼层
5550/5401 输出还达不到13vpp
5672 点
5633 ¥
发表于 2012-4-2 16:12 | 显示全部楼层
BC817-40/807-40也行。
5672 点
5633 ¥
发表于 2012-4-2 16:25 | 显示全部楼层
输入加电容是最佳的办法。这下可以输出很高电压了。
5672 点
5633 ¥
发表于 2012-4-2 16:28 | 显示全部楼层
5550也摇身一变能力非凡了。
GMT+8, 2026-4-3 01:51 , Processed in 0.178330 second(s), 9 queries , Gzip On, Redis On.
