107 点
152 ¥
发表于 2012-2-9 22:52 | 显示全部楼层
146 点
140 ¥
发表于 2012-2-11 12:11 | 显示全部楼层
新一代的USB解码器已经上市一年多,技术成熟,HIFIDIY可以量产了啊,本人的解码器也该升级了,茂伦TENOR TE7022L  TE8802L的指标远远高于pcm2704系列, 重要的是支持USB2.0全速总线。高清电影声音不卡了。 希望早日,买到你们的产品,谢谢啊, 以下是指标,不翻译了 很简单的。在淘 宝已经很多人在卖7022产品,看不到 HIFIDIY,,用了你们的 E6音箱 很是喜欢,继续用你们的产品。台湾人做出的芯片,怒自己人做不出来。TENOR TE7022L  :USB 2.0 Full Speed compliant & USB Audio Class 1.0 supported
• 16/24 bit Resolutions supported
• 8/16/32/44.1/48/96 KHz sampling rates supported
• 2-input channels and 2-output channels supported by one I2S pairs with independent sample rate
• Built in IEC60958 professional S/PDIF TX & RX, AES/EBU supported
• 6 GPI pins for HID function
• Built-in ROM for USB descriptor
• One I2C master port for external EEPROM for advance feature
• PLL integrated to support single 12MHz crystal operation
• 3.3V Operation Voltage
• 48pin LQFP package
• PB-Free
TE8802L provides a very flexible USB2.0-based audio & multimedia solution. Interleaved 2-channel input and output with 16/24-bit resolution and 44.1/48/88.2/96/176.4/192K sample rate are supported.
• USB2.0 High-Speed device supporting Audio Class v2.0
• USB2.0 Full-Speed device supporting Audio Class v1.0
• Audio Features
• 2-Inputs support by one I2S pairs with 128/256 Fs
• 2-Output support by one I2S pairs with 128/256 Fs
• Adaptive/Asynchronous Mode supported
• High-Speed mode support Adaptive/Asynchronous
• Full-Speed mode support Adaptive only
• Resolutions support 16/ 24-Bit with sampling rates support 44.1/48/88.2/96/176.4/192KHz
• Built in one IEC60958 professional 24 bit/96KHz S/PDIF RX
• Built in one IEC60958 professional 24 bit/192KHz S/PDIF TX
• One set of master I2C ports
• Two sets of standard MPU-401 compliant MIDI Tx/Rx pair by UART with pass-thru.
• Offer customized driver for Windows OS
• 1.8V core, 3.3V analog and I/O (3.3V tolerant)
• LQFP-128 package
• PB-Free
1389 点
1044 ¥
发表于 2012-2-11 22:14 | 显示全部楼层
能公布DAC 芯片型号吗?
318 点
311 ¥
发表于 2012-2-12 14:22 | 显示全部楼层
好多坛友说贵,其实不然,如果你只算材料成本的话也没办法,前期设计投入很花心思,加上各种附属(比如包装,外壳等等),这些东西都是有一定的采购厂家才做的,所以其中的各种风险不是你想像中那样简单。
146 点
140 ¥
发表于 2012-2-14 20:09 | 显示全部楼层
看图 辨别为茂伦TENOR TE7022L TE8802L的解码器,TE8802L 芯片 目前只授权给一线工厂,,只有7022可以买到 8802 规格远远高于7022
22 点
22 ¥
发表于 2012-2-15 06:42 | 显示全部楼层
3R33看着眼熟啊
82 点
82 ¥
发表于 2012-2-15 15:06 | 显示全部楼层
看看啊!!
167 点
167 ¥
发表于 2012-2-15 16:03 | 显示全部楼层
标记!继续关注!
339 点
335 ¥
发表于 2012-2-15 22:33 | 显示全部楼层
这个要搞一个,现在一个人在书房听音乐比较多.
511
揭阳逸帆音响
526 点
314 ¥
发表于 2012-2-22 11:26 | 显示全部楼层
漂亮 。
51 点
250 ¥
发表于 2012-2-23 11:00 | 显示全部楼层
大概价格多少啊
5 点
5 ¥
发表于 2012-2-26 21:51 | 显示全部楼层
何时出品
889 点
883 ¥
发表于 2012-3-7 21:20 | 显示全部楼层
  觉得旋钮太大太突兀太不协调啦。
HI-FI 新手
95 点
42 ¥
发表于 2012-3-11 22:52 | 显示全部楼层
这个好,我也想要
63 点
61 ¥
发表于 2012-3-27 21:27 | 显示全部楼层
这个DAC能直接当声卡用吗?
81 点
79 ¥
发表于 2012-3-28 13:56 | 显示全部楼层
耳放那部分用的是什么芯片,能推得动K601吗,之前的MINI USB AMP推不太动
192 点
192 ¥
发表于 2012-3-31 00:22 | 显示全部楼层
已有MINI DAC
24 点
24 ¥
发表于 2012-4-8 20:31 | 显示全部楼层
订了一台,不知何时能到货?
1860 点
1939 ¥
发表于 2012-4-18 08:29 | 显示全部楼层
造型不错
46 点
38 ¥
发表于 2012-5-2 21:45 | 显示全部楼层
很漂亮啊,要一个
GMT+8, 2026-5-13 14:03 , Processed in 0.140607 second(s), 8 queries , Gzip On, Redis On.
