470 点
303 ¥
发表于 2004-12-18 12:10 | 显示全部楼层
图片太小了,斑主能否搞大它!
[em11][em11][em11]
109
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
 楼主| 发表于 2004-12-18 13:49 | 显示全部楼层
正准备把图片搞清晰,再上图。上次我是用手拍照片的,水平较差[em10]
英文帖中有点错误,已更正[em11]
Originally posted by X.G.
3)check on-board
a.the LV scale of analog multimeter
the full-scale is 3V(the precision vale is the actual Voltage of inner battery),the indicator at centre show 1.5V....the indicator at start show 0V.
Sorry,I made a mistake on here( my Chinese post don't have it).Now correct it:
the full-scale is 0V(after the 'ZERO' Ohm calibrated) ,the indicator at centre show 1.5V....the indicator at start show 3V(the precision vale is the actual Voltage of inner battery).
109
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
 楼主| 发表于 2004-12-18 14:26 | 显示全部楼层
重新上传整张说明图(超大)
点击后。。。你就知道有多大[em06][em11]
<img src="attachments/dvbbs/2004-12/20041218142553965.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-12/20041218142553965.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
470 点
303 ¥
发表于 2004-12-18 15:30 | 显示全部楼层
133
4912 点
2799 ¥
元老级
发表于 2004-12-18 20:38 | 显示全部楼层
向鬼版学习
ENGLISH
等待验证会员 当前离线
carhifi
1378 点
7 ¥
发表于 2004-12-18 21:18 | 显示全部楼层
佩服佩服,向鬼版学习啊
看来要真的下决心学学鸡肠了,现在要是地球人都懂那么一点英文,俺西瓜大的英文认识不了一筐,惭愧惭愧[em08][em08][em11]
52
459 点
219 ¥
发表于 2004-12-18 22:11 | 显示全部楼层
估计英文过了20级
。[em03]
2556
管理员 当前离线
Rank: 9Rank: 9Rank: 9
14144 点
3154 ¥
发表于 2005-3-17 22:50 | 显示全部楼层
292
nostalgia
19692 点
12949 ¥
发表于 2005-3-17 22:59 | 显示全部楼层
中英文结合第一强贴
[em11][em11]
113 点
2 ¥
发表于 2005-3-17 23:48 | 显示全部楼层
哈厉害,收藏ING~~~
919 点
10 ¥
发表于 2005-3-18 00:14 | 显示全部楼层
学到知道的好贴~~~
[em02][em02][em02][em02]
DIY达人
1105 点
251 ¥
发表于 2005-3-18 00:25 | 显示全部楼层
非常好!精彩!!
93
超级贵宾 当前离线
守时、守信、信心、恒心、好奇
3252 点
1069 ¥
元老级 论坛贵宾 花甲前辈 super 贵宾
发表于 2005-12-13 16:57 | 显示全部楼层
小鬼头,这项测量法我还有补充。
四、通电测量法
    见附图的7
此主题相关图片如下:
    这种方法很简单,就是测量工作时三极管的be极电压。因为功放(以及前置)中的三极管(除保护电路等少部分外、这里的测量通常也不适用于末级功率三极管)均是处于放大区的,所以正常的硅三极管be极电压是0。6至0。7V。
   不是0。6至0。7V的,若果是高于此值的,通常是此管已损坏。若果低于此值的,则不一定是此管坏,但可以判断属于不正常工作了,可循此进行追查。。。需电路分析了,呵呵。
就是BE极短路法:
通电后,将三极管be极短路,这时三极管处于截流状态。如果三极管良好,C极电压会升高到供给电压电位(C极上串有电阻,对串电感者不大适用),如果电压不升高,这管CE极已短路;如果电压升高不大,表示这管已严重漏电,应要更换。
399
16987 点
8777 ¥
发表于 2005-12-13 17:27 | 显示全部楼层
如果测量象OCL这类多级直耦电路就要小心了
以下是引用wongkm33在2005-12-13 16:57:00的发言:
四、通电测量法
<I></I> <I></I> <I></I> <I></I> 见附图的7
此主题相关图片如下:
<I></I> <I></I> <I></I> <I></I> 这种方法很简单,就是测量工作时三极管的be极电压。因为功放(以及前置)中的三极管(除保护电路等少部分外、这里的测量通常也不适用于末级功率三极管)均是处于放大区的,所以正常的硅三极管be极电压是0。6至0。7V。
<I></I> <I></I> <I></I> 不是0。6至0。7V的,若果是高于此值的,通常是此管已损坏。若果低于此值的,则不一定是此管坏,但可以判断属于不正常工作了,可循此进行追查。。。需电路分析了,呵呵。
就是BE极短路法:
尤其是控制末级偏流的管.[em11]
93
超级贵宾 当前离线
守时、守信、信心、恒心、好奇
3252 点
1069 ¥
发表于 2005-12-13 19:30 | 显示全部楼层
当然,对于多级直交电路这样测法是不大适用的。
以下是引用HQ在2005-12-13 17:27:00的发言:
尤其是控制末级偏流的管.[em11]
794 点
146 ¥
发表于 2005-12-13 22:09 | 显示全部楼层
建议鬼版把图弄的清楚点
最好是用制图软件画
93
超级贵宾 当前离线
守时、守信、信心、恒心、好奇
3252 点
1069 ¥
发表于 2005-12-13 23:45 | 显示全部楼层
好的,我有空帮他画。
以下是引用wgvf在2005-12-13 22:09:00的发言:
最好是用制图软件画
109
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
 楼主| 发表于 2005-12-14 00:59 | 显示全部楼层
对。这方法也很不错。。。。我在检修其它电路时也用到。在功放中,间或也使用。我用得少,主要是因为需两手操作。。。。。一只手拿螺丝批呀什么的,去“短路”BE极,另一只手拿表笔去测量。。。。怕万一没拿牢东西,短路其它地方,引发其它的严重故障。。。。不知WONGKM33兄有何妙计?
正如HQ兄所言。。。。再次提醒的是,使用这种方法,须看场合。
385 点
126 ¥
发表于 2005-12-14 01:22 | 显示全部楼层
检修的时候还可以串连个灯泡在末级
这样可以放心操作而不必担心会烧掉功率管,而且还能通过发光的亮度判断电流大小。
缺点就是有些电路板不好串联。
93
超级贵宾 当前离线
守时、守信、信心、恒心、好奇
3252 点
1069 ¥
发表于 2005-12-14 11:08 | 显示全部楼层
我修理机器时,通常带备4对鳄鱼夹跳线。
以下是引用小鬼头在2005-12-14 0:59:00的发言:
先将电表黑线用跳线固定在底板地端,右手拿红表棒接C极(用跳线接牢亦可,这时就不需二手同时操作),另一手拿着摄子或螺丝批将BE极短路,如果使用跳线作短路则较安全。先把跳线接牢其中一脚,然后用另一端去碰触另一脚就可完成操作。用摄子或螺丝批作短路则比较方便快?。
GMT+8, 2026-3-24 20:06 , Processed in 0.131913 second(s), 7 queries , Gzip On, Redis On.
