[心得经验] 走遍中,台,港,澳四地的-CDM12(澳门区)
[复制链接] 查看: 49977|回复: 72
DIY达人
1105 点
251 ¥
 楼主| 发表于 2006-12-25 17:28 | 显示全部楼层
<div class="quote"><b>以下是引用<i>dh1030</i>在2006-12-25 9:15:00的发言:</b><br/>LZ在澳门的吗?</div><p><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">对</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">!</span><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">我是澳门渔村里一个平凡的渔民</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">........</span><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">不过现在这里已变成赌城了</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">,</span><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">没鱼可打了</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">!</span><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">哈哈</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">!!</span>[em01][em01]</p>
221
2708 点
1463 ¥
发表于 2006-12-25 15:19 | 显示全部楼层
<p><strong><font face="Verdana" color="#61b713">yyym2:</font></strong></p><p><strong><font face="Verdana" color="#61b713" size="4">转盘如何调音以及配什么解码器有音乐味,请大侠说说好吗?</font></strong></p>
261 点
7 ¥
发表于 2006-12-28 14:07 | 显示全部楼层
<div class="quote"><b>以下是引用<i>mousedog</i>在2006-12-28 0:51:00的发言:</b><br/>今晚带了自己部高阶版去朋友处听听,他有标准版.比较之下觉得两者声底非常接近,标准版声音比较厚重,人声略紧几分,解析力和背景宁静度不输给高阶版,我的改改高阶版在高中频较响亮,声音较起(生动),线条要好一点点.<br/>说实话标准版的声音已非常ok,值回票价![em05]</div><p></p><p>好消息!看来标准版已经很好了。那我的高阶版也一定没有问题了!</p><p></p><p>漫长的等待。。。。。。。。。。。。。。。。。。。。。。。。</p>
最闲也是最忙
336 点
83 ¥
发表于 2006-12-28 13:58 | 显示全部楼层
<div class="quote"><b>以下是引用<i>mousedog</i>在2006-12-27 17:18:00的发言:</b><br/><p>这些电容我这里较难找,不知菲利普的银壳电解如何?另电阻等紧丽特的红色RA阻,不知效果会不会比holco好.</p><p>5687兄有无试过呢?</p></div><p></p>可以在旧的显卡上拆阿,在永乐电影院旁边那条街不是有几间卖旧货的,那里应该可以找到。
221
2708 点
1463 ¥
发表于 2006-12-28 08:23 | 显示全部楼层
<p>这样的贴要顶!</p><p></p>
DIY达人
1105 点
251 ¥
 楼主| 发表于 2006-12-28 00:51 | 显示全部楼层
542 点
171 ¥
发表于 2006-12-27 22:54 | 显示全部楼层
红色RA电阻用了6个,应该比holco好,价钱贵一倍的。旦电容原本相用金属外壳轴向的,买不到,只能买到这种,效果也不错,也不贵,网上买的
1191 点
607 ¥
发表于 2006-12-27 18:45 | 显示全部楼层
<p>那个电容 可以用轴相的坦电容 应该不会比OS差。</p>
DIY达人
1105 点
251 ¥
 楼主| 发表于 2006-12-27 17:18 | 显示全部楼层
<div class="quote"><b>以下是引用<i>5687</i>在2006-12-27 13:53:00的发言:</b><br/>os电容8个,用旦电解换,就是这个<img alt="" src="http://www.cndiyclub.com/bbs/attachment/Fid_33/33_8068_9b157a8649d5fc1.jpg" border="0"/><br/></div><p>这些电容我这里较难找,不知菲利普的银壳电解如何?另电阻等紧丽特的红色RA阻,不知效果会不会比holco好.</p><p>5687兄有无试过呢?</p>
542 点
171 ¥
发表于 2006-12-27 13:53 | 显示全部楼层
os电容8个,用旦电解换,就是这个<img src="http://www.cndiyclub.com/bbs/attachment/Fid_33/33_8068_9b157a8649d5fc1.jpg" border="0" alt=""/>
261 点
7 ¥
发表于 2006-12-27 11:23 | 显示全部楼层
<div class="quote"><b>以下是引用<i>5687</i>在2006-12-27 11:18:00的发言:</b><br/>我用旦电解换掉os电容后的声音比较宽松,低频好了点</div><p></p>是换了哪几个,还是全部呢?是否换菲利普蓝六角会更好呢?
542 点
171 ¥
发表于 2006-12-27 11:18 | 显示全部楼层
261 点
7 ¥
发表于 2006-12-27 11:04 | 显示全部楼层
<div class="quote"><b>以下是引用<i>5687</i>在2006-12-27 10:30:00的发言:</b><br/><p>同轴输出的电阻换了,晶体旁边的100欧电阻不妨也换了吧。我觉得效果最显著的把那些os电容换了!</p></div><p></p><font color="#0938f7" size="5"><strong>请5687兄讲讲换电容前后的效果吧!让我们等转盘的TX过过干瘾!</strong></font>
542 点
171 ¥
发表于 2006-12-27 10:38 | 显示全部楼层
我也曾用镀银屏蔽线直接焊到板上,后来还是换回原来配的线。感觉还是原配线的味道好
542 点
171 ¥
发表于 2006-12-27 10:30 | 显示全部楼层
261 点
7 ¥
发表于 2006-12-27 10:28 | 显示全部楼层
<div class="quote"><b>以下是引用<i>mousedog</i>在2006-12-27 0:12:00的发言:</b><br/><p>servo板J6插的(电源板的J100)那三根线(+VD1,GND,+VD2)我是全换了, VD1 和VD2换了较粗的线,效果不太明显,</p><p>GND那条上左条粗银线(由图中那条线拆开用),</p><p><img src="attachments/dvbbs/2006-12/20061227024852194.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-12/20061227024852194.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /></p><p>地线在一部机内是非常重要,只靠那几根原本的线我觉就不足,将负责供电命脉那根GND换左之后,比较干的人声变得厚润左,原本紧张的低频出得自然好多,解析力提高,听鼓王的龙腾虎跃非常正[em03].将那三根线作扭绞减低干扰比净用磁环好.</p><p><br/>servo板J4插的时钟线和数字S/PDIF连线就较烦了,也踫壁了不少,大家要换可先看看 kelan兄的贴,他的宝贵调试经验直得参考[em07].</p><p><a href="http://www.hifidiy.net/bbs/dispbbs.asp?boardid=2&amp;replyid=538203&amp;id=44137&amp;page=1&amp;skin=0&amp;Star=2">http://www.hifidiy.net/bbs/dispbbs.asp?boardid=2&amp;replyid=538203&amp;id=44137&amp;page=1&amp;skin=0&amp;Star=2</a></p><p>我也建议不能全上屏蔽线,声音会变得毫无音乐味,低频也变薄,不好听!就算上也只能换时钟信号那对连线,而且要用线芯柔软不太粗那种银屏蔽线.试过用粗硬的都令声音高频段吵耳,起毛刺!<br/>数字S/PDIF那对连线还是用散线比较合适,为了增加中频厚度和乐感我也上了纯铜散线,再加上磁环.<br/>servo板J5插的就不需理会,原的也ok.</p><p>&nbsp;</p><br/></div><p><strong><i>mousedog</i>兄的宝贵调教经验!仁兄有没有试试把接线直接焊接到板子上面,是不是声音更好,还是和用插接件没有什么区别呢?</strong></p>
DIY达人
1105 点
251 ¥
 楼主| 发表于 2006-12-27 00:15 | 显示全部楼层
<div class="quote"><b>以下是引用<i>5687</i>在2006-12-27 0:02:00的发言:</b><br/>好奇怪你的散热器怎么不是黑色的?</div><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">哈哈</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">!</span><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">因为之前发漏给我</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">,</span><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">自己买的</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">......</span><span lang="ZH-CN" style="FONT-SIZE: 10.5pt; FONT-FAMILY: SimSun; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial; mso-fareast-language: ZH-CN;">不好看</span><span lang="EN-US" style="FONT-SIZE: 10.5pt; FONT-FAMILY: Arial; mso-fareast-language: ZH-CN; mso-fareast-font-family: SimSun;">!!</span>[em03]</p>
DIY达人
1105 点
251 ¥
 楼主| 发表于 2006-12-27 00:12 | 显示全部楼层
<div class="quote"><b>以下是引用<i>panzk</i>在2006-12-26 9:03:00的发言:</b><br/><p><font size="5"><font color="#0909f7"><strong><em>mousedog</em></strong>兄,请一定把调教接线的经验公布出来,请我等少走弯路啊!</font></font></p><p><font color="#0909f7" size="5">图上的三根线怎么只有2根加了磁环?如果三根线都粗壮,分别加磁环,是不是更好呢?</font></p></div><p>servo板J6插的(电源板的J100)那三根线(+VD1,GND,+VD2)我是全换了, VD1 和VD2换了较粗的线,效果不太明显,</p><p>GND那条上左条粗银线(由图中那条线拆开用),</p><p>
542 点
171 ¥
发表于 2006-12-27 00:02 | 显示全部楼层
好奇怪你的散热器怎么不是黑色的?
87 点
0 ¥
发表于 2006-12-31 15:25 | 显示全部楼层
<div class="quote"><b>以下是引用<i>panzk</i>在2006-12-28 14:07:00的发言:</b><br/><p></p><p>好消息!看来标准版已经很好了。那我的高阶版也一定没有问题了!</p><p></p><p>漫长的等待。。。。。。。。。。。。。。。。。。。。。。。。</p></div><p></p>加個綠燈開關 比較一下就知綠燈 是否有效.
GMT+8, 2026-5-19 21:50 , Processed in 2.584517 second(s), 9 queries , Gzip On, Redis On.
