655 点
30 ¥
发表于 2004-11-2 21:59 | 显示全部楼层
应是TDA8808、TCA0372电路有问题,牵涉整个光头侍服系统不正常。表现为激光管无光、无聚焦及寻迹动作。当然反馈影响CPU误动作,致使电机不停旋转不为其。
190 点
1 ¥
发表于 2004-11-2 21:33 | 显示全部楼层
各位老大
找到原因了,我的4.7K电位器接错了,转是转起来了,但停不下来,直到显示ERR为止,经过对比发现,TDA8808的3脚,也就是HF OUT端的直流电位不对,应该在2.5V左右,可我的板上很小,SAA7310的24脚也就是电机速度控制一直处于高电平,致使电机不停旋转,而正常情况下应该从高电平降下来,会不会是TDA8808的问题哪?
655 点
30 ¥
发表于 2004-11-2 21:17 | 显示全部楼层
又发现问题了。
两图如红圈中,TCA372DP2此点究竟是+10V还是-10V?CDM4PCB此点是-10V。
<img src="attachments/dvbbs/2004-11/200411221162164.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-11/200411221162164.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2004-11/2004112211632534.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-11/2004112211632534.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
655 点
30 ¥
发表于 2004-11-2 16:13 | 显示全部楼层
是啊!试机才知道!呵呵!
以下是引用gyxxyg在2004-11-2 13:10:00的发言:
通电后冒了烟,发现载片电机驱动的两只三极管(BC32825、BC33825)位置错了,应该互换一下,个别元件不能太高,如载片电机插座,插头插上后就高了。
[em02][em02][em02]
BC32825、BC33825要互换位置,以为我的741有问题呢,是啊!试机才知道!呵呵!
<img src="attachments/dvbbs/2004-11/2004112162052235.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-11/2004112162052235.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
190 点
1 ¥
发表于 2004-11-2 14:55 | 显示全部楼层
晚上试着在图上标一下
190 点
1 ¥
发表于 2004-11-2 14:53 | 显示全部楼层
还要调?
不过沙兵老大我的4.7K可调电阻值是按原板的值调的,还需调吗?
127
K哩啡
3577 点
792 ¥
元老级
发表于 2004-11-2 14:35 | 显示全部楼层
能够在上标示出这两只三极管的位置吗?
谢谢!
58
676 点
199 ¥
发表于 2004-11-2 13:48 | 显示全部楼层
老大慢慢调整
4.7K的可调电阻直到碟片可以转动就OK了[em11][em11]
190 点
1 ¥
发表于 2004-11-2 13:18 | 显示全部楼层
另有问题求救
我的CDM4板子通电后显示正常,进出盘控制正常,主轴上电时也有初始动作,激光头也有动作,但装上碟片后却不能读碟,主轴也不转。光头组件是好的(因为还有一块MKH310板可以试),会不会是哪个片子有问题哪?几个贴片片子都是从另一块MKH310板上拆下来的,不知是否会损伤片子?在此多谢了!
190 点
1 ¥
发表于 2004-11-2 13:10 | 显示全部楼层
通电后发现板上还有错误
708 点
540 ¥
 楼主| 发表于 2004-10-29 15:42 | 显示全部楼层
老飘,能不能给个元件表?
谢谢。
437 点
5 ¥
发表于 2004-10-29 13:21 | 显示全部楼层
请看
http://www.cndiyclub.com/bbs/list.asp?boardid=3
190 点
1 ¥
麻烦飘兄发我一份吧,谢谢!
ggyyx@263.sina.com
655 点
30 ¥
发表于 2004-10-29 12:36 | 显示全部楼层
发我一份,谢谢!
以下是引用purer在2004-10-29 12:00:00的发言:
如果有需要的话我可以提供线路图
已保存,谢谢![em11][em11][em11]
广东广州
2325 点
540 ¥
发表于 2004-10-29 12:34 | 显示全部楼层
purer兄
电话里你说给我线路图我一直都没收到。
麻烦你两个邮箱都发,稳当些
danielyang@163.com
danielyang@sina.com
125
超级战士
2023 点
1135 ¥
发表于 2004-10-29 12:23 | 显示全部楼层
飘兄拜托发一份图纸到我邮箱。
liyuan-sh@yeah.net
还有gtmaker兄,方便的话也给我发一份。
437 点
5 ¥
发表于 2004-10-29 12:00 | 显示全部楼层
如果有需要的话我可以提供线路图
708 点
540 ¥
 楼主| 发表于 2004-10-29 00:49 | 显示全部楼层
这些我还是懂得
看不懂还敢焊这块板吗 ?
708 点
540 ¥
 楼主| 发表于 2004-10-29 00:43 | 显示全部楼层
收到回话每人三个邮件
发给你们的图片资料,如你们会压缩,请压成清晰的图片上传到论坛,以方便大家。
但图中有个错误我在22楼提过,其他的错误相互交流吧。
655 点
30 ¥
发表于 2004-10-29 00:42 | 显示全部楼层
已经爽了,应该无问题吧!
以下是引用gtmaker在2004-10-28 23:48:00的发言:
  由于沙冰破解的板可能和我cdm4原版的不一样,电路设计可能略有不同,我的希望是认真研究电路后一次成功。不要把现在的板拆了,结果白忙一场。
愿大家都能一次成功。
[em11][em11][em11]
沙冰兄象是按MKH310机PCB除去电源和TDA1543解码电路,加入数码输出电路改进而成的,元件摆布都差不多,但比MKH310整齐美观(元件摆布虽然还有点小瑕疵)。元件可能按MKH310的参数吧。既然沙冰兄已有样版,已经爽了,应该无问题吧!
GMT+8, 2026-5-19 20:33 , Processed in 0.158275 second(s), 8 queries , Gzip On, Redis On.
