123
[经验心得] 我很郁闷,为什么胆机这么重!!!
[复制链接] 查看: 10214|回复: 46
173
3477 点
3349 ¥
发表于 2010-7-19 09:53 | 显示全部楼层
这样的用差料,厂家赚大了.还DIY好.
258 点
253 ¥
发表于 2010-7-27 12:33 | 显示全部楼层
胆机其实就那3头牛重!  管子很轻的
5 点
5 ¥
发表于 2010-7-27 14:53 | 显示全部楼层
秤不准,四头牛加起来最多三十斤.连管子,机壳等零件总共四十斤左右.
4 点
4 ¥
发表于 2010-7-27 15:57 | 显示全部楼层
刚放体重秤上。。42KG。。。
13684999 发表于 2010-7-13 23:43
好重呀!
沈阳松盈丰展影音设计 www.vipthx.com 世霸音箱 杰士音箱 奥图码
沈阳五里河公园网球场www.sywlh.com
沈阳山旅户外现已更名为沈阳三夫户外,欢迎新老朋友惠顾www.shanlu.com
沈阳斯立达电梯有限公司 www.sysldelevator.com 电梯销售 电梯安装 电梯维修 诚聘电梯销售人员
东北物流城 www.nlc88.com
281 点
271 ¥
 楼主| 发表于 2010-7-28 00:50 | 显示全部楼层
关于重量的问题 40KG以上,不到40KG,我把机子送你,厂家数据还205W,我后面标的145W,声音我就不多说了,免得招砖
发烧.土匪..
1075 点
1114 ¥
发表于 2010-7-28 00:54 | 显示全部楼层
纠纷待定组 当前离线
-328 点
682 ¥
发表于 2010-7-28 04:49 | 显示全部楼层
There are good reasons for a heavy 300B tube amp.
Output Transformer - the primary inductance should be large so that it would have good low frequency response. Higher inductance requires bigger the core.
Power Transformer - the single ended amplifier runs in Class A at 100% duty. Therefore, bigger transformer will not generate too much heat.
Filtering choke - the amp employs choke filter sounds better. Larger the choke, the better ripple rejection it would have. I use double PI - CLCLC filtering for the B+ to minimize the hum noise from the B+.
If I would buy a tube amp, surely I would believe heavier the better.
Johnny
GMT+8, 2025-12-20 07:17 , Processed in 0.103928 second(s), 18 queries , Gzip On, Redis On.
