想简单配对一下irfp044
 关闭 [复制链接] 查看: 6012|回复: 7
418 点
103 ¥
发表于 2004-8-26 20:39 | 显示全部楼层
各位老大有和简便方法?我手头有可调电源和数字表!
418 点
103 ¥
 楼主| 发表于 2004-8-27 21:02 | 显示全部楼层
多谢大家!!
小弟先谢谢!
360
管理员 当前离线
万金油
Rank: 9Rank: 9Rank: 9
18146 点
14095 ¥
元老级 社区贡献 优秀设计 论坛版主
发表于 2004-8-27 20:40 | 显示全部楼层
ALEPH兄也来了?欢迎欢迎!
184 点
1 ¥
发表于 2004-8-27 15:32 | 显示全部楼层
这个93年,PASS老头一篇文章很详细。
How To: Matching Devices: © 1993, Nelson Pass
After you acquire the devices, you will need to test them. You might consider running lots of tests on these transistors, but only one is essential: measuring gate-source voltage versus current. The greatest variations occur here, and it is necessary to do some matching to get proper performance. This test will also tell you whether or not the device is broken.
The test is simple and requires a power supply, a resistor, and a DC voltmeter. Figure 12 shows the test hookup for N- and P-channel types. The supply source resistance (R1) is nominal, and is found from I = (V - 4)/R1. Consistency is the most important thing here. The given voltage is 15 and, adjusting for about a 4V VGS, we will see about 11V across the resistor.
<img src="attachments/dvbbs/200482715311869173.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/200482715311869173.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
We are looking for as much matching of the input MOSFETs as possible at a current of 5mA. For this test, we use an R1 value of 2.2kohm. Measure the voltage between the gate and the source. Write it down on a piece of masking tape or a sticky label and place it on the part. Keep in mind the caveats about electrostatic discharge: touch ground before you touch the parts.
Matching input MOSFETs is critical, because they must share equally the 10mA of bias current from the current source, and they will not do that unless their VGS is matched. At 5mA current, they have an equivalent source resistance of about 15ohm. Assuming we want them to share the current to within 2mA, we calculate the required VGS match as follows. Using the formula V = IR, we see V = 0.002 x 15, which gives us 30mV. The VGS of the input devices should be matched to within 30mV at 5mA current. The matching is only essential within a given pair; you do not have to match the Ps to the Ns, or match to devices in another channel.
If you are unable to find input devices matched to within 30mV, you must insert resistance in the source to make up the difference. The resistance is calculated by the difference of the two values of VGS divided by 5mA. For example, if the difference in VP1GS is 100mV, then 0.1/0.005 = 20ohm. You would then place 20ohm in series with the MOSFET source having the lower VGS.
We use the same test setup for the MOSFETs in the TO-220 packages but at a higher current (20mA), so we use a 560ohm resistor. No matching is required for these devices; we are just checking to see that the VGS is between 4-4.6V and that they work.
We will measure the output device VGS at about 170mA. You can achieve this with either a 56ohm at 2W resistor, or two 100ohm at 1W resistors in parallel. We are looking to obtain a reasonable match within a parallel output bank of each polarity of each channel, so we want two groups of 12 with matched N- channel devices, and two groups of matched P-channel devices.
The VGS voltages of our test samples gave the following spread:
                   N-channel ---- P-channel
Min. VGS ---- 4.00V ------ 3.79V
Max. VGS --- 4.57V ------ 4.15V
Avg. VGS ----4.42V ------ 4.01V
We also measured the transconductance by taking another reading for each device at a higher current (0.5A), just to see what kind of variation we got. The transconductances measured from a low of 1.19 to a high of 1.56, with the average at about 1.35. Within this amplifier's general operating curve, each output will vary its current by about 1.3A for every volt of its VGS change. For 12 devices in parallel, we expect about 15A for each such volt.
By placing 1ohm source resistors on each transistor, we can assure adequate current sharing for a fairly wide range of VGS. In Class A bias, we will be operating at about 200mA/device, which will place 0.2V across each source resistor. A variation in VGS will cause the bias to be unequally di
广东广州
2325 点
540 ¥
发表于 2004-8-27 10:15 | 显示全部楼层
这个
<img src="attachments/dvbbs/20048271015069439.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/20048271015069439.gif\');}" onmousewheel="return imgzoom(this);" alt="" />
1443 点
469 ¥
发表于 2004-8-26 22:02 | 显示全部楼层
最好在接近工作电压电流下配对
418 点
103 ¥
 楼主| 发表于 2004-8-26 21:35 | 显示全部楼层
多谢!等!
2555
管理员 当前离线
14140 点
3152 ¥
发表于 2004-8-26 21:17 | 显示全部楼层
需要2块万用表和一个简单电路的!还需要一个5V电源!
这个电路我一下子记不起来!
等我翻到就贴上来![em11]
场管是压控元件!
