nostalgia
19692 点
12949 ¥
发表于 2006-4-10 16:28 | 显示全部楼层
<>你去理他干呢</P>
他说的曙光管子也是有限的接触罢了,根本没了解过中国的805
<>这个老外一看就是外行,国内的805各方面比进口的好多了</P><>特别是栅流比进口的小一倍,推动更容易</P><>傻冒老外才不知道中国参数是和他们的不一样的呢</P><>管子爆炸倒是不会,烫伤的话那电热器等之类都不要用了,人都是有本能的,应该注意安全</P><>不过你的管子电气安全倒确实要注意,所以我不用带帽子的805</P>
582 点
77 ¥
发表于 2006-4-10 16:23 | 显示全部楼层
[B]以下是引用[I]土八路[/I]在2006-4-10 15:51:00的发言:[/B][BR]<><FONT face=Verdana size=2>Julien版主!help me!</FONT></P><><FONT face=Verdana size=2>那个老外如此评价曙光管,气愤啊!不过,他提到的安全问题的确发人深思,不光是高压的问题,还有爆炸的可能!我还要采取什么措施啊?</FONT></P><><FONT face=Verdana size=2></FONT> 他的答复如下:</P><><FONT face=Verdana size=2>tubalu,<BR><BR>You certainly are not overheating 805's with only 85 watts PD. Yes, it must be a photohgraphic effect we see.<BR><BR>I have had good luck with my limited experience with Shuguang tubes. The 805's I tried that got a bit red were Shuguang and they sounded good. I have no need to purchase any other 805's as I am fortunate to have 6 pairs of old stock American type 805's (i.e. RCA, Westinghouse, GE) as ready spares.<BR><BR>It is up to you to provide a safe environment in your home. All I can do is urge you to reconsider the safety hazard that an open transmiting tube can pose in a home environment. That large, very hot tube could explode if water dripped on it, or burn someone, or electrocute anyone touching tube cap. Accidents happen and in this case can be prevented. Death is permanent.</FONT><BR></P>[em09][em09]
还好你没有在那里用李向阳地头像,要不估计要被攻击了
[em31]
582 点
77 ¥
发表于 2006-4-10 16:19 | 显示全部楼层
加网罩试试看  (菜鸟之言)<BR/> <BR/>八路你要给我平反了 我也是做了好事<BR/>
<BR/>还有八路不要气垒 只是安全问题 可没有说机器不好  宽心<BR/>
158
超级贵宾 当前在线
打鬼子的
7494 点
2576 ¥
元老级 super 贵宾
 楼主| 发表于 2006-4-10 15:51 | 显示全部楼层
582 点
77 ¥
发表于 2006-4-10 13:20 | 显示全部楼层
<BR/><BR/> 这些壳子还是有能力作的 老外作的机壳是有一套的 BWT:死八路是要打pp的
582 点
77 ¥
发表于 2006-4-10 13:16 | 显示全部楼层
[B]以下是引用[I]土八路[/I]在2006-4-9 22:33:00的发言:[/B][BR]<>晕!Toolbook把我的805贴上去了~</P><>老外回帖说要我注意安全!加个罩子才好!</P>
好好都是我不对 我错了还不行
829 点
8 ¥
发表于 2006-4-10 08:59 | 显示全部楼层
网址呢?俺也过去溜达溜达.
473 点
170 ¥
发表于 2006-4-9 23:14 | 显示全部楼层
受益非浅.
158
超级贵宾 当前在线
打鬼子的
7494 点
2576 ¥
元老级 super 贵宾
 楼主| 发表于 2006-4-9 22:33 | 显示全部楼层
248
5361 点
4066 ¥
发表于 2006-4-9 22:21 | 显示全部楼层
<>他们的外观造型就非常有创意</P>
<>老外把DIY当作一种休闲方式</P>
<>文化差异</P>
292
nostalgia
19692 点
12949 ¥
发表于 2006-4-9 22:18 | 显示全部楼层
我常去,就是潜水,老外水平不咱滴
158
超级贵宾 当前在线
打鬼子的
7494 点
2576 ¥
元老级 super 贵宾
 楼主| 发表于 2006-4-9 22:08 | 显示全部楼层
你忽悠我!
[B]以下是引用[I]小鬼头[/I]在2006-4-9 21:59:00的发言:[/B][BR]<>DIYAUDIO的胆坛我很少去。不过我注意到那里有一些高手,对胆的特性等等很熟悉。</P>
一路上还看到你不少帖子呢!还有WD40的!
[em03][em03]
109
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
发表于 2006-4-9 21:59 | 显示全部楼层
158
超级贵宾 当前在线
打鬼子的
7494 点
2576 ¥
元老级 super 贵宾
 楼主| 发表于 2006-4-9 21:28 | 显示全部楼层
92 点
43 ¥
发表于 2006-4-16 18:22 | 显示全部楼层
GMT+8, 2026-5-25 13:04 , Processed in 1.098177 second(s), 10 queries , Gzip On, Redis On.
