308
无声胜有声
5862 点
4909 ¥
发表于 2009-1-18 21:36 | 显示全部楼层
30对铜壳的11032/33
入了那么多啊!装什么机器那么厉害!
我也很喜欢用这管的,我现在用的仿音乐传真A120.2就用了4对这管,电流一对管1.35A!
4884 点
4501 ¥
发表于 2009-1-18 21:39 | 显示全部楼层
学习中..................
全能选手
400 点
358 ¥
发表于 2009-1-18 21:41 | 显示全部楼层
老郑可以试试把推动管省掉,也许又是另一种感觉呢。
2857 点
2785 ¥
发表于 2009-1-19 06:35 | 显示全部楼层
the basic topology bears zero resemblence to Luxman's typical topology. However, if you take a look at Hafler's trans-nova amps and you will see a much better designed amp than this one.
a few mistakes:
a) the designer obviously doesn't understand how the transconductance portion of the VAS works. D14 is actually another A970 - they form a current mirror. As such, R47 = R49.
b) once you figure that out, you will understand why R22=R45.
c) the cascoding makes a lot of sense for Hafler because the VAS is driving mosfets (high Ciss). since you are driving a medium power bjt in a 40v rail application, you don't get much benefit out of the cascoding.
开机十分钟以后,电流穿升到600MA!最后稳定在650MA左右不再上升,看来可以了。为了试验一下温补管子的工作效果,搬过来一个电风扇,用最强档对着散热器吹,同时用表量输出静态电流,随着散热器的温度的降低,电流也在逐步降低,等到散热器冰凉,电流也回到了冷态的150MA左右。
that should have convinced you that the Vbe multiplier is NOT working right - it is under-compensating the thermal impact.
专家
2087 点
2014 ¥
新人进步
发表于 2009-1-19 08:20 | 显示全部楼层
试听怎样?
492 点
8 ¥
发表于 2009-1-19 09:45 | 显示全部楼层
实习生
7300 点
7049 ¥
DIY大赛冠军
发表于 2009-1-19 12:24 | 显示全部楼层
用669/649也可以,把管子反面固定散热器,电流在10MA左右反面固定没问题的,管子不会过热的
没精力搞了
2289 点
2292 ¥
发表于 2009-1-19 12:30 | 显示全部楼层
又见好板了
3599 点
2800 ¥
发表于 2009-1-19 20:11 | 显示全部楼层
hao好 !
2857 点
2785 ¥
发表于 2009-1-20 02:51 | 显示全部楼层
here is the basic Hafler trans-nova topology. I have highlighted those parts that you didn't get right in the attached schematic.
hopefully that will help you correct those design mistakes.
ciao.
75
实习生
7300 点
7049 ¥
DIY大赛冠军
发表于 2009-1-20 12:56 | 显示全部楼层
我的也要上电了,有点怕啊,快过年了,不想放烟花啊
HI-FI菜老大
1058 点
1050 ¥
发表于 2009-1-20 21:14 | 显示全部楼层
半铜半铁交织出的声音不知如何。
108
6175 点
5017 ¥
论坛贵宾 乐于助人
 楼主| 发表于 2009-1-23 23:28 | 显示全部楼层
原帖由 millwood 于 2009-1-19 06:35 发表
a few ...
你是说,R22和R45还有R47和R49是上下臂应该是对称的,我直接改成680欧的话,会造成上下臂电流不对称?
第一级R46为68K,R48为10K,比值为6倍,电流太小,靠反馈60倍放大倍数来提高增益?不是靠大电流来驱动?
但是我这样安装下来,末级电流调不起来,声音还很烂。
还有,我的E文实在很差,您说的我只能看一个大概,80年代中旬我就参加工作了,以后就一直没有系统的学习过E文。只是大概的看着多了,李逵李鬼差不多。
108
6175 点
5017 ¥
论坛贵宾 乐于助人
 楼主| 发表于 2009-1-23 23:45 | 显示全部楼层
最后定型了,就按照这个改动,推动管子用669/649就很不错,比15030/31声音个细腻,还原更真实一些,虽然韵味少了一些,用667/647也可以,不过负载电阻就需要增加到330欧左右。
声音吗,我的这种做法和原机的设计原则不一样,结果也有些不同。不过总的来说,这个电路的声音不错,厚实细腻,密度极佳,分析力也很高,低频力度和量感也足够称呼为(力士)。声音收放控制的很好。听交响乐也不错。
108
6175 点
5017 ¥
论坛贵宾 乐于助人
 楼主| 发表于 2009-1-23 23:54 | 显示全部楼层
原帖由 goldwayzhang 于 2009-1-20 21:14 发表
半铜半铁交织出的声音不知如何。
哪个是炮灰管子,调试完成了他们也就该下岗了!主要是我做电路烧管太多,呵呵!
108
6175 点
5017 ¥
论坛贵宾 乐于助人
 楼主| 发表于 2009-1-24 00:00 | 显示全部楼层
35楼图纸里面已经改正了一些错误,以这个最后的为准。末级用达林顿,推动管可以用647/667之类的小管子同时不用上散热,如果用669/649的话,管子需要反过来安装,背后金属面向上,有字的正面涂硅脂上散热器。用669的好处就是,末级就算用21194-15003-15025等管子,也能推得动,同时在小电流下效果也不错。性能最接近小功率管。
4254 点
4563 ¥
发表于 2009-1-24 00:27 | 显示全部楼层
刚入了30对铜壳的11032/33。。。。。真有钱啊。我用了几年才舍得花钱慢慢淘了4对。
2857 点
2785 ¥
发表于 2009-1-24 00:29 | 显示全部楼层
some suggestions for you to think about:
1) the current going through R15 is (6.1-0.7)/1k=5.4ma. it is a little bit high but not a big problem.
2) R46/R48 determines the clamping on the jfets. As designed, the jfet's sources are sitting at 22k/(47k+22k)*50v=15v. That is about right for a typical jfet.
3) R49 and the resistor in serial with the diode are too high. those Re resistors exist to just balance out the unmatched parameters in a current mirror. They are typically 11 - 110ohm, and rarely above 220ohm: for a current mirror to work, you have to have high gains here. I would set them at 22ohm - 47ohm.
4) R35 / R27 determines the open loop gain only when they are sufficiently small. At 100k, those two resistors are essentally shorted by the Vbe multiplier and the output stage.
4) R35/R27 determines the idle current for the voltage amplification stage. you want the VAS to idle at about 10ma. that means R35/R27 = 1.4/10ma=140ohm.
5) that value yields a voltage drop of 3*0.7+10ma*60=2.8v on R45, or idle current of 2.8ma on R45. Which is roughly 50% of the current going through R15 -> your differential pair is balanced.
you are far better off developing a good understanding of how an amp works BEFORE attempting to modify it.
86 点
32 ¥
发表于 2009-1-24 00:48 | 显示全部楼层
学习,学习。
108
6175 点
5017 ¥
论坛贵宾 乐于助人
 楼主| 发表于 2009-1-24 01:06 | 显示全部楼层
原帖由 millwood 于 2009-1-24 00:29 发表
2) R46/R48 determines the clamping on the jfets ...
明白了!再次感谢一下老兄的热心指点。
GMT+8, 2025-12-21 11:19 , Processed in 0.112303 second(s), 7 queries , Gzip On, Redis On.
