- 906
- 980 小时
- 2026-11-20
- 50
- 1026304
- 815
- 906 点
- 718 ¥
- 2023-2-15
楼主 |
发表于 2026-4-29 10:37
显示全部楼层
he name, "Pleci" is a popular bird name in Indonesia, with a small physique but the chirp is very melodious and shrill. Just as the name suggests the Class D UcD Pleci discrete power amplifier also produces detailed sound and high freq can come out clearly and softly, like class AB.
Later I will compare the sound of this power amplifier with the power amplifier chip class AB LM1875 which is famous for its performance which is also very good. And this Class-D amplifier has the potential to achieve a class of LM1875 amplifier chip sound, but with high efficiency (One of the advantages of class-D amplifiers).
In the finished circuit image, I mix it with Discrete Op-Amp, so that the sound produced will be more natural. Discrete Op-Amp The quality is approximately equivalent to the Op-Amp chips for $ 25 USD. So, it will make this class D amplifier more classy and luxurious in terms of sound. Later I will update the assembly and test video. This class D amplifier is recommended for indoor use. Unlike other class D amplifiers which are focused on SPL only, but this class-d discrete amplifier is focused on the use of HiFi Home Audio. so don't expect to get an amplifier power above 500W RMS. Following the discrete power amplifier D class UcD Pleci scheme, this circuit diagram I re-scheme in the EasyEDA online application.
o use the power supply, it needs symmetrical voltages ranging from 30VDC - 60VDC, for maximum performance the minimum supply is 45VDC 10A. In the above class d power amplifier circuit, I have added DC Protection, Signal Indicators, and fuses on the main power supply.
Does this amplifier still need an external 12V DC bias voltage?
The answer is yes, because besides I use to supply DCP circuits and Speaker delay I use 12V voltage, and also used to supply mosfet driver voltages. This PWM amplifier speed without changing the component value, the speed is above 350kHz. So you can maximize clarity and high tone detail.
Then, can this power amplifier be used for a subwoofer?
The answer is very, very good, and even better, because it can be more detailed voice not only for mid and hi.
What is the LPF value?
For inductors, you can use a 15-22uH inductor, you can use a 3.3cm MS130 core or use a T-130 core or use a shielded inductor like I used, the RM12 core.
Op-amps can use dual discrete op-amps or use Op-Amp ICs, there are 2 alternatives namely DIP or SMD.
Related: loading
Here is a picture of the PCB Layout amplifier class D-UcD Pleci, this PCB Layout can also be downloaded in the Gerber format, and the download file also has a clearer scheme in PDF format.
