33 点
33 ¥
发表于 2010-3-20 15:18 | 显示全部楼层
看了心寒   我本来去买个5.1声道的名机
看来还是算了
宰相
64 点
64 ¥
发表于 2010-3-22 12:46 | 显示全部楼层
看了,过过隐.
550 点
547 ¥
发表于 2010-3-22 21:07 | 显示全部楼层
好贴,学习了。
74 点
74 ¥
发表于 2010-3-24 17:15 | 显示全部楼层
16# xtcqk1
支持! lz说的正是。。。。。。HIFI    是来听的。不是要看肚子有什么样子!  呵
74 点
74 ¥
发表于 2010-3-24 17:45 | 显示全部楼层
246# gdcd
当然!
74 点
74 ¥
发表于 2010-3-24 17:50 | 显示全部楼层
有些名机工艺似乎也比我好不到哪里去阿
谢谢提供资料
iop 发表于 2008-9-10 09:13
好不到哪去?  是什么好!!!!????
74 点
74 ¥
发表于 2010-3-24 18:08 | 显示全部楼层
好不容易全部看完了,结论只有一个,跳线好比桥,绕过河和上桥,大家自己选择吧!跳线没有什么不好的,非常合理啊!本人做机,跳线就是要使用的。关于焊点和飞线和铜箔的见解,那个简直就神学,不要迷信!
     名机 ...
jillking 发表于 2008-5-27 00:54
     神是可以吹出来的,呻吟可没法吹!
   能创造的是神,膜拜的是信徒!!  大家好好DIY吧。
-= Class A Fans =-
1551 点
1381 ¥
发表于 2010-3-24 19:47 | 显示全部楼层
Jungson JA-99D Fully Balanced Class A (100w/ch) Integrated Amplifier
Features:
Jungson's unique Class A fully symmetric and non-negative feedback and fully Balanced output design
Enormous 100W Class A output power
(1) set of Balanced (XLR) and (3) sets of un-balanced (RCA) inputs
(2) sets of speaker binding posts
Brand name components throughout: including High-Class 500,000 uF filter capacitors (Japan), 22uF couple capacitors (Japan), Sanken semiconductors - 12 pairs (Japan), and Jensen cabling (Denmark)
Jungson's 680 VA patented low noise square transformer
Beautiful blue LED front meters that can be turned on/off as you wish
Stepped high bandwidth volume control with multi function remote control
Specifications:
Power: 100W per channel (Class A, RMS 8 Ohms), 200W/4 Ohms
THD:< 0.05% (1 kHz/1W)
S/N ratio: > 100 dB
Frequency response: 20 Hz - 20 kHz (± 0.5dB)
Input impedance: 100k Ohms
Output impedance: 4-8 Ohms
Color: Black aluminum casing + Black aluminum front panel
Size (LxWxH): 18.5" D x 16.9" W x 7.5" H
Weight: 47 kg / 104 lbs
-= Class A Fans =-
1551 点
1381 ¥
发表于 2010-3-24 20:00 | 显示全部楼层
Shengya PSM-600 monoblocks
Shengya PSM-600 monoblocks are constructed with 48 high performance transistors, 3000 watts shielded transformers, 240,000 uF filter capacitors and huge aluminum heat sink for each channel.
Features:
Biasing meter is installed on front panel for users to easily observe performance
Class A or Class A/B switch button
Bi-wiring speaker connectors
1 set RCA / 1 set XLR inputs
Specifications:
Frequency response: 20Hz - 20kHz +/-0.5dB
Output power: 600W (8ohm) and 1200W (4ohm) RMS
Class A output power: 150W (8ohm)
THD: <=0.1% (1kHz, 1W)
Input sensitivity: 1.7V
S/N: 90 dB
Input Impedance: 47kohm
Size: 20" W x 22" D x 12" each
Weight: 80kg / 176 lbs each
-= Class A Fans =-
1551 点
1381 ¥
发表于 2010-3-24 20:22 | 显示全部楼层
A-534B Performance Pure Class A SET Integrated Tube Amp (300B)
Specifications:
Output Power: 10W RMS/channel Pure Class A
Output Impedance: 4 ohm and 8 ohm
Frequency Response: 5Hz - 50 KHz (-2dB)
Distortion: less than 1.5% @ 6.5 W
Input Impedance: 20Kohm
Input Sensitivity: 280mV
S/N Ratio: 88dB
Vacuum Tubes: Shuguang 300B x 2, EL34 x 2, 12AX7 x 2, 5U4G x 1.
Features:
Pure Class A Triode single ended
Hand built audiophile output transformers with Japanese silicon steel
Audiophile grade resistors, capacitors throughout and Japanese original ALPS volume Control
Infra-red aluminum remote control for volume and input Selector
(4) auxiliary inputs plus 4 & 8 ohm large speaker terminals
Dual mono tube rectified choke input power Supply for the ultimate voltage control and super fidelity
Headphone Jack for 32 ohm tabbed off 300B circuitry
Weight: 28 kgs / 62 lbs
333 点
610 ¥
发表于 2010-3-27 11:25 | 显示全部楼层
外国名机反映出一个PCB设计理念:电路图的电气性能优先!材料够用就好!工作状态调试到位!拥有雄厚实力的厂家不会连做个PCB板的水平都赶不上业余烧友的水平吧?是对放大器内涵的理解和设计理念及东西方文化习惯的差异表现。一句话:用黄金做的坦克价格最昂贵,但是绝对不是廉价钢铁坦克的对手!
376 点
370 ¥
发表于 2010-3-27 18:54 | 显示全部楼层
楼主应该是专业修理功放的吧?
以前我也是修理功放的,见过很多名器!
929 点
743 ¥
发表于 2010-3-27 23:05 | 显示全部楼层
什么时候Jungson、Shengya也成名机了?不解。。。。
100 点
100 ¥
发表于 2010-3-29 11:18 | 显示全部楼层
参观。。。。
1336 点
1322 ¥
发表于 2010-3-29 16:12 | 显示全部楼层
我也来凑下热闹
杀手
46 点
66 ¥
发表于 2010-3-29 22:57 | 显示全部楼层
都是些好东东丫!
205 点
198 ¥
发表于 2010-3-31 08:46 | 显示全部楼层
不管用啥材料,好声技术才算高!
538 点
536 ¥
发表于 2010-3-31 19:54 | 显示全部楼层
好不容易看完了,很好!很好!
搭棚一族
250 点
320 ¥
发表于 2010-4-1 00:06 | 显示全部楼层
大开眼界
13 点
13 ¥
发表于 2010-4-1 03:17 | 显示全部楼层
2# xtcqk
哇噻   有严重的感觉
GMT+8, 2026-5-23 23:23 , Processed in 0.118243 second(s), 7 queries , Gzip On, Redis On.
