77 点
7 ¥
发表于 2005-6-22 01:21 | 显示全部楼层
请问哪位师傅有MF14万用表的图纸,我的表坏了想参考修一下。谢谢!!!
209 点
74 ¥
发表于 2005-6-23 12:49 | 显示全部楼层
言重了,举手之劳,希望对你有帮助,早日修好
77 点
7 ¥
 楼主| 发表于 2005-6-23 12:41 | 显示全部楼层
谢谢ytlun!!!!!
忠心的谢谢你,谢谢你的MF14图纸,这图对我太重要了,再次感谢你!!!!!
209 点
74 ¥
发表于 2005-6-22 18:30 | 显示全部楼层
<img src="attachments/dvbbs/2005-6/2005622182929774.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-6/2005622182929774.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-6/200562218294251.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-6/200562218294251.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-6/2005622182951104.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-6/2005622182951104.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-6/200562218295820.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-6/200562218295820.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
209 点
74 ¥
发表于 2005-6-22 17:39 | 显示全部楼层
有 迟些上图
109
论坛版主
8012 点
1636 ¥
元老级 社区贡献 优秀设计
发表于 2005-6-22 12:21 | 显示全部楼层
MF14的图纸比较难找....
我也在找....
这表是电工专用表.品质非常高,厚重可靠.用于电子上略感不便,主要是电压档内阻低,以及没有高阻欧姆档.
其实,只要表头不坏,不用图纸也可以通过计算电阻等,来修复指针万用表的...
这是我前几天在胆艺轩简单介绍的方法:
小鬼头
级别:网虫
经验:
魅力:
财富:69 Y元
总发贴数:36篇
停留时间:35 分
  搜索  查看  IP地址  QQ  邮件    回复此帖
指针式万用表的基础是最灵敏的那个电流档(普通数字表则是200MV档)。其它档都是以它来扩展的。若所用档不准
主题:指针式万用表的基础是最灵敏的那个电流档(普通数字表则是200MV档)。其它档都是以它来扩展的。若所有档不准,必须先检查这一档。
此贴在 2005-06-15 23:54:48 由 小鬼头 修改
编辑   05-06-15 23:54
小鬼头
级别:网虫
经验:
魅力:
财富:69 Y元
总发贴数:36篇
停留时间:35 分
指针表多是在原来直流电压档的基础上扩展成交流电压档,而直流电压档(及电阻档)又扩展自最灵敏的那个电流
主题:指针表多是在原来直流电压档的基础上扩展成交流电压档,而直流电压档(及电阻档)又扩展自最灵敏的那个电流档。因此,遇到电表不准时,按反向顺序检查,即先电流档、后直流电压档。你这里是250V交流,那么在检查完50UA档后,就要检查250V的直流电压档——检查方法很简单,用数字万用表电阻档接这个表笔两端进行检查,量一量表的内阻对不对——正确的表内阻可计算得到:表面上一般显示有“20K欧姆/V”之类的,那么内阻250VX20K欧姆=5M欧姆(电阻档也可用这种方法来检查,不过稍繁一点,在此不述)。若内阻不对,那么就用此法再检查低一级的直流档。。。再对照看看电路图,可以很快就找到有问题的电阻。若果内阻正确,基本可以确认直流电压档无问题,那么检查范围就缩小至交流档所特有的那少数几个元件(二极管及其附近的)。。。这些应该够你查的了。
此贴在 2005-06-16 23:22:03 由 小鬼头 修改
http://www.bbs01.com/add.php?forum=2&style=1&titid=279959
GMT+8, 2026-5-25 09:03 , Processed in 0.289805 second(s), 11 queries , Gzip On, Redis On.
