- 2911
- 4718 小时
- 2024-5-17
- 100
- 819376
- 2933
- 2911 点
- 2853 ¥
- 2016-9-6
附:DAC芯片分类
Burr-Brown: Multibit:
PCM51, PCM52 – 16-bit predecessors PCM53, a ceramic package (PCM53的陶封版)
PCM53 16-bit, one of the old, but good (1983-86 years), with a parallel input(早期版本,但是不错,并联输入)
PCM54 16 bit multibitnik normal (slightly older PCM56), parallel input(比PCM56老,并联输入)
PCM55 16 bits, the same as the PCM54, only in a small SOIC package(小体积封装版本PCM54)
PCM56 16 bit, normal quality multibitnik(一般质量)
PCM58 18-bit, a very good DAC(非常好的DAC)
PCM61 18-bit, the quality of a PCM56, but 18-bit(质量与PCM56一样,但是18bit)
PCM63 20-bit, one of the best of the world’s Audio (世界顶级)
PCM64 18-bit, one of the best, with a parallel input(最好的DAC之一,并联输入)
PCM65 – one of the best, most expensive and rare multibitnikov, with parallel input(最好的DAC之一,最贵的,罕见的,并联输入)
PCM66 16-bit DAC-2 and, huddled in a single housing, the quality – so so(一般般)
PCM67 hybrid (multi + one-bit), 2 DACs and in one case (stereo)(多比特加一比特)
PCM69 hybrid (multi + one bit), the same as the PCM67(多比特加一比特,与PCM67一样)
PCM1700 18-bit, 2-DAC and in one case (stereo), the quality level PCM61(与PCM61差不多的音质)
PCM1701 18-bit, one of the best, the successor technology PCM58(最好的DAC之一,PCM58版本最成功的技术)
PCM1702 20-bit, the quality just below the PCM63 (略输于,仅次于PCM63)
PCM1704 20-bit, the same as the PCM1702,(与PCM1702相同,支持24bit数据流,转换精度依然是20bit)
but only able to accept 24-bit stream (converting all the same 20-bit)
Burr-Brown Single-bit:
PCM1600 / 1601, cheap
PCM1607, cheap
PCM1710, normal odnobitnik
PCM1715, cheap
PCM1716, cheap odnobitnik receiving 24bit/96kGts.
PCM1723, cheap
PCM1728 odnobitnik receiving 24bit/96kGts.
PCM1732 is more or less of the one-bit
PCM1738 is more or less of the one-bit, slightly better PCM1732
PCM1792 – newer odnobitnik series of 24/192
PCM1794 – best of odnobitnik PCM1792-PCM1798 (from a series of 24/192)
PCM1796, PCM1798 – latest odnobitniki, the quality is lower than the PCM1792
Philips:
TDA1540 14-bit old multibitnik (1982-1986.), Very musical(旧的飞利浦多比特芯片,非常有音乐感(看起来毛毛东和十年解码老烧的听感还不错))
TDA1541 16-bit is a very good multibitnik, stereo(非常好的多比特芯片)
TDA1541A 16 bit – “improved” TDA1541 – good multibitnik(1541优化版)
TDA1541A R1 16-bit – the version with the worst differential nonlinearity than ordinary (较差的差分线性)
TDA1541A TDA1541A S1 16 bit – one of the best filipsovskih multibit (最好的飞利浦多比特芯片)
TDA1541A S2 16 bit – one of the best filipsovskih multibit(最好的飞利浦多比特芯片)
TDA1543 16-bit, two channels in one, simple and cheap(双通道DAC,简单便宜)
TDA1545 16-bit, low-cost(廉价)
TDA1547 aka – DAC 7, one of the best single-bit filipsovskih(最好的飞利浦单比特芯片)
TDA1549 1 bit, the average size odnobitnik BitStream
TDA1305 1 bit, the usual odnobitnik, parameters worse than TDA1549 (比TDA1549更差的参数)
SAA7321 1 bit, the average odnobitnik
SAA7323 1 bit, the average odnobitnik
SAA7341 1 bit cheap chip “all-in-one”
SAA7350 1 bit, the usual Delta-Sigma, could be put together with TDA1547 and is itself
Analog Devices: Multibit:
AD1851 16-bit, cheap multibitnik(便宜)
AD1856 16-bit, multibitnik average, more coldly detailed analog PCM56(比PCM56冷一点,信息量大一些)
AD1860 18-bit, good multibitnik(不错的多比特DAC)
AD1861 18-bit, multibitnik, analog PCM61, but slightly worse than the AD1860(与PCM61相似,比AD1860差一点点)
AD1862 20-bit – one of the best of the world’s Audio(世界顶级)
AD1864 18-bit, good multibitnik, 2 DACs and in one case (stereo)(不错的双通道多比特芯片)
AD1865 18-bit, very good multibitnik, 2 DACs and in one case (stereo)(非常棒的多比特双通道芯片)
Analog Devices Single-bit:
AD1852 1 bit, the average odnobitnik without current output (voltage only)
AD1853 1 bit odnobitnik good, one of the best one-bit from Analog Devices
AD1854 1 bit cheaper
AD1855 1 bit
AD1955 1 bit odnobitnik good, one of the best one-bit from Analog Devices
UltraAnalog:
D18400 – 18 bits – a hybrid micro-set in the factory hand, the precursor D20400
D20400 (D20400A) – 20-bit – one of the best of the world’s Audio
NPC:
SM5860 – normal odnobitnik
SM5861 – normal odnobitnik
SM5864 – good odnobitnik
SM5865 – very worthy odnobitnik the best at Nippon Precision Circuits
SM5872 – normal odnobitnik
SM5874 – cheap odnobitnik
Crystal Semiconductor:
CS4303 – One of the best single-bit
CS4327 – 1 bit
CS4328 – good odnobitnik
CS4329 – 1 bit
CS4334 – 1 bit
CS4390 – cheap odnobitnik
CS4391, CS4392 – a little more than new, 1 bit
CS4396, CS4397, CS4398 – the latest from Crystal odnobitniki
Sanyo:
LC7880 – 16-bit DAC old hybrid, stereo
LC7881 – 16-bit DAC old hybrid, stereo
LC78820 – 18-bit, the old hybrid DAC, a stereo
Sony:
CX20017 (aka CX890) – the oldest DAC s (1982 to 1985). Applies without oversampling
CX20152 – 16-bit – the old, but normal in quality DAC double integration
CXD2529 – 1 bit cheaper
CXD2552 – 1 bit – one of the best Sonevskih odnobitnikov
CXD2561 – 1 bit cheaper
CXD2562 – 1 bit – one of the best Sonevskih odnobitnikov
CXD2565 – 1 bit
CXD2587 – 1 bit cheaper
CXD8505 – 1 bit cheaper
CXD8567 – 1 bit
CXD8735 – 1 bit
Toshiba:
TC9219 – 1 bit TC9237 – 1 bit TC9268 – 1 bit
TD6705 – 16 bit TD6709 – 16 bit TD6710 – 14 bit TD6711 – 16 bit TD6720 – 16 bit
Panasonic:
AN6806 – 16-bit, one of the first from Matsushita, but good quality
MN35500 – 1 bit cheaper MN35511 – 1 bit cheaper
MN6471 – 1 bit, MASH (4 built parallel DAC-a)
MN6472 – 1 bit, MASH (8 built parallel DACs)
MN6474 – 1 bit, MASH (4 built parallel DAC-a)
MN64731 – 1 bit, MASH – | MN64733 – 1 bit
MASH | MN64735 – 1 bit, MASH |> are the best of the single-bit Panasonic MN6476 – 1 bit
MASH | MN64761 – 1 bit
MASH _ | MN66271 – 1 bit, cheap, chip “all-in-one”
MN662713 – 1 bit, cheap, chip “all-in-one”
Pioneer:
PD2026 – 1 bit cheap, the sound is not so hot
PD2028 – 1 bit, the best of the single-bit Pionerovskih, without built-Legato Link
PD2029 – 1 bit, cheap odnobitnik with built Legato Link
PD7007 – 1 bit, the average odnobitnik, without built-Legato Link
PE8001 – 1 bit for rebadging Pioneer Burr-Brown PCM1716
Wolfson:
WM8716 – Delta-Sigma, supports 24/192, no current output (voltage only)
WM8740 – Delta-Sigma, supports 24/192, no current output (voltage only)
WM8741 – Delta-Sigma, supporting 24/192 with selectable digital filters.
Yamaha:
YM3015 – old, simple YM3020 – 16 bit floating point
YDC103 – 1 bit, the sound is not so hot, the chip “all-in-one” YM7141 – 1 bit, the sound of the average
YAC501 – 1 bit, a new standing in the upper pits YAC506 – 1 bit, a new standing in the upper pits
YAC507 – 1 bit newer, considered the best in Yamaha odnobitnikom
YAC514 – 1 bit, a new sound medium
Grade: “L” – the lowest (Low) – worse than no grade
“J” – selected to be better than bezgreydovy
“K” – selected to be the best in quality (better than “J”)
————– http://vasiltech.nm.ru
补充内容 (2018-11-11 16:11):
转发的。 |
