5593 点
5531 ¥
发表于 2014-7-10 01:12 | 显示全部楼层
5428 点
5303 ¥
发表于 2014-7-10 03:16 | 显示全部楼层
官方说明:三分
Project everest DD67000
© 2012 HARMAN International Industries, Incorporated. All rights reserved.
JBL, Bi-Radial and SonoGlass are trademarks of HARMAN International Industries, Incorporated, registered in the United States and/or other countries. The “Hear the truth” logo is a trademark of HARMAN International Industries, Incorporated.
Features, specifications and appearance are subject to change without notice.
8500 Balboa Boulevard, Northridge, CA 91329 USA
www.jbl.com
What’s included:
• 1 JBL Project Everest DD67000 three-way,
floorstanding speaker
• 4 floor spikes
Specifications
• Speaker type: three-way floorstanding
• Low-frequency transducer: Dual 15" (380mm) three-layer,
pure-pulp sandwich/foam core cone woofer
• High-frequency transducer: 4" (100mm) pure-beryllium
compression driver
• Ultrahigh-frequency transducer: 1" (25mm) pure-beryllium
compression driver
• Maximum recommended amplifier power: 500 watts
• Frequency response (–6dB): 29Hz – 60kHz (half space);
45Hz – 60kHz (anechoic)
• Nominal impedance: 8 ohms
5.0 ohms @ 80Hz
3.0 ohms @ 40kHz
• Sensitivity: 96dB (2.83V/1m)
• Horn directivity (horizontal x vertical):
High-frequency: 100o x 60o
Ultrahigh-frequency: 60o x 30o
• Crossover frequencies:
150Hz (LF1 6dB/octave)
850Hz (LF2 24dB/octave)
20kHz (UHF 24dB/octave)
• Control functions:
HF level control (low, mid, high)
LF level control (low, mid, high)
LF/HF drive mode bars (normal/bi-amp)
System orientation bars (left/right)
• Dimensions (H x W x D): 38" x 43-5/8" x 18-1/2"
(965mm x 1109 x 469mm)
• Weight: 302 lb. (137kg) without grille
312 lb. (142kg) with grille
• Package weight: 383 lb. (174kg)
56
5428 点
5303 ¥
发表于 2014-7-10 03:20 | 显示全部楼层
人耳听不到的(20k一60K)比人耳听到的(29Hz/-6db)重要。
570
好的
1742 点
1529 ¥
发表于 2014-7-10 04:05 | 显示全部楼层
0分
56
5428 点
5303 ¥
发表于 2014-7-10 07:17 | 显示全部楼层
超高音,低端不应到850Hz,起码在5K甚至更高以上。中音头,整个工作区间太低了,不相信。而两个15寸低音,典型的专业型,不太可能工作在150Hz以下。850Hz、150Hz两点不太可信。
难道是:其一15寸在150一850Hz,号角在850一20K,超高在20K以上,那另一只15寸在150Hz以下?
坐等廿兄解答
5593 点
5531 ¥
 楼主| 发表于 2014-7-10 07:37 | 显示全部楼层
5428 点
5303 ¥
发表于 2014-7-10 08:22 | 显示全部楼层
果然是我说的难道?不小心去到4分频?
5593 点
5531 ¥
 楼主| 发表于 2014-7-10 08:52 | 显示全部楼层
5593 点
5531 ¥
 楼主| 发表于 2014-7-10 08:54 | 显示全部楼层
5428 点
5303 ¥
发表于 2014-7-10 09:43 | 显示全部楼层
20-20 发表于 2014-7-10 08:52
呵呵
E兄
你应该比我清楚的
我懒得搜,那号这么大,也不应低至850Hz。
56
5428 点
5303 ¥
发表于 2014-7-10 09:47 | 显示全部楼层
20-20 发表于 2014-7-10 08:54
这是什么意思呢?
呵呵,高频可至60K,而低频才到29Hz(-6db,还依靠反射加强)。该要的没,不需要那么高的刻意标出来。
5593 点
5531 ¥
 楼主| 发表于 2014-7-10 12:03 | 显示全部楼层
2439 点
2359 ¥
发表于 2014-7-10 13:00 | 显示全部楼层
DD66000的频响
2439 点
2359 ¥
发表于 2014-7-10 13:01 | 显示全部楼层
2439 点
2359 ¥
发表于 2014-7-10 13:02 | 显示全部楼层
49
新手上路 当前离线
.·°∴☆ 善解人衣☆..·°
Rank: 1
5513 点
3386 ¥
发表于 2014-7-10 13:16 | 显示全部楼层
20-20 发表于 2014-7-10 07:37
也有一种说法是:其一15寸在850Hz以下,那另一只15寸在150H以下。并由于兩只低音频宽不一样,而有严格的左右 ...
对,两个15寸负责的频率是不一样的。但还是算三分。
56
5428 点
5303 ¥
发表于 2014-7-10 13:19 | 显示全部楼层
王梓俊- 发表于 2014-7-10 13:00
DD66000的频响
谢谢呵。宁愿放弃灭鼠器,也要补回低频。
5593 点
5531 ¥
 楼主| 发表于 2014-7-10 14:41 | 显示全部楼层
2439 点
2359 ¥
发表于 2014-7-10 15:15 | 显示全部楼层
厂家说是用来把电容充电,减少切换冲击。
应该是这样吧
5593 点
5531 ¥
 楼主| 发表于 2014-7-10 15:50 | 显示全部楼层
