2045 点
1901 ¥
发表于 2014-6-26 16:52 | 显示全部楼层
SONY CDP-950 CD机显示屏先是亮度不对,后黑屏不亮了,播放CD和别的功能都还正常,请高手支招如何处理,先谢谢了。原来一个SONY CDP-991也是这样子,有高手支招高显示屏的供电不通,换了一个电阻R214,电路通了就好了。这次也请高手指点一下,950的黑屏和前次的故障一样,也可能是显示屏供电的问题吗?请指点是哪个电阻坏了屏供电又不通了呢?
2045 点
1901 ¥
 楼主| 发表于 2014-6-26 16:53 | 显示全部楼层
SONY CD机很多都会出这样的故障,高手把机器的供电部分DIY一下,以求一劳永益
2045 点
1901 ¥
 楼主| 发表于 2014-7-20 12:48 | 显示全部楼层
常见CD机光头、芯片对照表
A:
ACOUSTIC RESEARCH CD-07   SAA7220
ACCUPHASE DP85    AD1853    NJM4580
ACCUPHASE DP90   PCM63
ADC CD 250XR    PCM54
AKAI CD25/26/27/32/36    KSS210A
AKAI CD37   PCM67P KSS210A NJM4558
AKAI CD52    KSS210A
AKAI CD55    AD1856 KSS210A
AKAI CD57   PCM67PJ KSS210 CXD1167Q
AKAI CD62    BO38258J
AKAI CD650/70    KSS210A
AKAI CD69    PCM63   KSS210A
AKAI CD-A70    MB84053B   KSS123A//BO367214J
AKAI CD-M839    PCM56
AKAI CD79    KSS210A
AKAI CD750    KSS210A
AKAI CD73/93   PCM56 KSS155A(884806401)
ALBA CD420    PCM54
ALCHEMIST NEXUS APD32A    2x TDA1549
AMC CD60    PCM1716
AMC CD8A    MN6474 (Technics MASH)
ANTHEM CD1    PCM1702
ARCAM ALPHA 5    TDA1541   CDM9
ARCAM ALPHA 5 PLUS  TDA7310 SAA7220P/B TDA1541A   CDM9
ARCAM ALPHA 6    SM5864
ARCAM ALPHA 7    PCM1710
ARCAM ALPHA 7SE    PCM1716
ARCAM ALPHA 8    SM5864AP
ARCAM ALPHA 9 dCS    RingDAC
ARCAM CD72    PCM1716
ARCAM CD92 dCS    RingDAC
ARCAM DELTA 70.2   TDA1541-S1 cdm4/31
ARCAM DELTA 70.3     LM627
ARCAM DELTA 270    PCM69
ARCAM DELTA BOX 5    PCM67
ARYE CX-7    PCM1738
ARYE D-1    PCM1704
AUDIO ALCHEMY ENGINE v3.0   AD1862
AUDIO ANALOGUE MAESTRO    AD1855
AUDIO INNOVATIONS ALTO    PCM1716
AUDIO NOTE CD-1    PCM1710
AUDIO NOTE CD-2    AD1865
AUDIO NOTE DAC-3    PCM63
AUDIO RESEARCH CD1    SAA7341
AUDIOLAB 8000 CD    CS4329
AVI SC2000MC    PCM63
B:
BLAUPUNKT CP2650    PCM54
C:
CAMBRIDGE AUDIO CD1    TDA1541
CAMBRIDGE AUDIO CD2  SAA7210 SAA7220P/A 4xTDA1541   CDM2
CAMBRIDGE AUDIO CD3    TDA1541A
CAMBRIDGE AUDIO CD4SE    CS4327
CAMBRIDGE AUDIO CD6    TDA1305T
CAMBRIDGE AUDIO D500    CS4327
CARVER SD/A 450    MN6474
C.E.C. 530CD2    Y3015
C.E.C. 680CD    LC7881
CONDOR CD950    YM3020
COPLAND CDA277    PCM63
COPLAND CDA288    PCM63-K
CROWN CD2111R    LC7881
CYRUS CD7    PCM1716
CYRUS dAD1    TDA1311
CYRUS dAD3    TDA1305
CYRUS dAD3Q    AD1861
CYRUS dAD7    AD1861
D:
DENON DA-500    PCM1702
DENON DCD-315    NKS240A
DENON DCD-435    PCM1716E
DENON DCD-480    PCM61   NKS240A
DENON DCD-485    PCM1735
DENON DCD-500    PCM54   KSS123A
DENON DCD-520    KSS210A
DENON DCD-580    PCM67P   NKS240A
DENON DCD-590    PCM61
DENON DCD-600    KSS152A
DENON DCD-610/20    KSS210A
DENON DCD-615/25    NKS240A
DENON DCD-635    PCM61P
DENON DCD-650F    PCM1700P
DENON DCD-655    PCM1702
DENON DCD-660    KSS210A
DENON DCD-680    PCM69A
DENON DCD-685    PCM1702
DENON DCD-690    PCM61
DENON DCD-695    PCM61
DENON DCD-700    PCM54HP   KSS123A
DENON DCD-715    NKS240A
DENON DCD-725    PCM61P-L
DENON DCD-735    PCM61
DENON DCD-755AR    PCM1702
DENON DCD-800    PCM54   KSS152A
DENON DCD-810    KSS210A
DENON DCD-820    PCM56   KSS210A
DENON DCD-825    NKS240A
DENON DCD-860    KSS210A
DENON DCD-890    PCM61P   NKS240A
DENON DCD-895    NKS240A
DENON DCD-900    KSS123A
DENON DCD-910    KSS210A
DENON DCD-920    PCM61   KSS210A
DENON DCD-980    PCM61P   NKS240A
DENON DCD-1015    PCM61P   NKS240A
DENON DCD-1000    KSS123A
DENON DCD-1100    PCM53JP-V  KSS123A
DENON DCD-1290    NKS240A
DENON DCD-1300    KSS123A
DENON DCD-1400    PCM56
DENON DCD-1420    PCM54HP   KSS210A
DENON DCD-1450AR    PCM1702
DENON DCD-1500    PCM54HP-K   KSS123A
DENON DCD-1500mk2    PCM56 KSS151A
DENON DCD-1520    PCM64   KSS151A
DENON DCD-1530    PCM61
DENON DCD-1550R   PCM61
DENON DCD-1550AR    PCM61P
DENON DCD-1560    PCM1701
DENON DCD-1650R    PCM1702
DENON DCD-1700    KSS123A
DENON DCD-1800    PCM53
DENON DCD-2060G/80G    NKS240A
DENON DCD-2560    4x AD1862
DENON DCD-2700    PCM1702J
DENON DCD-S10/3000    PCM1702J
DENON DCD-3300    PCM56P-K   KSS123A
DENON DCD-3520    PCM64   KSS151A
DENON DCD-3560    PCM58P-K
DENON DCD-S1    PCM1702
DENON DCM-280    PCM1748
DENON RCD-100    PCM1710
DENON UCD-F10    PCM61
DENON DN-2000F    NKS240A
DIORA CD-502    TDA1543
DUAL CD130    CX20017
DUAL CD20    PCM53
E:
EXPOSURE CD    TDA1545A
EZO FOG STAGE3    AD1853
F:
FISCHER AD935    LC7881   SFP1
FISCHER Z1    PCM58   SFP1
G:
GRUNDIG CD103    LC7881
GRUNDIG CD9000    TDA1541A   CDM4.11(£95.00)
H:
HARMAN KARDON HD200    YM3020
HARMAN KARDON HD500    PCM53
HARMAN KARDON HD710   MN6474
HARMAN KARDON HD720    PCM1710
HARMAN KARDON HD730    SAA7350
HARMAN KARDON HD760    PCM1702
HARMAN KARDON HD7225    MN6474
HARMAN KARDON HD7300    PCM61
HARMAN KARDON HD7325    MN6474
HARMAN KARDON HD7400/7500    KSS210A
HARMAN KARDON HD7525    PCM61P
HELIOS MODEL1S    CS4328 (36 bit, ETNA)
HELIOS MODEL2S    CS4328 (36 bit, ETNA)
HELIOS MODEL3S    CS4328 (36 bit, ETNA)
HELIOS STARGATE    CS4328 (36 bit, ETNA)
HEYBROOK SIGNATURE    PCM67
HIGH TECH GOLDLINE CX904    YM3020
J:
JVC XL V22    PCM54   OPTIMA2
JVC XL V221    LC7881   OPTIMA5
JVC XL V250BK    PCM56   OPTIMA2
JVC XL V311BK    MN6471   OPTIMA4S
JVC XL V464    MN35500   OPTIMA6S
JVC XL V1100    PCM54   OPTIMA1
K:
KENWOOD DP47    TD6720N   KSS152A
KENWOOD DP87    KSS152A
KENWOOD DP460    TD6709N
KENWOOD DP660SG    KSS152A
KENWOOD DP730    KSS210A
KENWOOD DP850    CX20152
KENWOOD DP920/30/50    KSS210A
KENWOOD DP1030    KSS210A
KENWOOD DP1050    NKS240A
KENWOOD DP1060    RCTRH8136
KENWOOD DP1080    LC78620E
KENWOOD DP1100D    CX20152
KENWOOD DP1510    PCM56   KSS210A
KENWOOD DP2000    CX20152
KENWOOD DP2010    PCM56P   KSS210A
KENWOOD DP2030    KSS210A
KENWOOD DP2050    NKS240A
KENWOOD DP2060    RCTRH8136
KENWOOD DP2080    LC78620E (LC78820)
KENWOOD DP3010/30/50    KSS210A
KENWOOD DP3060    NKS240A
KENWOOD DP3080    SM5864
KENWOOD DP4030    KSS210A
KENWOOD DP4090    KAN03
KENWOOD DP5010/30/40    KSS210A
KENWOOD DP5020    PCM1701P   KSS210A
KENWOOD DP5090    MN35502 JVC
KENWOOD DP7002    PCM1702
KENWOOD DP7030    CXD2552   KSS210A
KENWOOD DP7040/50    KSS210A
KENWOOD DP7060    TDA1547
KENWOOD DP7090    8x PCM1702
KENWOOD DP8020    KSS152A
KOREA CHINA CD 022    KDA0316LN
KOREA HCD 630   Y3015
KRELL KAV280    PCM1704
L:
LINN GENKI    PCM1723
LUXMAN D 102    TD6709N
LUXMAN D 103    PCM1701
LUXMAN D 112    1x PCM56
LUXMAN D2 92    LC7881
M:
MARANTZ CD7    TDA1541AS2 (double crown)
MARANTZ CD10  SAA7310  TDA1547   CDM4/D36
MARANTZ CD11LE/II   TDA1547   CDM4/D36 HDAM
MARANTZ CD1010/20    CDM12.1
MARANTZ CD14    TDA1547   CDM12.1
MARANTZ CD15    TDA1547   CDM4-MD
MARANTZ CD16D  SAA7310  TDA1547    HDAM
MARANTZ CD17mkII  TDA1370  TDA1547(DAC7)  VAM1201 NJM2114/HDAM
MARANTZ CD19    SM5872
MARANTZ CD23    CDM9
MARANTZ CD273    CDM2
MARANTZ CD38    TDA1545   CDM12.1
MARANTZ CD385    CDM4
MARANTZ CD40  SAA7310 SAA7220 TDA1541/A   CDM4/19
MARANTZ CD42 SAA7310  SAA7350 ? CDM4//691.30209
MARANTZ CD42 II    CDM4
MARANTZ CD43    SM5872BS   CDM12.1/05 NJM4560
MARANTZ CD45    TDA1540   CDM2/29
MARANTZ CD46    CDM12.1
MARANTZ CD48    TDA1545//1549  CDM12.1
MARANTZ CD50    TDA1541 CDM4/19
MARANTZ CD52  SAA7310   SAA7321GP   CDM4
MARANTZ CD52SE SAA7310   SAA7350(Bitstream) CDM4 NE5532
MARANTZ CD53    SM5872BS   CDM12.1 NJM2114
MARANTZ CD56   TDA1541 CDM4/25
MARANTZ CD57/57 II    CDM12.1
MARANTZ CD583/93    CDM4/19
MARANTZ CD60   TDA1541 A CDM4/19 NE5534
MARANTZ CD63    SM5872BS   CDM12.1 HDAM
MARANTZ CD63II    SM5872   CDM12.1
MARANTZ CD63mkII KI    SM5872 CDM12.1
MARANTZ CD63SE    SM5872BS   CDM12.1
MARANTZ CD65 SAA7310  TDA1541   CDM4/25
MARANTZ CD65 II SAA7210 SAA7220B TDA1541 A  CDM4/19
MARANTZ CD67    SM5872 CDM12.1
MARANTZ CD67SE    SM5872   CDM12.1
MARANTZ CD67II OSE    SM5872 CDM12.1
MARANTZ CD72  SAA7310  SAA7350(Bitstream) CDM4/19
MARANTZ CD72mkII SE SAA7310  TDA1547   CDM 4/28//CDM4/19 HDAM
MARANTZ CD73 SAA7000/10 SAA7020 2xTDA1540 CDM1
MARANTZ CD74  SAA7000/10 SAA7020 2xTDA1540   CDM1
MARANTZ CD75    CDM4/25
MARANTZ CD75NB    CDM2-160
MARANTZ CD75XNB    691.20464
MARANTZ CD80   TDA1541   CDM1/mkII(CDM4.19) single opamps
MARANTZ CD84   TDA1540 CDM1
MARANTZ CD85    CDM1/mkII
MARANTZ CD94/mkII   TDA1541   CDM1
MARANTZ CD873    CDM2-0500//CDM4/11
MARANTZ CD883    CDM4/19
MARANTZ CD4000  SAA7378  TDA1545  VAM1201 NJM4560
MARANTZ CD5000  SAA7378  TDA1549   VAM1201 NJM4560
MARANTZ CD6000  SAA7378  SM5872   VAM1201 NJM2114
MARANTZ CD6000KI  SAA7372  SM5872BS   VAM1201 HDAM
MARANTZ CD6000OSE SAA7372  2xSM5872 VAM1201 HDAM
MARANTZ SA-12S1/SA14   CS4397  HDAM
MARK LEVINSON N'36    PCM1702 (vagy PCM1704)
MARK LEVINSON No. 390S    AD1853
MERIDIAN 508    CS4329
MICROMEGA LEADER    SAA7321GP
MICROMEGA LOGIC    SAA7321
MICROMEGA PREMIUM18 new  CS4327
MICROMEGA STAGE2    SAA7321GP
MICROMEGA STAGE6    TDA1305
MISSION dAC5    TDA1547
MISSION dAD3    TDA1305
MISSION PCM4000    TDA1541
MITSUBISHI DP109    PCM56
MITSUBISHI MC5100    PCM56
MUSICAL FIDELITY x-ray   PCM1716  NE5532
MUSICAL FIDELITY Tri-Vista   PCM1738  NE5532
MUSICAL FIDELITY A2   YDC103
MUSICAL FIDELITY DIGILOG    TDA1541
MUSICAL FIDELITY E60    YDC103
MUSICAL FIDELITY E624    PCM1716
MYRYAD T-10    CS4327
MYRYAD T-20    CS4327
MYRYAD MC100    CXD2565
N:
NAD 502    MN6474AM   KSS210A
NAD 510    SAA7350   CDM12.1
NAD 515    CDM12.1
NAD 512    MN6474   KSS210A
NAD 522    PCM1710
NAD 5100    PCM56
NAD 5325    LC7881
NAD 5425    MN6471M
NAD C520    PCM1710
NAD S500    CS4390
NAIM AUDIO CD1    TDA1541
NAIM AUDIO CD2    TDA1541
NAIM AUDIO CD3    TDA1541
NAIM AUDIO CD3.5    TDA1305
NAIM AUDIO CD5    TDA1305
NAIM AUDIO CDI    TDA1541AS1 (single crown)
NAIM AUDIO CDS11    PCM1702K
NAKAMICHI CD PLAYER 1    PCM1700P
NAKAMICHI CD PLAYER 4    AD1864N
NAKAMICHI MB 4    LC78840
NAKAMICHI MB 5    LC78840
NAKAMICHI CDP 2E    TDA1541A
NAKAMICHI OMS 1E    PCM56
NAKAMICHI OMS 4E    PCM54
NAKAMICHI OMS 5E    TDA1540
NAKAMICHI OMS 7E    PCM54
NEC CD610    PCM54
O:
ONKYO DX-704    MN6472 (Technics MASH)
ONKYO DX-6430    YM3020
ONKYO DX-6470    PCM56
ONKYO DX-6550 Integra    TC9219 (ONKYO 8D-3170-1)
ONKYO DX-6570    PCM58
ONKYO DX-6620    LC7881
ONKYO DX-7011    TC9237
ONKYO DX-7211    SM5874
ONKYO DX-7500    ONKYO 8S-3380-1
ONKYO DX-7711 Integra    SM5864AP
ONKYO DX-7911 Integra    SM5864AP
ORELLE CD100    TDA1541
P:
PARASOUND CD M839    PCM56
PARASOUND C/DP1000    PCM67
PHILIPS AK601/630/640/729/CCD310/320    CDM4/19
PHILIPS CD-80    TDA1541
PHILIPS CD-85M   TDA1541
PHILIPS CD-94M   TDA1541
PHILIPS CD-100    TDA1540  CDM0
PHILIPS CD-101   TDA1540   CDM1
PHILIPS CD-104    TDA1540   CDM0/CDM1
PHILIPS CD-115/130/140    CDM4/19
PHILIPS CD-150/1    CDM2/29
PHILIPS CD-160    CDM4/25
PHILIPS CD-162/4    CDM4/19
PHILIPS CD-163    CDM12.1/05
PHILIPS CD-200    TDA1540   CDM0
PHILIPS CD-202    TDA1540   CDM0
PHILIPS CD-204    TDA1540   CDM0
PHILIPS CD-210    TDA1543 CDM4/19
PHILIPS CD-210     CDM4/19
PHILIPS CD-300/303 SAA7210 SAA7020 2xTDA1540   CDM1
PHILIPS CD-304   TDA1540   CDM1
PHILIPS CD-304 MkII (alu chassis) SAA7210 SAA7220P/A TDA1541   CDM1
PHILIPS CD-310    CDM4/19
PHILIPS CD-340    CDM4/19
PHILIPS CD-350   TDA1541   CDM2/29
PHILIPS CD-360    CDM2 //CDM4/25
PHILIPS CD-371/3    CDM4/11
PHILIPS CD-380   TDA1543/1/1A CDM4/19
PHILIPS CD-410    CDM12.1/05
PHILIPS CD-460    TDA1541   CDM2 //CDM4/25
PHILIPS CD-465    TDA1541
PHILIPS CD-470
PHILIPS CD-471    TDA1541   CDM4/11
PHILIPS CD-472   TDA1541   CDM4/11
PHILIPS CD-473   TDA1541   CDM4/11
PHILIPS CD-480/2    TDA1543 CDM4/19
PHILIPS CD-500/2    CDM4/19
PHILIPS CD-560    CDM2 //CDM4/25
PHILIPS CD-581/2   TDA1541  CDM4/19
PHILIPS CD-583/4    CDM4/19
PHILIPS CD-586    CDM4/19
PHILIPS CD-600/4/5    CDM4/19
PHILIPS CD-610  SAA7310 SAA7220P TDA1541  CDM4/19
PHILIPS CD-604   TDA1543   CDM4/19
PHILIPS CD-614/15   TDA1543   CDM4/19
PHILIPS CD-618   Bitstream ? CDM4/19
PHILIPS CD-620   TDA1541 ?  CDM4/19
PHILIPS CD-621 SAA7345
PHILIPS CD-624   SAA7323 CDM4/19
PHILIPS CD-630  SAA7220P/B TDA1541  CDM4/19
PHILIPS CD-634   Bitstream ? CDM4/19
PHILIPS CD-640   TDA1541
PHILIPS CD-650  SAA7210 SAA7220P/A TDA1541   CDM2/29//CDM4/25
PHILIPS CD-660    CDM4/11
PHILIPS CD-670 SAA7210 SAA7220P/A TDA1541 CDM4/11//(69130212) LM833 slim size,
plastic case, SPDIF
PHILIPS CD-690   Bitstream ? RCD1.2D
PHILIPS CD-692   Bitstream ? CDM9/63
PHILIPS CD-710/720    CDM12.1/05
PHILIPS CD-723  SAA7378  TDA1545    VAM1201 NJM4560
PHILIPS CD-733/740    CDM12.1/05
PHILIPS CD-751  SAA7378  TDA1549   CDM12.1/05
PHILIPS CD-750 SAA7378  TDA1549   CDM12.1/05
PHILIPS CD-753  SAA7378  TDA1549    VAM1201 NJM4560
PHILIPS CD-771    CDM2-0500//CDM4/11
PHILIPS CD-780/1    CDM4/19
PHILIPS CD-782   TDA1541 CDM4/19
PHILIPS CD-820  SAA7220 TDA1541 A CDM4/19 LM833
PHILIPS CD-830    CDM4/19
PHILIPS CD-824/834    CDM4/19
PHILIPS CD-840   Bitstream CDM4/19
PHILIPS CD-850   TDA1541 CDM4/19 LM833
PHILIPS CD-880    TDA1541 S1  CDM1 mkII
PHILIPS CD-882    CDM1 mkII//691.20449
PHILIPS CD-883    CDM4/19
PHILIPS CD-910/11   SAA7341GP  (4822-691-20768) CDM12.1/05//RCD1.2D
PHILIPS CD-930/1    TDA1547   CDM9/44
PHILIPS CD-920/1    CDM12.1/05//RCD1.2D
PHILIPS CD-940    CDM9/44
PHILIPS CD-950    TDA1547   CDM9/44
PHILIPS CD-950/1    TDA1547   CDM9/44
PHILIPS CD-960    TDA1541  CDM1/mkII ??? NE5534
PHILIPS LHH-100    TDA1547
PHILIPS LHH-500    TDA1547
PHILIPS LHH-600    TDA1547
PHILIPS LHH-800    TDA1547
PHILIPS LHH-1000    TDA1541
PHILIPS MAGNAVOX CDB-560    TDA1541
PHILIPS MAGNAVOX CDB-650    TDA1541
PINK TRIANGLE NUMERAL   TDA1305T
PIONEER DV-717    PE8001A
PIONEER PD40S    PWY1010
PIONEER PD75    PD2028A
PIONEER PD93    PD2028A
PIONEER PD95    PD2028A
PIONEER PD-102/3    PEA1179
PIONEER PD-202/3    PEA1179
PIONEER PD-204    PD2026B
PIONEER PD-970    PEA1030
PIONEER PD-4050    PWY1010
PIONEER PD-4500    PCM1700   PEA1030
PIONEER PD-4700/5700/6500/67000/7700/8700    PEA1030
PIONEER PD-4550   PCM1700P   PEA1030
PIONEER PD-5100    PD0034   PWY1010
PIONEER PD-52    PEA1030
PIONEER PD-5300    PCM56   PWY1010
PIONEER PD-54    PEA1179
PIONEER PD-5500    PEA1030
PIONEER PD-5050    PWY1010
PIONEER PD-5700    PD2026A   PEA1030
PIONEER PD-6050/6100/6300    PWY1010
PIONEER PD-65/6500/6700    PEA1030
PIONEER PD-7050    PWY1010
PIONEER PD-7300    PCM58P
PIONEER PD-7300/7500/7700/8700    PEA1030
PIONEER PDR-04    AKM4321
PIONEER PDR-609    PCM1716
PIONEER PDR-W739    PCM1716
PIONEER PDR-W839    PCM1716
PIONEER PDS-06    PCM1702J
PIONEER PD-S303    PEA1030 NJM 4558/4580
PIONEER PD-S501    PEA1030 NJM 4558/4580
PIONEER PD-S502    PD2026B   PEA1179 NJM 4558/4580
PIONEER PD-S503    PEA1179 NJM 4558/4580
PIONEER PD-S505    PD2029A   PEA1030 NJM 4558/4580
PIONEER PD-S507   CXD2507aq PE8001A    NJM 4558/4580
PIONEER PD-S602/3    PEA1179 NJM 4558/4580
PIONEER PD-S601/701    PEA1030 NJM 4558/4580
PIONEER PD-S702    PEA1179 NJM 4558/4580
PIONEER PD-S703    PD2029A   PEA1179 NJM 4558/4580
PIONEER PD-S707    PEA1030 NJM 4558/4580
PIONEER PD-S801    PD2028
PIONEER PD-S802    PD0116A   PEA1179
PIONEER PD-S901    PD2028B   PEA1030
PIONEER PD-S909/990    PEA1030
PRIMARE D20    AKM4324
PRIMARE D302    4x PCM1702
PROCEED PCD2    PCM58P
PROTON AC423    LC78820
PROTON AC424    TDA1311A
Q:
QUAD66     TDA1541A
QUAD77     CS4328
R:
REGA PLANET    PCM1710U
REVOX B225    TDA1540
REVOX B226    TDA1541    NE5534
REVOX C221    SAA7310
ROKSAN ATTESSA DP3P    CS4328
ROKSAN CASPIAN    TDA1305
ROTEL RCD-02    PCM1732
ROTEL DCM-9PRO    PCM63
ROTEL RCD-855    TDA1541   CDM4/19
ROTEL RCD-856BX    SAA7323
ROTEL RCD-865BX    SAA7323
ROTEL RCD-945AX    SAA7341GP T
ROTEL RCD-955    TDA1541
ROTEL RCD-965BX    SAA7323GP T
ROTEL RCD-970BX    TDA1305T
ROTEL RCD-971    PCM63
ROTEL RCD-975    TDA1305T
ROTEL RCD-991    PCM63P
ROTEL RCD-1070    PCM1732
S:
SANSUI CD V1000    PCM56
SANYO CP489    LC7881
SEG CD200    YM3020
SHARP DX112    IR 3K16BM
SHARP DX650    LC7880
SHERWOOD CD1    TDA1547
SHERWOOD CD1060C    D6372 CX
SHERWOOD CD1160R    PCM56
SHERWOOD CD1192R    YM4113B
SHERWOOD CDC2000C    μPD6376
SHERWOOD CDC2010RC    μPD6376
SHERWOOD CD4030R    SAA7350BS
SIMAUDIO MOON ECLIPSE    4x PCM1704K
SONIC FRONTIERS SFCD1 UltraAnalog  D20400A
SONY CDP-25/356    KSS120C
SONY CDP-203/30/45/50/55/65/70    KSS121A
SONY CDP-40    1x PCM54
SONY CDP-101    CX20017
SONY CDP-222ES    PCM56P J
SONY CDP-227ESD    TDA1541
SONY CDP-228ESD    PCM58P   KSS151A
SONY CDP-302ES    CX20152
SONY CDP-333ESA    CXD2562
SONY CDP-333ESD    TDA1541
SONY CDP-333ESJ    CXD2562
SONY CDP-337ESD    2xTDA1541A
SONY CDP-497    CXD2561
SONY CDP-502    PCM54
SONY CDP-502ES    CX20152
SONY CDP-552    PCM54
SONY CDP-553ESD    PCM53JP-V K
SONY CDP-555ESA    CXD2562
SONY CDP-555ESD    TDA1541A
SONY CDP-555ESJ    CXD2562
SONY CDP-620   CX23034 PCM54
SONY CDP-650    PCM54
SONY CDP-701ES    CX20017
SONY CDP-777ESA    CXD2562Q
SONY CDP-M18 CXD2500Q CXD2554M  KSS240A
SONY CDP-MS1    CXD8594 + CXA8042AS
SONY CDP-R3 + DAS-R1a             CXD2552Q + CXD2552
SONY CDP-X229ES    CXD2562Q   NKS240A
SONY CDP-X3000    CXD2562Q + CXA8042AS
SONY CDP-X303ES    CXD2562Q
SONY CDP-X5000   CXD2515 CXD2562 + CXA8042
SONY CDP-X505ES    CXD2562Q
SONY CDP-X33ES    CXD2552Q
SONY CDP-X55ES    CXD2552   KSS270A
SONY CDP-X777ES    CXD2552BQ
SONY CDP-X779ES    CXD2562
SONY CDP-X77ES    CXD2552   KSS280A
SONY CDP-X7ESD    PCM58P S   KSS190A
SONY CDP-X900    CXA8042
SONY CDP-XA30ES    CXD2562Q + CXA8042AS   KSS160B
SONY CDP-XA50ES    CXA8042AS
SONY CDP-XA55ES    CXD8594Q + CXA8042S   KSS310A
SONY CDP-XA5ES    CXD2562Q + CXA8042AS
SONY CDP-XA7ES    CXD2562 + CXA8042AS
SONY CDP-XB920    CXD8715 + CXA8355
SONY CDP-XB720E    CXD8735N
SONY CDP-XB930    CXD8735N
SONY CDP-XE300    CXD8567
SONY CDP-XE330    CXD2529Q
SONY CDP-XE900    CXD8505 + CXA8055   KSS213B
SONY DAS-R1    4XTDA1541AS1 (single crown)
SONY CDX11/20/80/5B    KSS160B
SONY CDXA15/20/30    KSS160B
SOUND WAVE CD1100    LC7881
SUDGEN OPTIMA    TDA1543
SUDGEN SDA-1    TDA1541
SUDGEN SDT-1    TDA1541AS1 (single crown)
T:
T+A CD1210R    SM5864AP
TAG McLAREN CD20R    CS4329
TALK ELECTRONICS THUNDER 3   CS4390
TASCAM CD201    MN6474
TEAC PD155mk2    Y3015
TEAC PD160    TC9218F   9A01026600
TEAC CPD3450SE   YDC103LSI    OPAxx
TEAC CPD3100/4100    KSS210A
TEAC PD365   YM7121B
TEAC VRDS 7    TDA1547
TEAC VRDS 8    PCM1702
TEAC VRDS 9    PCM1702
TEAC VRDS 10SE    TDA1547
TEAC VRDS 25    AD1862J
TEAC ZD5000    PCM53
TECHNICS SL-P1    PCM53
TECHNICS SL-P2    PCM53
TECHNICS SL-P110    PCM54HP
TECHNICS SL-P120K E    PCM54HP
TECHNICS SL-P272A    MN6474
TECHNICS SL-P202/212/222    CDM4/19
TECHNICS SL-P177/277/377/477 A    CDM4/19
TECHNICS SL-P1200    PCM54HP
TECHNICS SL-P360/70/460/70/570    CDM12.1/05
TECHNICS SL-PG480A    MN662713   CDM12.1/05
TECHNICS SL-PG100/200/400/420/440/500/520/540    CDM4/19
TECHNICS SL-PJ28A    MN6477   CDM4/19
TECHNICS SL-PJ24/26/27/28/37/325/46    CDM4/19
TECHNICS SL-PS620    CDM4/19
TECHNICS SL-PS670D    MN6474   CDM12.1/05
TECHNICS SL-PS700    MN6474   SOAD70A
TECHNICS SL-PS740A     CDM4/19
TECHNICS SL-PS770A    MN6473   CDM12.1/05
TECHNICS SL-PS840/900A     SOAD70A
THETA DSP    PCM67
THOMSON LAD300    TD6720N
THULE CD100    CS4303
THULE SPIRIT    PCM1715U
TOSHIBA XR40    TD6705AP
U:
UHER UCD-210   LC7882
UNIVERSUM CD4682    PCM56
USHER CD-100    PCM1732
W:
WADIA 850    PCM1702
WADIA 860    4x PCM1702
WADIA 861    4x PCM1704
Y:
YAMAHA CD-2    PCM53
YAMAHA CD-3    PCM53
YAMAHA CD-2000    PCM54HP
YAMAHA CDX-3   PCM54
YAMAHA CDX-410    PCM56
YAMAHA CDX-420    PCM56
YAMAHA CDX-450    KSS210A
YAMAHA CDX-470    YDC103   KSS210A
YAMAHA CDX-480    MN66271   KSS210A
YAMAHA CDX-490    MN66271R
YAMAHA CDX-580    YAC514   KSS210A
YAMAHA CDX-590    YAC514
YAMAHA CDX-593    YAC514
YAMAHA CDX-700    PCM56
YAMAHA CDX-750/860    KSS210A
YAMAHA CDX-880    YAC514   KSS210A
YAMAHA CDX-900    PCM56
YAMAHA CDX-890    YAC514
YAMAHA CDX-893    YAC514
YAMAHA CDX-993    YAC514F
YAMAHA CDX-1100    PCM56
YAMAHA CDX-2020    PCM58
补充内容 (2014-7-22 22:21):
SONY CDP-520ES        CX20152 – CX23034        Sony BU-1
SONY CDP-552ESD        CX20152 – CX23034        Sony BU-1
SONY CDP-552ESD II        2 x PCM53JP-V-K – CX23034        Sony BU-1C
SONY CDP-553ESD        2 x PCM53JP-V-K – CX23034        Sony BU-1C
SONY CDP-555ESA        1 x CXD2562Q – CXD2560M        KSS-272A
SONY CDP-555ESD        1 x TDA1541A – CXD1088Q        Sony BU-1E
SONY CDP-555ESJ        1 x CXD2562Q – CXD2567M        KSS-272A
2045 点
1901 ¥
 楼主| 发表于 2014-8-19 16:22 | 显示全部楼层
All information about the Philips TDA1541A d/a converter
http://www.dutchaudioclassics.nl/philips-tda1541.asp
