Introduced 1999
❙ Input connectors Unbalanced (rear panel switch position in):
WBT Phono socket
Balanced (rear panel switch position out):
XLR socket
Pin connections: Phono-inner hot, outer hot
XLR-Pin 1: OV, Pin 2: Hot, Pin 3: cold
❙ Input impedance Unbalanced 7k8 Ω
Balanced: 7k8 Ω
❙ Gain Unbalanced: 28.6 dB Balanced: 22.6 dB
❙ Input level for clipping Balanced: 3.34 Vrms;
Unbalanced: 1.67 Vrms;
Signal sensing threshold: >150 uV
❙ Output connectors Standard: Neutrik speakon
Optional: 4 mm sockets
❙ Output power 500 W rms into 4 Ω, 290 W rms into 8 Ω
❙ Load tolerance Stable into all loudspeaker loads
❙ Harmonic distortion <0.02%
❙ Frequency response 2 Hz - 60 KHz (-3 dB)
❙ Peak output voltage 70 V
❙ Fuse rating T6.3A
❙ Mains input range 90 Vac - 126 Vac; 200 Vac - 253 Vac @ 50/60 Hz
❙ Maximum input power 1000 W
❙ Typical operating input power 39 W
❙ Standby power <10 W
❙ Dimensions W 350 mm x D 355 mm x H 60 mm
W 13.8 inches x D 13.9 inches x H 2.4 inches
❙ Weight 9 kg / 19.84 lbs
LINN AKURATE KONTROL 7.1前级
The Akurate Kontrol has a phono stage for a turntable, six analogue and six digital outputs and can process all major audio algorithms:
Dolby Digital 5.1
Dolby Pro Logic II
DTS Surround
DTS 96/24
The Akurate Kontrol pre-amplifier uses Linn's 'silent power' Switch Mode Power Supply (SMPS) to minimise noise and distortion so all you hear is great music.
The Akurate Kontrol is designed for easy connection and control of all your analogue and digital sources, and fits seamlessly into a Knekt multi-room system for great music throughout your home.
