- 397
- 1266 小时
- 2024-12-30
- 50
- 282337
- 1129
- 397 点
- 396 ¥
- 2011-1-13
我有台力士M06 纯甲55W.该功放有桥接功能,目前的箱感觉推力不够,想再入一台M 06@,然后桥接成两台单声道,这样不知道还是不是工作在甲类,功率加大不知道推力会不会增大.救教有经验的朋友,非常感谢!!
该功放英文介绍如下:Form Stereo power amplifier
Succession effective output stereo: 55W+55W (8 ohms, 20Hz - 20kHz, Class-A both channel simultaneous operation)
mono: 220W (8 ohms, 20Hz - 20kHz, balance input)
Input sensitivity
stereo Coaxial: 50kohm
Balance: 100kohm
mono Balance: 100kohm
Input level adjustment 50kohm fixed-resistance switching type 12-point Attenuator (Coaxial)
THD stereo: 0.008% or less (8 ohms, both ch(es) simultaneous operation)
mono: 0.008% or less (8ohms)
Cross modulation distortion
(8 ohms, 60Hz:7kHz=4:1) stereo: 0.008% or less
Frequency characteristic 5Hz - 300kHz, and +0 -3 dB
SN ratio (IHF-A) 110dB
Dumping factor 10(8-ohm, 50Hz) 0
Supply voltage AC100V, 50Hz/60Hz
Power consumption 300W
Dimensions Width 444x height 211x depth of 417mm
Weight 22kg
