- 487
- 405 小时
- 2025-6-23
- 50
- 24830
- 508
- 487 点
- 477 ¥
- 2007-7-19
楼主 |
发表于 2007-11-1 09:42
显示全部楼层
让大家笑话了,我英语是个二把刀,不接触英语好多年了,很多英文看着眼生,找了词霸和在线翻译了一下,总算明白点意思了。如有什么不对,大家说说吧。
Application
用途
Glass octal type used in power supply of radio equipment having moderate dc requirements. Requires octal socket. Vertical tube mounting is preferred, but horizontal opration is permissible if pins 2 and 8 are in horizontal plane.
玻璃八进制型用于电力供应的无线电设备具有温和直流要求。需要八进制插座。垂直管安装是首选,但对于横向的操作是可以容许的,如果引脚2和8个是在水平面。
Mechanical Data
机械数据
Bulb .......................................... T-9
Base .......................................... Intermediate Octal 6-Pin
Outline ....................................... 9-13 9-42
EIA Base ...................................... 5T
Mounting Position ............................. Any
Electrical Data
有关电的数据
Heater Voltage ................................ 5.0 V
Heater Current ................................ 2.0 A
Maximum Ratings (Design Center Values)
最大的 额定功率(设计 中心 价值 )
Each Diode(每个二极管)
Peak Inverse Plate Voltage .................... 1400 V()
最高 相反的 板极 电压
Voltage Drop @ Current ........................ 50 V @ 125 mA
电压 下跌 电流
Characteristics and Typical Operation
特有的 和 典型的 操作
Rectifier(整流器)
AC Plate Supply Voltage Each Plate (RMS) ...... 350 V
Input Capacitor ............................... 20
交流 极板 供应 电压 每个 极板
输入 电容
Mfd
Effective Plate Supply Impedance Each Plate ... 50 Ω
效果 极板 供应 阻抗 每个 极板
DC Half-Load Output Current .................. 62.5 mA
输出直流 半波
DC Half-Load Output Voltage ................... 390 V
输出电压 半波
DC Output Current ............................. 125 mA
输出电流
DC Output Voltage ............................. 360 V
输出电压
Voltage Regulation (Half-Load to Full-Load) ... 40 V
电压规律(半波到全波)
特征和典型的操作
Rectifier (整流)
AC Plate Supply Voltage Each Plate (RMS) ...... 500 VInput Capacitor ............................... 10 Mfd
Effective Plate Supply Impedance Each Plate ... 140 Ω
DC Half-Load Output Current ................... 42 mA
DC Half-Load Output Voltage ................... 610 V
DC Output Current ............................. 84 mA
DC Output Voltage ............................. 560 V
Voltage Regulation (Half-Load to Full-Load) ... 50 V
Rectifier
Input Inductor ................................ 10 H
DC Half-Load Output Current ................... 75 mA
DC Half-Load Output Voltage ................... 270 V
DC Output Current ............................. 150 mA
DC Output Voltage ............................. 245 V
Voltage Regulation (Half-Load to Full-Load) ... 25 V
Rectifier
DC Half-Load Output Voltage ................... 405 V
DC Output Voltage ............................. 380 V
Voltage Regulation (Half-Load to Full-Load) ... 15 V |
