231
心是愿望,神是境界!性格决定命运,细节决定成败!
806 点
680 ¥
发表于 2014-3-24 10:39 | 显示全部楼层
我没搞过障板,求交流,
下面是E文 邮件原文,
Dear Mr. WU XING HUI,
I transfer to you and with immense pleasure my experience and all my help for realize marvelous Dipoles.
The costs of project, realization and construction for the Dipoles are very low and fast to be built.
The ideal loudspeakers for realize marvelous Dipoles have :
- Qts from 0.9 or superior.
- High Excursion of Cone (+/- 4, 5, 6, 7 mm or superior)
- Low Frequences (Fs) of 30, 40 or 50 Hze.
This are the three more important parameters for get a ideal loudspeaker for utilize in Dipole configuration.
This are the parameters for the Woofers ... for a Mid-Woofer the value of Low Frequences (Fs) have small importance 70, 80, 90 Hze, the other parameters Qts and Excursion of Cone, to remain more and more high possible.
You look for Mid-Woofer in carbon - fiber with the parameters above and in little time I  send to you drawing.
I make tests with loudspeaker of 165 mm and the result is excellent ... if you also find one with this measure, is all right !
We, in little time, have new preamplifiers and amplifiers.
This products not have buttons for ON/OFF, them make ON/OFF with signal in entry of only 1 mV/eff and when music to disappear for 40 seconds, every products in  automatically go off.
For this new products (with valve), we want to insert small screen OLED or other screen to color (with possibility of programmed) where writes our logotype.
If you to find for we this good product, we purchase for discreet quantities from you and then, we give to you possibility of sell our products with your logotype ... as if this  products are yours !!!
If you to sell our products with your logotype ... you have high gain $$$$ !!!
231
806 点
680 ¥
 楼主| 发表于 2014-3-26 17:58 | 显示全部楼层
求翻译,,,
559
2065 点
1915 ¥
发表于 2014-3-26 20:15 | 显示全部楼层
亲爱的吴先生兴
我转到你和巨大的快乐我的经验和我所有的帮助实现奇妙的偶极子。
项目的成本,实现和建设的偶极子非常低和快速。
实现理想的喇叭的偶极子有:
——从0.9或优越的规定性。
-高偏移的锥(+ / - 4、5、6、7毫米或上级)
-低Frequences(Fs)30、40或50 Hze。
这是得到一个理想的三个重要参数利用扬声器的偶极子配置。
这是低音的参数…Mid-Woofer Frequences低的价值(Fs)有小70的重要性,80年,90 Hze,其他参数规定性和锥的偏移,保持越来越高。
你寻找Mid-Woofer碳-纤维与上述参数在很少的时间,我发送给你图纸。
我做测试扬声器的165毫米和结果是优秀的…如果你也找一个与这一标准,都是正确的!
在很少的时间,我们有新的放大器,放大器。
这个产品没有开/关按钮,他们只与输入信号的开/关1 mV / eff音乐消失40秒,每个产品在自动离开。
对于这个新产品(阀门),我们想要插入小屏幕OLED屏幕或其他颜色(编程)的可能性,写我们的标识。
如果你发现我们这好产品,我们购买的数量从你,然后我们给你销售我们的产品的可能性与你的标识……如果这个产品是你的! ! !
如果你销售我们的产品与你的标识……你有高增益$ $ $ $ ! ! !
