- 78
- 112 小时
- 2022-6-18
- 50
- 32730
- 68
- 78 点
- 64 ¥
- 2007-12-24
最近在研究cs8414,总觉得时钟问题有点头疼,如果用cs8414内部时钟输出,音质不太理想,听音乐好像总是隔着一层纱布。如果用外部时钟作参考,音质提升明显,但有人说存在参考时钟与转盘时钟不一致的问题,而且仅能解码44.1k采样率的音源。我用外部时钟模式没有一点问题,但总担心会不会丢失一些东西。
在用示波器测试cs8414输出波形的时候,发现用内部时钟模式时,11脚fsync波形很不稳定,而19脚mck即使在外部时钟模式下仍然有输出。于是突发奇想,将cs8414设置为外部时钟模式,然后用19脚的256fs分频得到sck和lrck后再输回8414。经过实验,此方法确实有效,我感觉音质也有很大提升,长期试听朦胧感基本消失,也没有爆音破音。
有图有真相
另外还请高人详细解答cs8414数据手册里面的一句话:In the CS8414, FSYNC is always generated from the incoming data stream. When FSYNC is generated from the data, its edges are extracted at times when intersymbol interference is at a minimum. This provides a sample frequency clock that is as spectrally pure as the digital audio source clock for moderate length transmission lines.
When FSYNC and SCK are inputs, one stereo
sample is double buffered.
