[分立后级] 24W甲类放大器
[复制链接] 查看: 11876|回复: 27
1130 点
1012 ¥
发表于 2013-11-26 22:31 | 显示全部楼层
The circuit was designed as Class A amplifier that would provide 24 Wattsof power
Amplifier – an electronic device used for intensifying the amplitude orpower of a transmitted signal by manipulating the output to counterpart theinput signal but with a larger amplitude
Classes of Amplifier:
  • Class A –     output device conducts through 360 degrees or 100% of the input cycle*
  • Class B –     output device conducts through 180 degrees or 50% of the input cycle
  • Class AB –     almost the same as Class B amplifiers but differs in that they have a     small idle current flowing from positive supply to negative supply even     when there is no input signal
  • Class C –     output device conducts less than 180 degrees or less than 50% of the input     signal
  • Class D –     uses switching and pulse width modulation of a high frequency to obtain a     very high power efficiency
  • Class E –     refers to an amplifier with pulsed inputs and a tuned circuit output
  • Class F – a     highly efficient switching power amplifier
  • Class G –     consists of several power rails at different voltages and switches between     rails as the signal output approaches each
  • Class H –     takes the idea of Class G one step further creating an infinitely variable     supply rail
Although Class A cost the most and are least practical, they are stillpreferred because the sound best, returns very clean signal, it is the mostlinear and has the lowest distortion. The circuit’s inactive current must beset by the resistor R25 while the maximum resistance must be set when poweringthe circuit by the trimmer resistor R3, which will be reduced the the inactivecurrent has been achieved. A range of 34 V to 46 V may be used as the supplyvoltage. The biggest disadvantage of Class A is that it uses a lot ofelectricity and gets very hot, making it very dependent on a heatsink bigenough to maintain its operating temperature so that the amplifier would besafe from thermal runaway.
The circuit operates over the whole of the input cycle such that theoutput signal is an exact replica of the input with no clipping. The ouputdevice will conduct all the time which means the power devices must conduct acontinuous current which exceeds the maximum peak load current. The outputstage of the circuit has bias current greater than the maximum output currentwhich makes all output transistors always conducting current.
To compare the uses of every class of amplifiers:
  • Class A – is     used as an audio and radio frequency amplifier in radio, radar, and sound     systems
  • Class B – is     used widespread for audio amplifiers that require high power outputs and     power amplifier stages of transmitters
  • Class C – is     used as a radio frequency amplifier in transmitters only and cannot be     used for audio
  • Class AB – is commonly as push-pull amplifier, designed     to function with audio power amplifiers
  • Class D – are     widely used to control motors and almost limited to small DC motors but     are now also used as audio amplifiers using a few additional circuitry to     permit analog signals to be converted to a much higher frequency pulse     with modulated signal
  • Class E – is     not used for audio, but commonly used in radio transmitters where the     output is at a single narrow band of frequencies
  • Class F – is     typically used at such high frequencies that the switching time becomes     comparable to the duty time
  • Class G – is     used as rail switched amplifier which has two different power supply     voltages
  • Class H – is     very common in professional audio amplifiers
版主 当前在线
6823 点
5986 ¥
发表于 2013-11-26 22:34 | 显示全部楼层
差分级信号通过C5传导到电压放大级吗?这个C5才100P
926 点
840 ¥
发表于 2013-11-26 22:37 | 显示全部楼层
c5=100μ,单电源供电。
灵山-小方
626 点
542 ¥
发表于 2013-11-26 22:38 | 显示全部楼层
是100UF  你看原图清晰一点
1130 点
1012 ¥
 楼主| 发表于 2013-11-26 22:40 | 显示全部楼层
这个24瓦的A类放大器由分立件组成的,由南非klynhans设计。
规格:
这里是规格:
24W类为8欧姆
100MHz至100kHz平
2 4周为8欧姆305mv输入(33分贝增益)
总谐波失真是非常低的,虽然我没有能够正确测量
电源电压可以34V和46V和静态电流之间应设置为1.7A R25(通过测量的电压必须超过0.75V R25用于静态电流仅在这里测量)。R23是微调,必须设置为最大电阻(10K欧姆)供电时。然后R23电阻必须降低到静态电流达到。如果放大器是安装在一个足够大的散热器(0.6k/w最多)将放大器从热失控很安全。智能时必须选择权和电阻器和电容器的额定电压。
我一直在使用这个放大器与一对极想F20和声音是令人难以置信的!
马克的网站可能会发现:http://mrcshobbies.blogspot.com
以上通过自动翻译不太准确
133 点
128 ¥
发表于 2013-11-26 22:43 | 显示全部楼层
请问搂主,这未级,r18 与r23串联之间的点,是否要接q1.q3的b极?
1130 点
1012 ¥
 楼主| 发表于 2013-11-26 22:46 | 显示全部楼层
24WCA.gif 补充一下
1130 点
1012 ¥
 楼主| 发表于 2013-11-26 22:47 | 显示全部楼层
我也不太清楚
133 点
128 ¥
发表于 2013-11-26 23:01 | 显示全部楼层
看了你的,自动翻译,r18与r34可调电阻串联,可能不连接的。
133 点
128 ¥
看了你的,自动翻译,r18与r23可调电阻串联,可能不连接的。
133 点
128 ¥
发表于 2013-11-26 23:02 | 显示全部楼层
可能不与q1.q3的b极连接的。
1130 点
1012 ¥
 楼主| 发表于 2013-11-26 23:42 | 显示全部楼层
感觉比1969好吧?
888 点
823 ¥
发表于 2013-11-26 23:50 | 显示全部楼层
georgedl 发表于 2013-11-26 22:46
补充一下
绝对不能连接。连接了不就是将680欧电阻和前面的晶体管并联了吗?虽然还是可以出声音。
485 点
485 ¥
发表于 2013-11-26 23:53 | 显示全部楼层
好图..这个强拉2分之一电位概念清楚..感觉比1969工作点稳定..可以装台听听在评论好坏
926 点
840 ¥
发表于 2013-11-26 23:56 | 显示全部楼层
确实不错。R6、R7调中点。
104
老菜鸟一个
5385 点
5138 ¥
发表于 2013-11-27 01:01 | 显示全部楼层
这个等人开板
86
1781 点
1654 ¥
发表于 2013-11-27 08:08 | 显示全部楼层
看图功率管应是单端输出吧?
1013 点
407 ¥
发表于 2013-11-27 18:23 | 显示全部楼层
好像不错,2并的1969?
60 点
57 ¥
发表于 2013-11-29 10:34 | 显示全部楼层
不错
14228 点
14167 ¥
发表于 2013-11-29 11:23 | 显示全部楼层
