- 152
- 77 小时
- 2022-11-25
- 50
- 206056
- 155
- 152 点
- 157 ¥
- 2010-5-29
楼主 |
发表于 2017-2-7 02:59
显示全部楼层
没有数字音频输出,连GPIO的可选编程列表里面也没有该类选项,废物。结帖!
3 Feature
The systems include the following feature:
ARM926-EJS 16KB I-Cache/16KB D-Cache
Support 16 bits SDR
Two 32-bit Programmed Timers
Enhanced 8-CH Direct-Memory-Access Controller
Built in Pulse Width Modulator
Built in USB 2.0 HS
Built in Touch Panel Interface
Built in Low Resolution A/D convertor
On-chip Sigma-Delta A/D with SNR up to 95dB(A-Weight)
On-chip Sigma-Delta D/A and PA with SNR up to 100dB(A-Weight)
On-Chip ROM Boot loader
Built in HDTV encoder
Built in LCD controller
Built in IrDA for remote control
Built in audio codec for headphone and microphone application
Support SLC/MLC NAND flash up to 64bits ECC
Support SD/TF/MMC card
Fully support PMU application
Video Decoder Engine(all format up to 1280*720@30fps)
H.264
Fully compatible with ISO-14496-10 in BP/MP/HP
Supports CABAC/CAVLC
Supports frame/field/MAFF structure
Variable block size(16x16, 16x8, 8x16, 8x8, 8x4, 4x8 and 4x4)
MPEG-1
Fully compatible with ISO/IEC 11172-2 Mpeg1 specification
Support I, P, B, D pictures
MPEG-2
Fully compatible with ISO/IEC 13818-2 Mpeg2 specification in Main profile
Support I, P, B pictures
Support field coded picture and frame coded picture
MPEG-4
Fully compatible with ISO-14496-2 SP/ASP
Supports GMC up to three wrapping points
Supports H.264 baseline profile
Supports Xvid
Package
- LQFP128
3.3V for I/O, and 1.2V for Internal digital circuit |
