210 点
194 ¥
发表于 2013-3-24 11:32 | 显示全部楼层
不依不饶,进行到底,这是第三版的PCM1794,这块PCB做了两台机,一台使用PCM1798芯片,另一台使用PCM1794芯片。
PCM1794果然不忽悠,在测试指标上虽然与PCM1798相差很细微,但听感更好。
RightMark Audio Analyzer test report
Testing devicePCM1794
Sampling mode16-bit, 44 kHz
Interface
Testing chainExternal loopback (line-out - line-in)
RMAA Version6.2.3
20 Hz - 20 kHz filterON
Normalize amplitudeON
Level change0.1 dB / 0.0 dB
Mono modeOFF
Calibration singal, Hz1000
Polaritycorrect/correct
Summary
Frequency response (from 40 Hz to 15 kHz), dB
+0.01, -0.08
Excellent
Noise level, dB (A)
-97.1
Excellent
Dynamic range, dB (A)
96.6
Excellent
THD, %
0.0018
Excellent
THD + Noise, dB (A)
-88.5
Good
IMD + Noise, %
0.0044
Excellent
Stereo crosstalk, dB
-97.4
Excellent
IMD at 10 kHz, %
0.012
Very good
General performance
Excellent
From 20 Hz to 20 kHz, dB
-0.16, +0.01
From 40 Hz to 15 kHz, dB
-0.08, +0.01
Left
Right
RMS power, dB
-95.5
-95.6
RMS power (A-weighted), dB
-97.1
-97.1
Peak level, dB FS
-82.5
-86.9
DC offset, %
-0.0
-0.0
Left
Right
Dynamic range, dB
+95.5
+95.5
Dynamic range (A-weighted), dB
+96.6
+96.5
DC offset, %
-0.00
-0.00
Left
Right
THD, %
+0.0014
+0.0022
THD + Noise, %
+0.0036
+0.0040
THD + Noise (A-weighted), %
+0.0034
+0.0041
Left
Right
IMD + Noise, %
+0.0044
+0.0045
IMD + Noise (A-weighted), %
+0.0038
+0.0039
Left
Right
Crosstalk at 100 Hz, dB
-95
-95
Crosstalk at 1000 Hz, dB
-96
-97
Crosstalk at 10000 Hz, dB
-91
-90
Left
Right
IMD + Noise at 5000 Hz,
0.0052
0.0055
IMD + Noise at 10000 Hz,
0.0094
0.0091
IMD + Noise at 15000 Hz,
0.0220
0.0208
784 点
777 ¥
发表于 2013-3-24 11:56 | 显示全部楼层
这太专业了,有广告的味道
210 点
194 ¥
 楼主| 发表于 2013-3-24 11:59 | 显示全部楼层
AlltestResult2.jpg 再上一图。
452 点
444 ¥
发表于 2013-3-24 12:15 | 显示全部楼层
晶振的位置是不是可以搞大点,
210 点
194 ¥
 楼主| 发表于 2013-3-24 12:21 | 显示全部楼层
我问过几家卖晶振的人,他们说,现在的晶振都很稳定,现代的晶振最比较小,工艺也很好,相对来说,大的晶振是比较旧的生产工艺,性能还没有小的好。
当然,这是一般的说法啦,如果真要纠结这个问题,那就纠结吧。
127
脑放进行时
17478 点
15213 ¥
社区贡献 优秀设计 论坛版主
发表于 2013-3-24 12:50 | 显示全部楼层
晶振多余了 拆掉吧
250 点
245 ¥
发表于 2013-3-25 10:00 | 显示全部楼层
USB的芯片太低端了怎么着也的上个6631吧    别介意说说而已  板子做的不错
认证会员 当前离线
897 点
846 ¥
认证会员
发表于 2013-3-25 12:34 | 显示全部楼层
顶,测试结果很不错哟!支持!
GMT+8, 2025-9-6 01:07 , Processed in 0.110645 second(s), 9 queries , Gzip On, Redis On.
