137
中尉
517 点
360 ¥
发表于 2013-3-13 17:32 | 显示全部楼层
128
1075 点
1067 ¥
发表于 2013-3-13 17:43 | 显示全部楼层
The stereo Integrated Amplifier of W super scheme.
W and the super servo scheme which solved DC leakage to an output, the influence on the tone quality by the noise component resulting from source impedance, etc. are adopted as a power amplifier part.
Moreover, the super servo scheme of the super-low-pass cut is built also into the equalizer amplifier corresponding to MC.
Without fluctuating a bias entirely, the linearity of the circuit operation was raised and linear switching which suppresses crossover distortion is adopted.
Although it is B class operation which adopts, shares and amplifies two power transistors, the crossover skewness which tends to be generated at a wave-like joint by adopting a special corrective network is suppressed.
Furthermore, it has succeeded in the three-step Darlington stream composition of a High fT power transistor, and the thing which will carry out a double push pull and which it is alike and is banished more out of an audio frequency band also to switching distortion.
A MC-man month compatible variable gain equalizer and 2 amplifier stream compositions called only high gain power amplifier are adopted.
Equalizer amplifier is a development of the non it1 Capacitor-Less NF constant translation method by an electric-current translation super servo scheme which needs neither head amplifier nor a boost transformer even if it faces a using of MC cart,By the outstanding three-step differential amplifier of the nakedness property etc., it is being planned whether they are the improvement in S/N, and high gain.
Moreover, the power amplifier by W and a super servo scheme was raising the gain of 20dB, omitted tone amplifier and realized the wide dynamic range and the low distortion.
The softness circuitry is carried. Unlike the usual tone control, this circuitry can choose three kinds of different tone characters.
The large-sized power transformer of a twin whined scheme is used for a power-source part, and it is a chemicon for a rectification,The correlation of a careful hearing and the physical properties of a material is investigated, and the low impedance wide-range chemicon of a multi-tab scheme is used as the printed circuit board and a low inductance circuitry made to link directly.
Moreover, thorough low impedance-ization, such as using the hot bus (bus-bar) line made from a copperplate for a power feeding/power distribution of each section, and an earth line, is attained.
The direct tone scheme except the tone-quality failure with tone amplifier is adopted.
The difference of temperature by each part is detected, and the auto tracking bias scheme which enabled the always stabilized low-distortion drive is adopted.
In order to suppress an occurrence of a high order higher harmonic, it is the design of the tone-quality priority which uses non-magnetic-material material.
集成的立体声放大器的W超计划。
W和超伺服计划,解决DC泄漏到输出的源阻抗产生的噪声成分,对音质的影响的,采用作为一个功放部分。
此外,超级伺服计划建立的超级低通切到对应的MC均衡器放大器。
完全没有波动的偏置,电路的操作的线性度被提高,抑制了交越失真的非线性开关采用。
虽然是B级采用,和放大两个功率晶体管,容易产生波浪状联合,通过采用特殊的纠正网络被抑制的交叉偏态的操作。
此外,它已成功地在三个步骤组成的高fT功率晶体管达林顿流,的东西进行双推挽和它是相同的,被驱逐更多的音频频段的开关失真。
MC-人一个月兼容的可变增益均衡器和2个放大器物流组成称为高增益功率放大器采用。
均衡器放大器电电流的翻译超级伺服方案,既不需要前置放大器,也不是一个升压变压器,即使它面临着一个MC车的使用,以优异的三个步骤是一个发展的非IT1电容的NF不变的翻译方法的下体属性等的差动放大器,它是被计划他们是否是改善的S / N,高增益。
此外,由W功率放大器和一个超级伺服计划提高增益为20dB,省略音放大器,实现了宽动态范围和低失真。
的柔软电路进行。不同于一般的音调控制,该电路可以选择三种不同的音色字符。
用于双呜咽计划的大尺寸的电源变压器的功率源的一部分,它是一个CHEMICON的整流,研究的相关性进行了认真的听觉和物理性质的材料,低阻抗的宽范围CHEMICON多标签计划用作作出直接连结在印刷电路板和一个低电感的电路。
此外,彻底的低阻抗化,如使用热总线(母线)线由铜板的供电/功率分布的每个部分,和一个接地线,也就达到了。
方案除了直接音与音放大器的音频质量不合格被采纳。
各部分的温度的差异被检测到,并采用使总是稳定的低失真驱动器的自动跟踪偏置方案。
为了抑制高阶高次谐波的发生,这是设计的音频质量优先使用非磁性物质的材料。
128
1075 点
1067 ¥
发表于 2013-3-13 17:45 | 显示全部楼层
Form  W super servo scheme Integrated Amplifier
Output power (20Hz - 20kHz)  110W+110W (8 ohm, AUX->SP out, both channel drive)
THD (20Hz - 20kHz)  0.008% (at the time of AUX->SP out and a rate)
0.006% (at the time of AUX->SP out, 1 / 2 rates)
0.003% (PH-man month->Rec out, 3V)
0.01% (PH-MC->Rec out, 3V)
Cross modulation distortion  0.005% (AUX->SP out)
Power Band Width  5Hz - 100kHz (IHF-3dB, THD0.2%)
Dumping factor  100 (1kHz, 8ohm)
Frequency characteristic  20Hz-20kHz±0.2dB (PH->Rec out, RIAA deflection)
2Hz-100kHz+0dB-1.5dB (AUX->SP out, RIAA deflection)
Input sensitivity/impedance  Phono man month: 2.5mV / 47kohm-100kohm
Phono High MC: 2.5mV/100 ohm
Phono MC: 130 microvolts/100 ohm to 330 ohm
Tuner, AUX, Tape Play1, 2:150mV / 47kohm
Phono maximum permissible input
(1kHz/10kHz 0.05%)  Phono MM:300mV/1400mV
Phono High MC:300mV/1400mV
Phono MC:17mV/82mV
An Output voltage/impedance  Tape Rec1, 2:150mV / 2.2kohm
Pre Out: 1.5V/600 ohm
S/N ratio (IHF A, input short-circuit)  Phono MM:86dB
Phono MC:69dB
Tuner, AUX, Tape Play1, 2:100dB
Tone control (Vol-16dB)  Bass(70Hz): ±8dB
Treble(20kHz): ±8dB
Loudness  + 6dB+4dB, 100Hz
Subsonic Filter  15Hz, 20Hz 6dB/oct
Muting  -20dB
Power source  100V, 50/60Hz
Power consumption
(Electrical Appliance and Material Control Law specification)  200W
AC outlet  unswitched: One piece (200W)
switched: Two pieces (total 200W)
Dimensions  Width 435x height 170x depth of 424mm
Weight  20.3kg
表格W超级伺服方案集成放大器
输出功率(20HZ  - ​​20KHZ)110W+110 W(8欧姆,AUX-> SP输出,两个通道的驱动器)
总谐波失真(20HZ  - ​​20KHZ)0.008%(AUX-> SP出来的时候,速率)
0.006%(在AUX-> SP满分的时间,1/2速率)
0.003%(PH人一个月的录音输出,3V)
0.01%(PH-MC->录音输出,3V)
交叉调制失真0.005%(AUX-> SP了)
5HZ - 100kHz的功率频带宽度(IHF-3dB的,THD0.2%)
倾倒100倍(1kHz时,8欧姆)
频率特性20Hz-20kHz的为±0.2dB(PH->录音输出,RIAA偏转)
2HZ-100KHZ0分贝1.5分贝(AUX-> SP了,RIAA偏转)
输入灵敏度/阻抗唱机人月:为2.5mV/47kohm100kOhm的
MC唱头高:2.5mV/100欧姆
MC唱头:130 microvolts/100欧姆到330欧姆
调谐器,AUX,带Play1,2:150毫伏/47kohm
唱机最大允许输入
(1kHz/10kHz0.05%)唱机MM:300mV/1400mV的数据
MC:300mV/1400mV唱机高
唱机MC:17mV/82mV的
输出电压/阻抗带REC1,2:150毫伏/2.2kohm的的
PRE OUT:1.5V/600欧姆
S / N比(IHF A,输入短路)唱机MM:86分贝
唱机MC:69分贝的
。调谐,AUX,带Play1,2:100分贝;
音调控制(VOL-16分贝)低音(70Hz时):±8分贝
高音(20kHz)的:8分贝±
音量+6分贝的为+4 dB,100Hz的
高通滤波器15HZ,20HZ6dB/oct
静音 -  20dB的
电源100V,50/60HZ
耗电量
(电器及材料控制法规范)200W
AC不带开关的插座:单件(200W)
转自:两件(共200W)
外形尺寸宽435x高170X深度424毫米
重量20.3公斤
137
中尉
517 点
360 ¥
 楼主| 发表于 2013-3-13 17:57 | 显示全部楼层
谢谢你啊,是你翻译的吗,还是软件翻译的
