- 224
- 765 小时
- 2019-10-7
- 50
- 3353
- 197
- 224 点
- 154 ¥
- 2005-3-10
购买了12对3寸罗技全频,想做两套5.1环绕音箱,打算四个环绕每个箱用一对,中置用两对,五个箱子都加一个直径3.5CM左右的高音。我对音箱知识一窍不通啊!还请各位DX帮帮忙,给个箱图,并附上详细尺寸,小弟我不胜感激!!!下面是喇叭的参数
3" PAPER CONE/ FULL RANGE
DIAPHRAGM MTL [td=1,1,131]Paper
SURROUND MTL [td=1,1,131]Santoprene
NOMINAL IMPEDANCE [td=1,1,131]8
DCR IMPEDANCE [td=1,1,131]6.6
SENSITIVITY 1W/1m [td=1,1,131]87 dB
FREQUENCY RESPONSE [td=1,1,131]100-20K Hz
FREE AIR RESONANCE [td=1,1,131]100 Hz
VOICE COIL DIAMETER [td=1,1,131]18.4 mm
AIR GAP HEIGHT [td=1,1,131]6 mm
RATED POWER INPUT [td=1,1,131]12 W
MAXIMUM POWER INPUT [td=1,1,131]25 W
FORCE FACTOR, BL [td=1,1,131]3.3 TM
MAGNET WEIGHT (4.1oz) [td=1,1,131]115 g
MOVING MASS [td=1,1,131]1.71 g
FERRO FLUID ENHANCED [td=1,1,131]No
SUSPENSION COMPL. [td=1,1,131]1234.23MN-1
EFFEC.PISTON AREA [td=1,1,131]0.0032M2
Levc [td=1,1,131]0.3mH
Zo [td=1,1,131]52ohm
X-max [td=1,1,131]0.4 mm
Vas [td=1,1,131]1.79 Litr.
Qts [td=1,1,131]0.64
Qms [td=1,1,131]6.59
Qes [td=1,1,131]0.71 |
