- 2724
- 6321 小时
- 2025-7-2
- 100
- 3
- 1005
- 3372
- 3
- 2724 点
- 977 ¥
- 2004-7-11
楼主 |
发表于 2013-2-25 15:42
显示全部楼层
Musical Fidelity A1000 是电源分体的合并机.
Specs
2x 50W output in Class A (8Ohm)
MC input (600µV sens.)
MM input (8mV sens.)
Line inputs (350mV sens.)
S/N ratios
>60dB (MC)
>75dB (MM)
>85dB (lines)
±0,7dB RIAA accuracy
<0,5% THD (20Hz...20kHz)
>85dB channel separation
PC : 215W continuous
Dimensions :
48,3 x 12,2 x 33,5cm (A1000)
19,4 x 12,2 x 33,5cm (PSU)
Weight :
11kg (A1000)
7kg (PSU). |
