78 点
64 ¥
发表于 2013-2-22 11:33 | 显示全部楼层
在讨论多片dac并联的时候,很多支持并联的网友经常拿pcm1704、1702的内部结构作为依据支持自己的观点。
在此先不说多片并联是否正确,我要说的是pcm1704、1702内部不是简单的两片dac并联,也不是差分。
是为了解决r2r解码器存在的过零失真问题,bb公司采用了类似乙类放大器的原理,把信号分成上下两个分别进行解码。
这是pcm1702数据手册的原文:
The PCM1702 is a new solution to the problem. It combines
all the advantages of a conventional DAC (excellent full
scale performance, high signal-to-noise ratio and ease of
use) with superior low-level performance. Two DACs are
combined in a complementary arrangement to produce an
extremely linear output. The two DACs share a common
reference, and a common R-2R ladder for bit current sources
by dual balanced current segments to ensure perfect tracking
under all conditions. By interleaving the individual bits of
each DAC and employing precise laser trimming of resistors,
the highly accurate match required between DACs is
achieved.
This new, complementary linear or advanced sign magnitude
approach, which steps away from zero with small steps
in both directions, avoids any glitching or “large” linearity
errors and provides an absolute current output. The low level
performance of the PCM1702 is such that real 20-bit resolution
can be realized, especially around the critical bipolar
zero point.
Table 1 shows the conversion made by the internal logic of
the PCM1702 from binary two’s complement (BTC). Also,
the resulting internal codes to the upper and lower DACs
(see front page block diagram) are listed. Notice that only
the LSB portions of either internal DAC are changing
around bipolar zero. This accounts for the superlative performance
of the PCM1702 in this area of operation.
看表就可以知道对于首位是0的信号由上dac进行解码,首位是1的信号,由下dac进行解码。内部两个dac不是简单并联。所以大家在讨论的时候,请认真研究数据手册,不要想当然。
78 点
64 ¥
 楼主| 发表于 2013-2-22 11:35 | 显示全部楼层
对于下面的说法,我感到很疑惑。
很多客户问,那2片并联或4片并联到底能提高多少效果呢?拿4片16BIT的并联,和1片24BIT的,区别多少?
并联使用DAC可提高等效比特数,提高转换精度,还原音乐的厚度感和力度感增强。当DAC并联使用时,信噪比、动态范围都会提高,而失真度将会减小,各种误差也被平均化而降低。并联的方法有很多种,风格稍有不同。
大体上说:2个18 bit DAC并联后的转换精度相当于19 bit,4个20 bit DAC并联后转换精度相当于23 bit ,而8个20 bit DAC并联后转换精度相当于24 bit,等等。PCM1704等24 bit DAC出现之前,高档数字音响的24 bit转换精度就是利用多个DAC并联方法得到的。所以4个16 bit的并联,相当于19 bit效果。
从人耳声音听感上来说,区别不可能象技术指标数字上的差距那么大。24BIT的技术指标要比20BIT高16倍,即2的4次方,24BIT的技术指标要比16BIT的高1024倍。所以2并联从技术指标上来,20BIT的就相当于21BIT的了,提高100%,但声音效果是提高10%左右。同理4并联可以提高约20%。所以多片DAC并联,实际听感,并不如很多人想象的可以提高那么多,很多还是商业广告需求。
127
脑放进行时
17478 点
15213 ¥
社区贡献 优秀设计 论坛版主
发表于 2013-2-22 11:47 | 显示全部楼层
分段DAC咯
PCM1704 PCM1704 PCM1794 这些都是分段DAC
3516 点
3434 ¥
发表于 2013-2-22 12:08 | 显示全部楼层
晕…… 并联还是差分、分段、主副什么的,都是具体应用而已呀。
206
5573 点
5235 ¥
发表于 2013-2-22 12:22 | 显示全部楼层
事实上并联R2R的芯片后的音效提高并没有那么明显的,有时还没有等级的差异大。所以,一般的DIY情况下,别对多并寄予过大的厚望。
2850 点
2701 ¥
发表于 2013-2-22 14:05 | 显示全部楼层
并联分时转换的确是可以提高精度与信噪比,你说的听感,的确区别不是很大,我就试过4BIT的转换(只使用1702的高4位,一次错误的逻辑所导致),能听到声音时也是很悦耳,也能很清楚分得出各种乐器与人声,很不可思议吧,可能频率畸变的影响远大于电压幅度畸变的影响
100
5541 点
5490 ¥
发表于 2013-2-22 14:55 | 显示全部楼层
我也不喜欢并联,玩并联还不如玩平衡输出
2145 点
1973 ¥
发表于 2013-2-22 18:40 | 显示全部楼层
小熊猫
6091 点
5748 ¥
发表于 2013-2-22 19:40 | 显示全部楼层
63才是上下结构,1702,1704是左右结构,1794是多阶1bit 。
596 点
360 ¥
发表于 2013-2-22 23:15 | 显示全部楼层
卡西利亚斯 发表于 2013-2-22 19:40
203 点
221 ¥
发表于 2013-8-11 21:26 | 显示全部楼层
那为什么有的高档DVD也是用4片1704并联呢
203 点
221 ¥
应该是说无绝对吧
231 点
198 ¥
发表于 2013-8-11 21:46 | 显示全部楼层
好像先锋的一款旗舰DVD就是4片1704 论坛上经常有那个板子卖的应该就是这个
203 点
221 ¥
发表于 2013-8-12 14:32 | 显示全部楼层
是的我也见到了
