新手求肋
[复制链接] 查看: 2074|回复: 4
75
480 点
434 ¥
发表于 2007-6-11 18:27 | 显示全部楼层
我是新手想做一个三分频音箱   我买的单元高音scan speak R2904/7000中音低肯
        Flexunits 5 H 52 15 06 SD
           Flexunits 12 B 77 25 10分频点、300一3500箱子容积80升
Effective Cone Area 137   Cm2  B 77 25 10
Effective Cone Area 515   Cm2
Nominal Impedance 8  Ohm
Resonance Frequence 25  Hz
Equivalent Air Volume 250  Ltrs.
Mecanical Q Factor 2.5
Electrical Q Factor 0.34
Total Q Factor 0.3
Acceleration Factor 203
Nominal Power Handling 250  W
Efficiency 92  dB
Frequency response 28-1800  Hz
DC resistance 5.4  Ohm
Compliance 0.6733  mm/Nm
Mechanical res. 3.782
VC inductance 0.76  mH
Moving mass 60.20  g
Force factor 12.24
Linear excursion (x-max) 8.6  mm
Max. excursion (P-P) 48
Resonance Frequence 40  Hz
Equivalent Air Volume 28.5  Ltrs.
Mecanical Q Factor 1.8
Electrical Q Factor 0.39
Total Q Factor 0.32
Acceleration Factor 499
Nominal Power Handling 150  W
Efficiency 89  dB
Frequency response 42-4300  Hz
DC resistance 5.6  Ohm
Compliance 1.0846  mm/Nm
Mechanical res. 2.038
VC inductance 0.13  mH
Moving mass 14.60  g
Force factor 7.26
Linear excursion (x-max) 5.2  mm
Max. excursion (P-P) 32  mm
R2904/7000
Characteristic sensitivity (2.83V / 1m) :  94.5 dB
Recommended frequency range :  2 - 40 kHz
Free air resonance frequency, fs :  520 Hz
DC resistance, Re :  3.0 ohm
Voice coil inductance, Le :  0.01 mH
Effective piston area, Sd :  5.6 cm2
Moving mass incl. air, md :  0.30 g
Force factor, BL :  2.8 Tm
Excursion, lin./max. :  ±0.20 / ±1.6 mm
Voice coil diameter :  25 mm
Rated power handling :  160 W (12 dB/oct.
   cross-over at 2.5 kHz)
Net weight :  0.42 kg
敢拆不会修
2186 点
2107 ¥
发表于 2007-6-11 19:35 | 显示全部楼层
呵呵,新手就做这么大的箱子
119
超级贵宾 当前离线
3546 点
3116 ¥
优秀设计 论坛版主
发表于 2007-6-11 20:36 | 显示全部楼层
坏了,楼主说的喇叭有两个俺没听过,看样子还得多学习。
不过看起来中音灵敏度比低音低3DB,会不会有问题呢?看中音喇叭的参数也是个低音啊。
417 点
295 ¥
发表于 2007-6-11 20:46 | 显示全部楼层
还是仿制音箱成功的机会高,除非你只求能响那是例外。老话一句音箱“易学难精”呵。
75
480 点
434 ¥
 楼主| 发表于 2007-6-11 21:04 | 显示全部楼层
回楼上兄我相做精品才向dx学习啊厢子没有问题分频就得求DX们指导了·中 低音单元是AT 5"  12"                 求高手帮忙我这谢谢了
