奥迪chorus不能开机
[复制链接] 查看: 7198|回复: 33
24 点
24 ¥
发表于 2012-11-13 20:37 | 显示全部楼层
最近在废品的收获三台车机,其中的大众捷达、飞度都已开机,唯独一台奥迪chorus开机保护---显示SAFE,找不到密码,到汽车音响修理店读出24LC16B的数据,无可用程序,无法重写,郁闷啊!机身码AUZ2Z2D1300914,看评价说奥迪chorus音质还不错,实在想领略,恳请坛中各位大侠指点-----解码或改成无码。图片是借用的,机器与图片一致。
572 点
562 ¥
发表于 2012-11-13 21:51 | 显示全部楼层
不明白无可用程序,无法重写
既然读出数据,那就根据数据去算
65
1624 点
1567 ¥
发表于 2012-11-13 22:32 | 显示全部楼层
请遵守下列序列的解码:
1。切换收音机上按1按钮,在显示
出现“安全”。
2。按个按钮“TP”UND“RDS”同时,直到
“1000”出现在显示屏上。
*您必须立即释放按钮推,
因为否则的号码“1000”,将认识到
收音机作为一个错误的代码输入。
3。现在进入射频卡的码数的
预设电台推按钮1 -  4。
使用预设按钮1“千”位,推按钮2
“百”数字等。
4。按住,直到上个按钮“TP”UND“RDS”8
的汽车收音机切换到正常操作模式下。
*后的第一个项目一个错误代码号的程序可能
重复一次。失败后的第二次尝试
无线电子锁定一小时。
汽车收音机必须保持接通的持续时间
电子lock.Then两次尝试,才允许,如果
不成功,无线再次被封锁一个小时。该循环
每小时的两个项目仍然在为一个不确定的数字效果
的尝试。
65
1624 点
1567 ¥
这是谷歌翻译的
65
1624 点
1567 ¥
发表于 2012-11-13 23:15 | 显示全部楼层
Decoding (fixcode)
This car radio is electronically secured by means of a 4-digit code
number. After an interruption of the power supply the radio has
to be made operable by entering the correct code number.
Refer to the Radio Card included in the pack to obtain the code
number
Please observe the following sequence for the decoding:
1. Switch the radio on by pressing the button 1, in the display there
appears "SAFE".
2. Press the push-buttons "TP" 7 und "RDS" 8 simultaneously until
"1000" appears in the display.
* You must then immediately release the push-buttons,
because otherwise the number "1000" will be recognized by
the radio as a wrong code-entry.
3. Now enter the code number of the Radio Card by means of the
station preset push-buttons 1 - 4.
Use preset push-button 1 for the "thousand" digit, push-button 2
for the "hundred" digit etc.
4. Press and hold on to the push-buttons "TP" 7 und "RDS" 8 until
the car radio switches to the normal operating mode.
* After the first entry of a wrong code number the procedure may
be repeated once. After an unsuccessful second attempt the
radio is electronically locked for one hour.
The car radio must remain switched on for the duration of the
electronic lock.Then another two attempts are permitted until, if
unsuccessful, the radio is blocked again for one hour. The cycle
of two entries per hour remains in effect for an indefinite number
of attempts.
24 点
24 ¥
 楼主| 发表于 2012-11-13 23:41 | 显示全部楼层
谢谢指导,现在关键是不知道原密码,排列组合有一万个啊
145
908 点
803 ¥
发表于 2012-11-14 00:08 | 显示全部楼层
换机可以吗?
145
908 点
803 ¥
发表于 2012-11-14 00:31 | 显示全部楼层
机子是好的!写一个有密码的码块换上就可以了
145
908 点
803 ¥
发表于 2012-11-14 00:33 | 显示全部楼层
24 点
24 ¥
 楼主| 发表于 2012-11-14 09:54 | 显示全部楼层
回复 8# HI-FI--DIY
请问何处可以买到已写好的码块?
174
穷烧
4612 点
4155 ¥
发表于 2012-11-14 10:08 | 显示全部楼层
回复 10# bcybmlzy
把这个程序写进去就OK了密码1000.
982 点
942 ¥
发表于 2012-11-14 11:39 | 显示全部楼层
回复  HI-FI--DIY
请问何处可以买到已写好的码块?
bcybmlzy 发表于 2012-11-14 09:54
少量供应!
24 点
24 ¥
 楼主| 发表于 2012-11-14 19:13 | 显示全部楼层
感谢各位的回应,一定想办法把它弄响!再次谢谢
81 点
67 ¥
发表于 2012-11-14 21:44 | 显示全部楼层
淘宝有卖芯片
81 点
67 ¥
发表于 2012-11-14 21:46 | 显示全部楼层
淘宝有卖芯片
145
908 点
803 ¥
发表于 2012-11-14 23:13 | 显示全部楼层
回复 13# bcybmlzy
    我的编码器不是给朋友借走了可以写一个给你
108 点
108 ¥
发表于 2012-11-15 09:24 | 显示全部楼层
高端机器,梦想中
24 点
24 ¥
 楼主| 发表于 2012-11-15 10:24 | 显示全部楼层
回复 16# HI-FI--DIY
    十分感谢!
24 点
24 ¥
 楼主| 发表于 2012-11-15 10:27 | 显示全部楼层
回复 11# 山东好汉
非常感谢!明天去找朋友帮忙写入
174
穷烧
4612 点
4155 ¥
发表于 2012-11-15 12:59 | 显示全部楼层
你确定是根德的就行开机如图!
