[胆机基础] 请教下图输出电压的峰峰值
[复制链接] 查看: 5244|回复: 15
100
5541 点
5490 ¥
发表于 2012-11-12 15:56 | 显示全部楼层
本人菜鸟,不会计算,请高手帮忙算算下图输出电压的峰峰值,谢谢。
100
5541 点
5490 ¥
 楼主| 发表于 2012-11-12 15:58 | 显示全部楼层
这个图
180
Q 群 512808099
10862 点
8954 ¥
发表于 2012-11-13 07:43 | 显示全部楼层
这个图
皋城瑶珄 发表于 2012-11-12 15:58
采用简单计算:Out Vpp大约106V,Vrms大约37V
62
2556 点
2042 ¥
发表于 2012-11-13 14:18 | 显示全部楼层
回复 3# 路遥plus
路版采用简单计算竟与模拟仿真相同!
  1. 6V6GT
  2. Beam Power Amplifier
  3. EIA Base & Outline
  4. Substitute Data
  5. Preferred Substitutes ......................... 7408
  6. Substitutes ................................... 1614
  7. -------------------------------
  8. Application
  9. -------------------------------
  10. Glass octal type used as output amplifiers in automobile, battery-operated, and other receivers in which reduced plate-current drain is desirable. Requires octal socket and may be mounted in any position.
  11. -------------------------------
  12. It is equivalent in performance to type 6AQ5. Refer to type 6AQ5 for characteristic curves.
  13. Mechanical Data
  14. -------------------------------
  15. Bulb .......................................... T-9
  16. Base Type ..................................... Int or short Int Octal
  17. EIA Outline ................................... 9-11 9-41
  18. EIA Base ...................................... 7S
  19. Mounting Position ............................. Any
  20. Electrical Data
  21. -------------------------------
  22. Heater Voltage ................................ 6.3 V
  23. Heater Current ................................ 0.45 A
  24. Maximum Heater-Cathode Voltage
  25.   Heater Positive with Respect to Cathode
  26.     DC Component .............................. 90 V
  27.   Heater Negative with Respect to Cathode
  28.     DC Component .............................. 90 V
  29. Direct Interelectrode Capacitances (approx)
  30. Pentode
  31. -------------------------------
  32. Input ......................................... 9.5 pf
  33. Output ........................................ 7.5 pf
  34. Grid to Plate ................................. 0.7 pf
  35. Maximum Ratings (Design Center Values)
  36. Pentode
  37. -------------------------------
  38. Plate Voltage ................................. 315 V
  39. Grid No. 2 Voltage ............................ 285 V
  40. Plate Dissipation ............................. 12 W
  41. Grid No. 2 Dissipation ........................ 2 W
  42. Characteristics and Typical Operation
  43. Class A Amplifier
  44. -------------------------------
  45. Plate Voltage ................................. 180 V
  46. Grid No. 2 Voltage ............................ 180 V
  47. Grid No. 1 Voltage ............................ -8.5 V
  48. Peak Grid No. 1 Voltage........................ 8.5 V
  49. Plate Resistance (approx) ..................... 58K Ω
  50. Transconductance .............................. 3700 ?
  51. Plate Current (Zero Signal) ................... 29 mA
  52. Plate Current (Maximum Signal) ................ 30 mA
  53. Grid No. 2 Current (Zero Signal) .............. 3 mA
  54. Grid No. 2 Current (Maximum Signal) ........... 4 mA
  55. Load Resistance ............................... 5.5K Ω
  56. Power Output (approx) ......................... 2 W
  57. Total Harmonic Distortion ..................... 8 %
  58. Class A Amplifier
  59. -------------------------------
  60. Plate Voltage ................................. 250 V
  61. Grid No. 2 Voltage ............................ 250 V
  62. Grid No. 1 Voltage ............................ -12.5 V
  63. Peak Grid No. 1 Voltage........................ 12.5 V
  64. Plate Resistance (approx) ..................... 52K Ω
  65. Transconductance .............................. 4100 ?
  66. Plate Current (Zero Signal) ................... 45 mA
  67. Plate Current (Maximum Signal) ................ 47 mA
  68. Grid No. 2 Current (Zero Signal) .............. 4.5 mA
  69. Grid No. 2 Current (Maximum Signal) ........... 7 mA
  70. Load Resistance ............................... 5K Ω
  71. Power Output (approx) ......................... 4.5 W
  72. Total Harmonic Distortion ..................... 8 %
  73. Class A Amplifier
  74. -------------------------------
  75. Plate Voltage ................................. 315 V
  76. Grid No. 2 Voltage ............................ 225 V
  77. Grid No. 1 Voltage ............................ -13 V
  78. Peak Grid No. 1 Voltage........................ 13 V
  79. Plate Resistance (approx) ..................... 77K Ω
  80. Transconductance .............................. 3750 ?
  81. Plate Current (Zero Signal) ................... 34 mA
  82. Plate Current (Maximum Signal) ................ 35 mA
  83. Grid No. 2 Current (Zero Signal) .............. 2.2 mA
  84. Grid No. 2 Current (Maximum Signal) ........... 6 mA
  85. Load Resistance ............................... 8.5K Ω
  86. Power Output (approx) ......................... 5.5 W
  87. Total Harmonic Distortion ..................... 12 %
  88. Class AB1 Amplifier
  89. -------------------------------
  90. Plate Voltage ................................. 250 V
  91. Grid No. 2 Voltage ............................ 250 V
  92. Grid No. 1 Voltage ............................ -15 V
  93. Peak Grid No. 1 Voltage........................ 30 V
  94. Plate Resistance (approx) ..................... 60K Ω
  95. Transconductance .............................. 3750 ?
  96. Plate Current (Zero Signal) ................... 70 mA
  97. Plate Current (Maximum Signal) ................ 79 mA
  98. Grid No. 2 Current (Zero Signal) .............. 5 mA
  99. Grid No. 2 Current (Maximum Signal) ........... 13 mA
  100. Load Resistance ............................... 10K Ω
  101. Power Output (approx) ......................... 10 W
  102. Total Harmonic Distortion ..................... 5 %
  103. Class AB1 Amplifier
  104. -------------------------------
  105. Plate Voltage ................................. 285 V
  106. Grid No. 2 Voltage ............................ 285 V
  107. Grid No. 1 Voltage ............................ -19 V
  108. Peak Grid No. 1 Voltage........................ 38 V
  109. Plate Resistance (approx) ..................... 65K Ω
  110. Transconductance .............................. 3600 ?
  111. Plate Current (Zero Signal) ................... 70 mA
  112. Plate Current (Maximum Signal) ................ 92 mA
  113. Grid No. 2 Current (Zero Signal) .............. 4 mA
  114. Grid No. 2 Current (Maximum Signal) ........... 13.5 mA
  115. Load Resistance ............................... 8K Ω
  116. Power Output (approx) ......................... 14 W
  117. Total Harmonic Distortion ..................... 3.5 %
  118. Class C Amplifier/Oscillator
  119. -------------------------------
  120. Plate Voltage ................................. 300 V
  121. Grid No. 2 Voltage ............................ 200 V
  122. Grid No. 1 Voltage ............................ -45 V
  123. Grid No. 1 Current ............................ 2.5 mA
  124. Plate Current ................................. 60 mA
  125. Grid No. 2 Current ............................ 7.5 mA
  126. Driving Power ................................. 0.3 W
  127. Power Output (approx) ......................... 12 W
  128. Class C Modulated Amplifier (Plate)
  129. -------------------------------
  130. Plate Voltage ................................. 250 V
  131. Grid No. 2 Voltage ............................ 200 V
  132. Grid No. 1 Voltage ............................ -45 V
  133. Grid No. 1 Current ............................ 2 mA
  134. Plate Current ................................. 60 mA
  135. Grid No. 2 Current ............................ 6 mA
  136. Driving Power ................................. 0.4 W
  137. Power Output (approx) ......................... 10 W
复制代码
6V6推动电路
输出电压
输入阻抗
输出阻抗
100
5541 点
5490 ¥
 楼主| 发表于 2012-11-13 19:12 | 显示全部楼层
回复 3# 路遥plus
谢谢路版,如果需要输出峰峰值170V,电路还需要做哪些调整?
100
5541 点
5490 ¥
 楼主| 发表于 2012-11-13 19:16 | 显示全部楼层
回复 4# mld
谢谢,再麻烦兄弟帮忙算下如果供电350V,屏极负载、阴极电阻多大能输出峰峰值170V?
62
2556 点
2042 ¥
发表于 2012-11-13 22:06 | 显示全部楼层
回复 6# 皋城瑶珄
你要的这个170Vp-p值应该闭环考虑才是,单元电路在插入系统后情况会很不一样的...
波形图:
电路图:
测试值:
  1. Harmonic  Frequency         Fourier         Normalized         Phase          Normalized
  2. Number   [Hz]           Component         Component        [degree]        Phase [deg]
  3.     1   1.000e+03        8.616e+01        1.000e+00         -179.61°        0.00°
  4.     2   2.000e+03        3.270e-01        3.795e-03           90.37°      269.97°
  5.     3   3.000e+03        2.712e-02        3.148e-04         -178.39°        1.22°
  6.     4   4.000e+03        2.286e-03        2.653e-05          -44.46°      135.15°
  7.     5   5.000e+03        6.265e-03        7.272e-05            2.41°      182.01°
  8.     6   6.000e+03        1.190e-03        1.381e-05          -17.19°      162.42°
  9.     7   7.000e+03        2.815e-03        3.267e-05         -174.34°        5.26°
  10.     8   8.000e+03        7.763e-04        9.010e-06           12.41°      192.02°
  11.     9   9.000e+03        3.535e-03        4.103e-05            4.26°      183.87°
  12. Total Harmonic Distortion: 0.380953%
  13. ------------------------------------------
  14. v_in: PP(v(in))=21.9945 FROM 0 TO 0.005
  15. v_out: PP(v(out))=172.323 FROM 0 TO 0.005
复制代码
180
Q 群 512808099
10862 点
8954 ¥
发表于 2012-11-14 04:07 | 显示全部楼层
回复  路遥plus
路版采用简单计算竟与模拟仿真相同!6V6推动电路
输出电压
输入阻抗 ...
mld 发表于 2012-11-13 14:18
呵呵,因为LZ的电路已经给出屏流,我就偷偷懒,用下式估算:
Vo= 15mA x 10K x 25%=37.5Vrms
Vpp=37.5Vrms x 2.828=106Vpp
如果效率按27.5%算,那就真的与仿真数值差不多一样了:
Vo=15 x 10 x 27.5%=41.25Vrms = 116.65Vpp
取25%虽然保守了些,但输出信号失真度相对就小些。
62
2556 点
2042 ¥
发表于 2012-11-14 13:17 | 显示全部楼层
...因为LZ的电路已经给出屏流,我就偷偷懒,用下式估算:
取25%虽然保守了些,但输出信号失真度相对就小 ...
路遥plus 发表于 2012-11-14 04:07
这些都是以前学过的,看来我得回头恶补...
100
5541 点
5490 ¥
 楼主| 发表于 2012-11-14 17:09 | 显示全部楼层
回复 8# 路遥plus
  那计算出的116V峰值,是否和下图的动态阻容曲线图Q点是一样的?
100
5541 点
5490 ¥
 楼主| 发表于 2012-11-14 17:14 | 显示全部楼层
回复 9# mld
请老兄看看
用这个图来推单端300B的,该300B栅负压为-85V/屏流80MA,经过下图红线改动后推300B有无问题?
【6J8P阴极加了旁路电容】【6P6P推动改成400V电压供电】
峰值改成175VP-P/20MA/栅负压-16V
180
Q 群 512808099
10862 点
8954 ¥
发表于 2012-11-14 17:19 | 显示全部楼层
回复  路遥plus
皋城瑶珄 发表于 2012-11-14 17:09
是的.
100
5541 点
5490 ¥
 楼主| 发表于 2012-11-14 21:05 | 显示全部楼层
回复 12# 路遥plus
请斑竹看看这张图骑马6N8VPP是否能推动11楼的300B,
画红圈是推动部分,该极Vrms  和VPP 分别为多少?
180
Q 群 512808099
10862 点
8954 ¥
发表于 2012-11-15 03:48 | 显示全部楼层
回复  路遥plus
画红圈是推动部分,该极Vrms  和 ...
皋城瑶珄 发表于 2012-11-14 21:05
这个SRPP推动电路所标的阴极电压应该是错的(1.7V/4.7K=0.36mA???),实际上应该是1.3mA左右才对。
这个电路大约可以输出75Vrms即210Vpp左右。应该可以推得动后面的300B,但推得好不好就要试过先知。
100
5541 点
5490 ¥
 楼主| 发表于 2012-11-18 20:08 | 显示全部楼层
回复 14# 路遥plus
请教版主这个骑马咋算的?
RK1/RK2是4.7K,其他咋算????????????
    阴极电阻
RL = 负載(SRPP为定负载)
Rk1 = Rk2 = (2RL+ ra) / mu
靜態电流
Iq = HT / (2ra + 2muRk)
输出阻抗
Zout = (ra + 2Rk)[ra+Rk(mu+2)] / [2ra + 2Rk (mu + 2)]
放大量:
∵ 2Iq  ←  每管
    2(2Iq)RL = Eo(输出)
       2IqRk = Ei(输入)
∴ A = Eo / Ei
电压方面尽量靠近最大工作点
下面是另位版主算式,俺贴过来没有图摸不清楚咋算骑马推动???????????
阴极电阻
RL = 68KΩ = Rg(300B)
Rk1 = Rk2 = (2*68KΩ+44KΩ)/70 = 2.57KΩ
* * 或用上面方法定 Rk,如: 1.8KΩ
靜態电流
Iq = 500V/(2 x44K+2x70*2.57) = 1.12mA
* * Iq = 500V/(2 x44K+2x70*1.8K) = 1.47mA
输出阻抗
Zout = (44K+2x2.57K)x[44K+2.57Kx(70x2)]/[2x44K+2x2.57Kx(70+2)]
Zout = 24.57KΩ
* * Zout = (44K+2x1.8K)x[44K+1.8Kx(70x2)]/[2x44K+2x1.8Kx(70+2)]
* * Zout = 23.8KΩ
放大量:
∵ 2Iq  ←  每管
    2(2Iq)RL = Eo(输出)
    2x(2x1.12mA)x68K = 304.6V(输出)
* *     2x(2x1.47mA)x68K = 399.84V(输出)
       2IqRk = Ei(输入)
       2x1.12mAx2.57K = 5.76V(输入)
* *        2x1.47mAx1.8K = 5.3V(输入)
∴ A = Eo / Ei
∴ A = 304.6V/5.76V = 53倍
* * ∴ A = 399.84V/5.3V = 75.44倍
86
282 点
213 ¥
发表于 2012-11-24 19:41 | 显示全部楼层
兄弟。你好!刘际军要你给他打个电话
