[分立后级] Hi-End胆结石放大器
[复制链接] 查看: 20373|回复: 73
145
2672 点
2278 ¥
发表于 2012-10-23 15:46 | 显示全部楼层
145
2672 点
2278 ¥
 楼主| 发表于 2012-10-23 15:49 | 显示全部楼层
2734 点
2797 ¥
发表于 2012-10-23 15:59 | 显示全部楼层
顶起看看。
2734 点
2797 ¥
发表于 2012-10-23 16:03 | 显示全部楼层
对电源要求高。
4595 点
4559 ¥
发表于 2012-10-23 16:09 | 显示全部楼层
真是个疯狂的电路
垃圾佬
3110 点
3078 ¥
发表于 2012-10-23 20:40 | 显示全部楼层
偶合变压器难搞
瞎烧、便宜烧……
3683 点
3654 ¥
发表于 2012-10-23 22:27 | 显示全部楼层
又在玩高压的了!!!
117
1194 点
1174 ¥
发表于 2012-10-23 22:47 | 显示全部楼层
又开始烧音频牛了,,,这个更hi的贵。。。
700 点
695 ¥
发表于 2012-10-23 23:00 | 显示全部楼层
有想法啊!不错的想法A!
87
职业侠客 当前在线
929 点
505 ¥
发表于 2012-10-23 23:22 | 显示全部楼层
老兄,描下效果???
1459 点
1375 ¥
发表于 2012-10-24 00:12 | 显示全部楼层
回复 1# zhainm
    那个网站里面的电路用的都是超级贵的元件。
6414 点
5884 ¥
发表于 2012-10-24 03:13 | 显示全部楼层
讨厌Hi_end,没好感!
文明人,别扔砖头啊
145
2672 点
2278 ¥
 楼主| 发表于 2012-10-24 07:51 | 显示全部楼层
回复 10# 木棉花
首帖的超链里有具体的描述
145
2672 点
2278 ¥
 楼主| 发表于 2012-10-24 08:20 | 显示全部楼层
ZT---原作者的描述:
This an "End" level design so, like the Phono End and DAC End, it give the max sonic performances.
Now you may be perplexed about a hybrid design if you are a purist of vacuum tubes but I tell you all my friends are shocked by the result of this amplifier.
In a direct comparison with the my new 813-GM70 SE, the Hybrid 2010 version 2 and the PP2010, the difference is huge and it is very difficult to return to hear these other amplifiers.
All sounds are clear and detailed with incredible speed issue that leaves you speechless.
In the past 20 years I have made dozens of amplifiers with different topologies, but the results obtained with this was totally unexpected and unexplained.
I suggest this project to all those who want a definitive amplifier because it can be used to hear any kind of music and it drive any kind of loudspeakers without problems (multi-way and full-range).
A great experience is not required for this project because the assembly is very close to an electrical system rather than an electronic amplifier.
370 点
329 ¥
发表于 2012-10-24 09:33 | 显示全部楼层
回复 14# zhainm
91
业余侠客 当前在线
313 点
640 ¥
认证会员
发表于 2012-10-24 09:59 | 显示全部楼层
还不错的
1127 点
1075 ¥
发表于 2012-10-24 11:09 | 显示全部楼层
686 点
681 ¥
发表于 2012-10-24 19:50 | 显示全部楼层
是一妙招,估计音色很好,只是对零件要求太高太贵了。
1794 点
1550 ¥
发表于 2012-10-24 21:25 | 显示全部楼层
小牛机。
1227 点
975 ¥
发表于 2012-10-24 21:33 | 显示全部楼层
楼主大哥,你这个线路我也想过,略有所不同。但是1058静态能到多少A。这样的推挽输出功率太难做了。下面几个电阻也是吃功率的。
