- 15
- 15 小时
- 2013-5-18
- 40
- 261324
- 13
- 15 点
- 15 ¥
- 2010-11-15
楼主 |
发表于 2012-10-12 14:11
显示全部楼层
这个没有找到中文资料
Component, 3-Way, Tweeter, Mid-Range Speaker, 6" x 9", 200 Watt, Non-Powered
Details
Released 3 years ago
Nominal Power Handling 200 Watt RMS
Car Speaker Function Tweeter
Mid-Range Speaker
Powered Non-Powered
Woofer Material Poly / Plastic
Poly / Plastic
Car Speaker Type Component
Elements 3-Way
Enclosure Non-Enclosed
Frequency Response 25 Hz - 20 kHz
25 Hz - 20 kHz
Impedance 4 ohm (Dual Coil)
4 ohm (Dual Coil)
MPN as-69
AS69V
Magnet Material Neodymium
Sensitivity 95 dB
95 dB
Size 6" x 9"
Top Mounting Depth 3.50 In. |
