我做的6C33C-B耳放
[复制链接] 查看: 6871|回复: 2
338 点
85 ¥
发表于 2005-1-16 10:40 | 显示全部楼层
6C33C-B耳放<img src="attachments/dvbbs/2005-1/2005116103913449.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-1/2005116103913449.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-1/2005116103944187.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-1/2005116103944187.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-1/200511610400584.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-1/200511610400584.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
电路图中下端的栅极电阻(680K)画错了,应该接-75V
2555
管理员 当前离线
Rank: 9Rank: 9Rank: 9
14142 点
3154 ¥
发表于 2005-1-19 20:11 | 显示全部楼层
<img src="attachments/dvbbs/2005-1/200511610416103.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-1/200511610416103.jpg\');}" onmousewheel="return imgzoom(this);" alt="" /><img src="attachments/dvbbs/2005-1/2005116104118809.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-1/2005116104118809.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
338 点
85 ¥
 楼主| 发表于 2005-2-20 09:16 | 显示全部楼层
6C33C-B耳放(终结调试篇)
    春节假期,回了一趟老家,年初三就匆匆往回赶,不为别的:6C33耳放装好多时,年终工作太忙没来得及仔细调整,只能趁年假的最后几天来一解心中之结。。。。调试没有想象的那么顺利,前级电路一改再改,有三个晚上都呆在33层空无一人的办公楼里,迎接着大楼保安员不解的目光。。。。其间先后解决了交流哼声问题、前级动态问题以及末级工作点等问题。终于可以接上耳机好好欣赏音乐啦。。。以下对调试过程作一个小结:
一、交流哼声及其解决办法:
    本机上电测试,就发现有很讨厌的交流哼声,开始还担心是电源变压器、扼流圈、输出变压器安装得太拥挤产生了互感,如果是这样,这个结构就无可救药啦。。。子木提醒我:检查一下电源,我就从电源入手---用示波器测量发现:末级直流高压的纹波很大,而且扼流圈很烫,原来这个扼流圈的额定电流是300MA,现在整机电流已经达到400MA了,很可能是出现了磁饱和导致电感量急剧下降。。。好在末级采用了可以调整的固定偏压结构,把负压调高一点,使得总电流下降到300MA,果然纹波下降了许多!
    这时接上耳机试听,哼声是减少了不少,但是还是能明显听得到。。。我的前级灯丝绕组是6.3V中心抽头(3.15处)的,原来接地,由于SRPP的上管阴极电位将近90V,灯丝电位太低就会形成一个“灯丝--阴极”的干扰电子发射,而且受到50HZ的交流调制。。。
    我把供给前级放大的高压(+360V)通过一个330K和150K的电阻分压,得到一个+110V左右的电压,再把原来灯丝绕组的中心抽头接到这个分压点上,开机再试听。。。。哈哈,交流哼声彻底消失啦!(实测在300欧姆输出端上的总输出纹波只有不到3MV)
二、前级放大的动态:
   前级放大的管子,开始选定了俄罗斯的6922,这也是国内耳放较热门的前放管。后来又买了一对菲利普的6DJ8,替补的还有俄罗斯的6H23,以及国产管曙光12AU7。
   用6922和6DJ8作的改进型的SRPP无论是波形失真还是频响特性都不错,但是用示波器仔细观测:许多前辈所提到过的超低频失调出现了,也就是SRPP的中点电位有一个不规则的缓慢变化,由于其周期很慢,耳机是听不到的,但是如果末级的低频响应很好,这个超低频是可以使耳机的音圈偏移中心位置的!
   后来又试装了标准型的SRPP电路,这个现象依然存在,尤其是中间的推动级用了直接耦合,使得这个问题更加突出。。。干脆就回到最初的单三级管放大吧!
   三极管放大电路是用的标准电路,为了引入负反馈,阴极没有加旁路电容,开环测试发现:这个旁路电容不加,又没有负反馈的时候,波形失真严重!而且有一个很有趣的现象:当输入比较小时,失真度小,当信号加大到某一个数量时,失真达到最大值,再加大信号失真度反而下降了。。。。我担心是阴极完全不加电容造成这样的情况,就把阴极电阻改换成两个电阻串连,其中阻值较大的并联了200uF的阴极电容,较小的作为负反馈的分压电阻,但是情况虽有改善,波形仍然有类似的失真。。。
    我开始考虑是不是6922,6DJ8,6H23这一类的低栅负压(-1.5v)的动态范围不够才会这样?于是开始把输入级改成双三极管并联的形式,双管并联,放大系数加倍,内阻减少一半,更重要的是:输入动态范围也增加一倍!
    电路改完,情况果然好了许多,整机在失真度不到1%的情况下,输出功率可达4W,作为耳放哪怕是推KK也足够啦!接上耳机试听了一把,呵呵。。。几天的辛苦总算没有白费,总算找到了那份每一个Diyer都孜孜以求的欣喜。。。。。。
    最后为了对比,我又修改了灯丝接线,加大了阴极电阻,换上了曙光出口装的12AU7,不试则已,一试就把过去对国产管不好声的偏见抛到了九霄云外!经测试,开环的失真度比菲利普的6DJ8小一倍多,反复对比试听(每次要换阴极电阻,改接灯丝,有多麻烦!),。。。我那170米一对请来的菲利普6DJ8看来只能束之高阁啦!
    接下来的几个小时是用示波器,失真度测试仪对栅偏压、屏级负载电阻和负反馈量的仔细调校,指导思路是:
    *保证足够的放大增益;
    *最佳的动态摆幅;
    *最低的失真度;
    调试中发现:没有一个典型参数是可以套用的,要使得你的放大器进入最佳的状态,你非得对它的各种参数(包括屏压、栅偏压、负载电阻)进行一番调试!
    最后的结果是:当输入为1Vp-p时,第一级前放(12AU7)屏极输出8.8Vp-p,中间推动级(6H8C)的输出为120Vp-p(开环)。开环时的前级(包括推动级)总失真度为小于2.6%(120Vp-p)。
三、6C33C-B末级工作点调试:
   我原来设定的末级工作点为200MA,但是限于机箱的安装面积,扼流圈只能装得下一个300MA 8H 的,这样一来只能把每只管子的工作点下调到150MA,为了推动全频喇叭,还有必要对输出功率的潜力进行极限探索。我只好先去掉一个声道,在不同的工作点下以失真度不大于1%为条件进行测试,结果发现:当末级电流调到200MA时,1%失真的输出功率已经可以达到8W,进一步加大电流:250MA时,失真1%可以达到10W(2%时的输出功率达到了14.8W),可见这个用来推全频喇叭已经足够!我的FE166号角音箱早已静静地躺了好久了,只等甩师傅组织团购的单元。
GMT+8, 2025-9-24 09:23 , Processed in 0.144203 second(s), 10 queries , Gzip On, Redis On.
