- 285
- 973 小时
- 2024-10-7
- 50
- 16947
- 362
- 285 点
- 118 ¥
- 2007-1-5
Specification: Coda 7
System type: Two-way, bookshelf/stand-mount
Enclosure type: Reflex
Dimensions: (H x W x D): 300 x 180 x 235mm (11.8 x 7.1 x 9.3 inches)
Weight: 3.3kg (7.3 lbs)
Nominal impedance: 6 ohms
Amplifier requirements: 10-70W
Maximum Output: 109dB
Frequency response: 48Hz to 20kHz +/-3.0dB (-6dB at 42Hz)
Sensitivity: 91dB at 1m for 2.83V
Finish: Black Ash or Mahogany
System: SP3192
Drive units: B130 bass/midrange unit (SP1355), 25mm tweeter (SP1354)
Crossover network: SP2228
Specification: Coda 8
Dimensions: (H x W x D): 325 x 200 x 288mm (12.8 x 7.9 x 11.3 inches)
Weight: 4.6kg (10.1 lbs)
Amplifier requirements: 10-100W
Maximum Output: 110dB
Frequency response: 45Hz to 20kHz +/-3.0dB (-6dB at 39Hz)
Finish: Black Ash or mahogany
System: SP3194
Drive units: B160 bass/midrange unit (SP1372), 25mm tweeter (SP1354)
Crossover network: SP2240
