- 313
- 738 小时
- 2023-11-6
- 50
- 78484
- 305
- 313 点
- 303 ¥
- 2009-2-4
回复 11# yitong
1085的手册也有类似内容。
The circuit design used in the LT1083 family requires the
use of an output capacitor as part of the device frequency
compensation. For all operating conditions, the addition of
a 150μF aluminium electrolytic or a 22μF solid tantalum
on the output will ensure stability. Normally, capacitors
much smaller than this can be used with the LT1083. Many
different types of capacitors with widely varying characteristics
are available. These capacitors differ in capacitor
tolerance (sometimes ranging up to ±100%), equivalent
series resistance, and capacitance temperature coeffi cient.
The 150μF or 22μF values given will ensure stability.
When the adjustment terminal is bypassed to improve the
ripple rejection, the requirement for an output capacitor
increases. The value of 22μF tantalum or 150μF aluminum
covers all cases of bypassing the adjustment terminal.
Without bypassing the adjustment terminal, smaller
capacitors can be used with equally good results and the
table below shows approximately |
