- 1300
- 1761 小时
- 2020-1-21
- 70
- 373636
- 853
- 1300 点
- 870 ¥
- 2011-8-1
回复 18# lssir066
要看负载喇叭是几欧。
MC7106 使用说明书如是说:
POWER OUTPUT, SIX CHANNELS
100 watts per channel into 8 ohm loads, or 160 watts per channel into 4 ohm loads minimum sine wave continuous average power output per channel, all channels
operating.
The output RMS voltage is:
28.3V across 8 ohms 25.2V across 4 ohms
POWER OUTPUT,
TWO CHANNELS BRIDGED
320 watts into an 8 ohm load, minimum sine wave continuous average power output.
The output RMS voltage is: 50.6V across 8 ohms
OUTPUT LOAD IMPEDANCE
8 or 4 ohms, for all six separate channels 8 ohrns, Bridged operation |
