- 31
- 27 小时
- 2013-9-17
- 40
- 480160
- 31
- 31 点
- 31 ¥
- 2012-3-13
Excellent Entry Level Monitors August 5, 2008
By Greg A. Tirevold VINE™ VOICE
The HS80M monitor gives you built in power, room adjustment gain controls and good sound. While monitors are probably the most subjective thing you buy for your home or project studio. You usually don't have the option of actually bringing home 2 or 3 pairs of monitors and picking the one that performs best in your space so reputation plays a large role in the decision. These are excellent entry level monitors that will not disappoint you if you really understand what monitors are supposed to do.
I have mine mounted on a set of Auralex MoPad absorbers on top of 36" monitor stands and the absorbers make a big difference. Remember that the room you are listening in plays as big, if not bigger role in what you hear than the monitors you are using. Look into getting some basic acoustic treatments to tame the pumped up bass and harsh treble reflections you can get in most house sized rooms. Put yourself in an equilateral triangle with your head at one apex and the speakers at the other two, with tweeters at ear level facing in at you for the proper stereo image. When you get it right the sound seems to hang in midair about 4-5 feet in front of you and you can't seem to hear anything coming from either speaker unless the music is panned hard left or right.
These monitors have MORE than enough power to set your ears ringing if your not careful so don't treat them like your computer's multimedia speakers and dial up the volume. Start low and remember 83db is the "standard" intensity for monitoring.
So if your in the market for excellent quality, entry level monitors then these would be a fine choice. Also look in into KRK Rockits, Wharfedale Diamond 8.2 and Adam A5 monitors for others of quality you may like. |
