146 点
140 ¥
发表于 2012-2-11 10:32 | 显示全部楼层
新一代的USB解码器已经上市一年多,技术成熟,HIFIDIY可以量产了啊,本人的解码器也该升级了,茂伦TENOR TE7022L  TE8802L的指标远远高于pcm2704系列, 重要的是支持USB2.0全速总线。高清电影声音不卡了。 希望早日,买到你们的产品,谢谢啊, 以下是指标,不翻译了 很简单的。在淘 宝已经很多人在卖7022产品,看不到 HIFIDIY,,用了你们的 E6音箱 很是喜欢,继续用你们的产品。台湾人做出的芯片,怒自己人做不出来。TENOR TE7022L  :USB 2.0 Full Speed compliant & USB Audio Class 1.0 supported
• 16/24 bit Resolutions supported
• 8/16/32/44.1/48/96 KHz sampling rates supported
• 2-input channels and 2-output channels supported by one I2S pairs with independent sample rate
• Built in IEC60958 professional S/PDIF TX & RX, AES/EBU supported
• 6 GPI pins for HID function
• Built-in ROM for USB descriptor
• One I2C master port for external EEPROM for advance feature
• PLL integrated to support single 12MHz crystal operation
• 3.3V Operation Voltage
• 48pin LQFP package
• PB-Free
TE8802L provides a very flexible USB2.0-based audio & multimedia solution. Interleaved 2-channel input and output with 16/24-bit resolution and 44.1/48/88.2/96/176.4/192K sample rate are supported.
• USB2.0 High-Speed device supporting Audio Class v2.0
• USB2.0 Full-Speed device supporting Audio Class v1.0
• Audio Features
• 2-Inputs support by one I2S pairs with 128/256 Fs
• 2-Output support by one I2S pairs with 128/256 Fs
• Adaptive/Asynchronous Mode supported
• High-Speed mode support Adaptive/Asynchronous
• Full-Speed mode support Adaptive only
• Resolutions support 16/ 24-Bit with sampling rates support 44.1/48/88.2/96/176.4/192KHz
• Built in one IEC60958 professional 24 bit/96KHz S/PDIF RX
• Built in one IEC60958 professional 24 bit/192KHz S/PDIF TX
• One set of master I2C ports
• Two sets of standard MPU-401 compliant MIDI Tx/Rx pair by UART with pass-thru.
• Offer customized driver for Windows OS
• 1.8V core, 3.3V analog and I/O (3.3V tolerant)
• LQFP-128 package
• PB-Free
146 点
140 ¥
 楼主| 发表于 2012-2-14 19:57 | 显示全部楼层
怎么都没人一起买啊
31 点
31 ¥
发表于 2012-2-15 16:40 | 显示全部楼层
顶一下,也在关注TE7022L
31 点
31 ¥
顶一下,也在关注TE7022L
146 点
140 ¥
 楼主| 发表于 2012-2-15 19:25 | 显示全部楼层
哪个朋友 听过TE7022L 的呻吟,,我只有pcm2704+dir9001+cs4398的 解码器,听了一年多了,想升级USB解码器,,,目前 只有TE7022L 支持USB2.0全速,,,不知道7022 +pcm1793呻吟怎么样
940 点
460 ¥
发表于 2012-2-15 22:02 | 显示全部楼层
我听过,USB就别指望声音好了。
633 点
625 ¥
发表于 2012-2-16 09:00 | 显示全部楼层
我听过7022转同轴+8805+1955解码比主板同轴+8805+1955解码好。
946 点
935 ¥
社区贡献 乐于助人
发表于 2012-2-16 11:04 | 显示全部楼层
我听过,USB就别指望声音好了。
kelan 发表于 2012-2-15 22:02
    说得对,指望这种低成本的USB芯片,很难出好声的
146 点
140 ¥
 楼主| 发表于 2012-2-16 23:11 | 显示全部楼层
只有富人才能享受高品质的数字音乐吗?? TE7022L 做的好,呻吟应该不错的,USB2.0的速率用来放呻吟足够了,带宽也够, 很多专业调音 也再 向 USB 转变, 方便,xp ,win7,mac 都支持 usb
泛泛之辈
375 点
371 ¥
发表于 2012-2-17 10:52 | 显示全部楼层
146 点
140 ¥
 楼主| 发表于 2012-2-17 19:27 | 显示全部楼层
pcm2704 解码器得到许多人认可,出色的音质 在高端解码器也在用pcm2704,,怎么说USB 出不了好声音,pcm2704是 2008年的芯片, te7022 新一代的芯片 难道会比 旧的 更差?? 那工厂生产的芯片卖给谁?? TE8802L 目前只供应一线大厂, 小厂 还拿不到芯片, TE8802L 定位音乐制作人
81
1287 点
1297 ¥
发表于 2012-8-17 10:13 | 显示全部楼层
TE8802的同轴输出,胜于CM6631与数字时代的同轴输出?
79 点
77 ¥
发表于 2012-8-17 12:00 | 显示全部楼层
顶一下,我也打算升级解码器
