- 371
- 1761 小时
- 2023-11-20
- 50
- 33268
- 977
- 371 点
- 346 ¥
- 2008-1-2
http://www.google.com.hk/url?sa= ... Ta0LDKU4rT_j7M7LBPQ
这个应该是了
Interlaced YUV 4:2:2 input video signal compliant with ITU-R BT. 601 (8-bit
YCbCr) and ITU-R BT. 656 standards
Support 2 port of ITU-R BT. 656 or 601 8-bit inputs.
Support 8-bit serial RGB input.
Support 18-bit parallel RGB input.
Support NTSC/PAL TV system.
Support 4 different horizontal resolutions, 480, 960, 1200, and 1440.
Built-in gamma correction function.
Provide source and gate drivers control timing.
Built-in 8 zoom in/zoom out display modes.
Shift clock signals for the source driver (3-φ clock).
Provide flip and mirror scan control.
Built-in 2 channel PWM DC-DC booster control circuit for VGH and VGL
Digital IO voltage: 3.3V or 5V.
Operation voltage: 5V.
64 pin LQFP . |
