440
369 点
361 ¥
发表于 2012-1-9 20:51 | 显示全部楼层
请问HTR5630和RX-V340 是不是同一款功放?遥控是否通用???请各位大侠帮帮忙!!!!!!!!
440
369 点
361 ¥
 楼主| 发表于 2012-1-10 11:15 | 显示全部楼层
没有知道的吗?????
271
3716 点
2166 ¥
发表于 2012-1-10 11:26 | 显示全部楼层
What Is The Difference Between The RX-V Line And The HTR Line?
There are many similarities between these two product lines. The RX-V line and the HTR line are produced in the same Yamaha factory using the same high quality parts throughout. The RX-V and equivalent HTR models have the same warranty periods, the same manufacturer's suggested retail price, the same features, and the same remote control units.
There is a cosmetic difference found on the front panels of these two lines. The RX-V line maintains the traditional white colored lettering normally found on most Yamaha components, while the HTR line provides a slightly different approach. Yamaha has created a new look by using gold colored lettering in selected areas on the HTR receiver series. However, both the RX-V line and the HTR line feature the same high quality front panel construction.
The amplifiers in the HTR and RX-V units are identical but rated differently to comply with the accepted measurement standards of their respective channels of distribution. Both ratings are FTC approved and are designed to handle the dynamics of today's audio and video sources. The RX-V line has the power amplifiers rated from 20-20000 Hz. The HTR line has the power amplifiers rated at 1000 Hz. Both lines can reproduce the full frequency response of 20-20000 Hz.
The RX-V line is typically sold through Yamaha authorized audio/video specialty retailers, and is not available for mail order sales, phone sales, or internet sales.
The HTR line is sold through mass merchants, catalog retailers, and department stores. You may also purchase the HTR line through the mail, by phone, or at authorized internet retailers.
All transactions must be done through the authorized Yamaha dealer network. Any purchase made from an unauthorized dealer/retailer voids the Yamaha manufacturer's warranty.
271
3716 点
2166 ¥
发表于 2012-1-10 11:27 | 显示全部楼层
按照上面的官方解释:遥控器应该是通用的
遥控玩家
52 点
51 ¥
发表于 2012-1-10 12:33 | 显示全部楼层
回复 1# 雨后天晴 基本一样的,遥控器通用,是同一款遥控
440
369 点
361 ¥
 楼主| 发表于 2012-1-10 14:58 | 显示全部楼层
回复 4# dogjam
   非常感谢你的回复!!!
