119 点
122 ¥
发表于 2011-11-11 16:53 | 显示全部楼层
转帖如下:
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
Hi Guys,
There's a new addition to "The Wire" series of projects I've been working on lately.
It's push-pull amplifier based on the LME49830 front end which drives a pair of ACD101NDD and ACD103PDD lateral mosfets. It's immensely versatile in that you can run essentially any rail voltage from about +/- 10V up to about +/-90V on the mosfets and get anywhere from 1W to 400W of output depending on the load and the rails. This is an amp that can be tailored to any situation.
You can also run the amp in class A, class AB, or class B if that's your thing.
For the input, you can run either fully balance, or with just one 0R jumper it can be configured for SE input. You can run the amplifier AC or DC coupled. There are separate supply options for running the LME49830 on higher rails than the mosfets which improves efficiency and allows for a good regulated supply for the front end. Alternatively, with a pair of 0R jumpers, you can run just a single +/- supply for both the LME and the mosfets.
The board is small enough to fit pretty much anywhere, and all you need to provide is the power supply and the heatsink! I've even got an optional regulated supply board for the LME section.
I've attached the schematic, the Excel worksheet to calculate power outputs and rails, along with the layout and a BOM.
The PCB will be a 3 layer design with a ground plane in the middle and signal routing on either side. The LME has its own heatsink and the two mosfets are mounted on a user supplied sink off the end of the board. The board measures 2.45" by 1.6" and has all the required mounting points.
I will also be running a kit with this that includes all of the parts required to build a complete amplifier. All the user will need to supply is the main heatsink and the power supply.
PCB's are going to be $12 per channel, and a full kit including all 0.1% thin film resistors, and the best caps available for this application will be $78 per channel. I've attached the price list for the amplifier kit which contains all the details.
There will be 50 boards made available, and it will be first come first serve. Please post here if you're interested in a just a board, or a board and a kit, along with how many of each. Any technical question are welcome as well!
Measurements to follow!
Cheers,
Owen
http://www.diyaudio.com/forums/s ... ateral-mosfets.html
全部资料老外都贴出来了。不知道有没有人有兴趣出套件啊? 想diy 一个玩玩。
Price List for LME AMP.pdf (24.31 KB, 下载次数: 1125)
罗宾汉
6221 点
5901 ¥
社区贡献 优秀设计 论坛版主 DIY大赛获奖
发表于 2011-11-11 17:58 | 显示全部楼层
贴片下就有些元件不好选择了。
221
4527 点
4301 ¥
发表于 2011-11-11 18:07 | 显示全部楼层
重新画板就得 谁翻译翻译啊
1451 点
1442 ¥
发表于 2011-11-11 19:13 | 显示全部楼层
下来看下
55
775 点
415 ¥
发表于 2011-11-11 21:26 | 显示全部楼层
“线AMP的”A类/ AB功放的基础上侧MOSFET的LME49830芯片
嗨,
另外有一个新的“导线”我一直在近期工作的一系列项目。
它的基础上的LME49830芯片前端驱动一双ACD101NDD ACD103PDD侧MOSFET的推挽放大器。它的巨大的通用性,你可以运行基本上由约任何轨电压+ / - 10V至+ / - 90V的MOSFET,从1W到400W的输出取决于负载和Rails。这是一个任何情况下,可以根据安培。
您还可以运行在A类,AB类或B类放大器,如果这是你的事情。
输入,可以运行,也可以充分平衡,或只是一个0R跳线,它可以配置为SE输入。您可以运行放大器的AC或DC耦合。比,提高效率,并允许一个良好的稳压电源的前端的金属氧化物半导体场效应晶体管更高的铁轨上运行的LME49830芯片有单独的电源选项。另外,与一对0R跳线,你可以运行只是一个单一的+ / - 伦敦金属交易所的金属氧化物半导体场效应晶体管的供应。
董事会是足够小,适合几乎任何地方,和所有您需要提供的电源和散热器!我什至还得到了一个可选的稳压电源板,伦敦金属交易所部分。
我附上示意图,Excel工作表来计算的输出功率和Rails,以及布局和BOM。
印刷电路板将是一个3层的设计,在中间和两边的信号路由的地平面。伦敦金属交易所都有自己的散热片和两个MOSFET上安装用户提供下沉董事会结束。董事会措施2.45“1.6”和所有必需的安装点。
我也将运行这个工具包,包括所有需要建立一个完整的放大器的部分。用户需要提供的是主要的散热片和电源。
PCB的每通道12美元,和一个完整的套件,包括0.1%的薄膜电阻,以及可用于该应用程序最好的上限将每通道78美元。我已经附加放大器套件的价格,其中包含所有的细节清单。
将提供50板,这将是先到先得。请张贴在这里,伴随着每一个有多少,如果你感兴趣的只是板,或板和套件。任何技术问题,也欢迎!
测量!
欢呼声,
欧文
用GOOGLE在线翻译的.
89 点
70 ¥
发表于 2015-1-7 11:22 | 显示全部楼层
1249 点
1144 ¥
发表于 2015-1-7 19:19 | 显示全部楼层
这个翻译和看原文差不多啊 。呵呵。。。
1974 点
1580 ¥
发表于 2015-1-8 02:54 | 显示全部楼层
原文一样看到头晕
2766 点
2667 ¥
发表于 2015-1-8 06:54 | 显示全部楼层
“线与”的A / AB类基于横向MOSFET lme49830功率放大器
嗨,伙计们,
还有“我最近工作项目线”系列新。
这是推挽放大器基于lme49830前端驱动两acd103pdd acd101ndd和横向的MOSFET。这是非常灵活,你可以运行任何轨电压约±10V至约+ / - 90V的MOSFET和得到任何地方从1W到400W的输出取决于负载和铁轨。这是一个放大器,能够适应任何情况。
你也可以在A类,AB类或B类放大器的运行,如果那是你的事。
对于输入,你可以运行完全平衡,或只是一个0R跳线,它可以配置为SE输入。您可以运行的交流或直流耦合放大器。有较高的轨道上运行lme49830比MOSFET效率提高单独的电源选项,允许一个良好的稳压电源的前端。另外,有一对或跳线,你可以运行只是一个单一的+ / -供应两LME和MOSFET。
董事会是足够小适合几乎任何地方,和所有您需要提供的是电源和散热片!我也有一个可选的稳压电源板为LME的部分。
我已经附上的Excel工作表的计算原理,输出功率和轨道,随着布局和BOM。
电路板是与地平面中的信号路由两侧3层设计。LME有其自身的散热片和两MOSFET安装在用户提供的沉了董事会的结束。董事会的措施2.45“1.6”和所有需要的安装点。
我也将运行一个包,包括所有需要建立一个完整的放大器配件。所有用户需要提供的是主要的散热片和电源。
PCB将每通道12美元,和包括0.1%的薄膜电阻的全盒,和最好的帽子可供该应用程序将每通道78美元。我已经附上包含所有细节的放大器盒价格表。
将有50个板了,它会先来先服务。如果你感兴趣的只是板请张贴在这里,或板和试剂盒,以及多少个。同时也欢迎任何技术问题!
测量遵循!
干杯,
欧文
89
2146 点
2032 ¥
发表于 2018-10-22 12:32 | 显示全部楼层
DIYAUDIO 上的资料要如何才能下载?https://www.diyaudio.com/forums/ ... 2x1000w-4ohm-2.html我需要这里的哈里森K3000功放的电路图。谢谢有人指点下,或谁有这个资料能我一下?邮箱:HZX999@163.COM
386 点
378 ¥
发表于 2018-12-16 22:20 | 显示全部楼层
正在画LME49810推3对三极管的板
因为我只有LME49810这个芯片
65
HOT
266 点
202 ¥
发表于 2019-2-2 10:50 | 显示全部楼层
看着挺简洁的
