965 点
378 ¥
发表于 2011-10-2 23:52 | 显示全部楼层
有用过绅士宝15w-8434g00的朋友吗?
看参数好像不错,想试试
天造之才,皆有其用!
5040 点
2766 ¥
社区贡献 论坛贵宾 新人进步
发表于 2011-10-3 00:02 | 显示全部楼层
把图帖上看看
965 点
378 ¥
 楼主| 发表于 2011-10-3 00:07 | 显示全部楼层
回复 2# 喇叭轩 T-S Parameters
Resonance frequency [fs] 45 Hz
Mechanical Q factor [Qms] 3.74
Electrical Q factor [Qes] 0.27
Total Q factor [Qts] 0.25
Force factor [Bl] 7.3 Tm
Mechanical resistance [Rms] 0.66 kg/s
Moving mass [Mms] 8.61 g
Suspension compliance [Cms] 1.43 mm/N
Effective diaph. diameter [D] 101 mm
Effective piston area [Sd] 80 cm²
Equivalent volume [Vas] 12.8 l
Sensitivity (2.83V/1m) 86.9 dB
Ratio Bl/√Re 3.05 N/√W
Ratio fs/Qts 180 Hz
Electrical Data
Nominal impedance [Zn] 8 L
Minimum impedance [Zmin] 7.1 L
Maximum impedance [Zo] 84.7 L
DC resistance [Re] 5.7 L
Voice coil inductance [Le] 0.8 mH
Power Handling
100h RMS noise test (IEC 17.1) 60 W
Long-term max power (IEC 17.3) 120 W
Voice Coil and Magnet Data
Voice coil diameter 25 mm
Voice coil height 13.4 mm
Voice coil layers 2
Height of gap 5 mm
Linear excursion ± 4.2 mm
Max mech. excursion ± 8 mm
Unit weight 1.2 kg
965 点
378 ¥
 楼主| 发表于 2011-10-3 00:08 | 显示全部楼层
不会压缩PDF图
绅士宝主页上有
965 点
378 ¥
 楼主| 发表于 2011-10-3 08:56 | 显示全部楼层
顶给用过的大侠看
965 点
378 ¥
 楼主| 发表于 2011-10-3 18:19 | 显示全部楼层
15W/4434G00
多少米能搞到
