- 1065
- 5382 小时
- 2022-10-31
- 70
- 235499
- 1189
- 1065 点
- 1023 ¥
- 2010-9-1
60W MosFet Audio Amplifier
R1______________47K 1/4W Resistor
R2_______________4K7 1/4W Resistor
R3______________22K 1/4W Resistor
R4_______________1K 1/4W Resistor
R5,R12,R13_____330R 1/4W Resistors
R6_______________1K5 1/4W Resistor
R7______________15K 1/4W Resistor
R8______________33K 1/4W Resistor
R9_____________150K 1/4W Resistor
R10____________500R 1/2W Trimmer Cermet
R11_____________39R 1/4W Resistor
R14,R15___________R33 2.5W Resistors
R16_____________10R 2.5W Resistor
R17_______________R22 5W Resistor (wirewound)
C1_____________470nF 63V Polyester Capacitor
C2_____________470pF 63V Polystyrene or ceramic Capacitor
C3______________47µF 63V Electrolytic Capacitor
C4,C8,C9,C11___100nF 63V Polyester Capacitors
C5______________10pF 63V Polystyrene or ceramic Capacitor
C6_______________1µF 63V Polyester Capacitor
C7,C10_________100µF 63V Electrolytic Capacitors
D1___________1N4002 100V 1A Diode
D2_____________5mm. Red LED
Q1,Q2,Q4_____MPSA43 200V 500mA NPN Transistors
Q3,Q5________BC546 65V 100mA NPN Transistors
Q6___________MJE340 200V 500mA NPN Transistor
Q7___________MJE350 200V 500mA PNP Transistor
Q8___________IRFP240 200V 20A N-Channel Hexfet Transistor
Q9___________IRFP9240 200V 12A P-Channel Hexfet Transistor
Technical data:
Output power:
60 Watt RMS @ 8 Ohm (1KHz sinewave) - 90W RMS @ 4 Ohm
Sensitivity:
1V RMS input for 58W output
Frequency response:
30Hz to 20KHz -1dB
Total harmonic distortion @ 1KHz:
1W 0.003% 10W 0.006% 20W 0.01% 40W 0.013% 60W 0.018%
Total harmonic distortion @10KHz:
1W 0.005% 10W 0.02% 20W 0.03% 40W 0.06% 60W 0.09%
Unconditionally stable on capacitive loads |
