[心得经验] [原创] CDM12 RELOADED
[复制链接] 查看: 15706|回复: 20
599 点
261 ¥
发表于 2007-2-11 15:50 | 显示全部楼层
<p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">终于转了,两个月后,我的转盘终于转了。</span><span lang="EN-US"><font face="Times New Roman">&nbsp;</font></span></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">低烧多年,音箱、后级、前级、解码器每样都做过,</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">源头的转盘(</span><span lang="EN-US"><font face="Times New Roman">CD</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">)却一直没有尝试。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">因为光头、伺服、结构这三个部分是</span><span lang="EN-US"><font face="Times New Roman">diy</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">者独自难以做好的,做不好,还不如不做。</span><span lang="EN-US"><font face="Times New Roman">&nbsp;</font></span></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">从小钳子发布准备推出转盘的消息开始,就充满了期待,终于有机会去把握声音重放的全过程了。如何去实现心目中理想的音源,一段时间里,这样那样的想法此起彼伏。</span><span lang="EN-US"><font face="Times New Roman">&nbsp;</font></span></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">收到转盘套件,没有急着动手,左看右看,上看下看,电路明白了,如何去改,心里有数了。</span><span lang="EN-US"><font face="Times New Roman">&nbsp;</font></span></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">没有原理图,也没有电路设计的宣传,这不重要,因为</span><span lang="EN-US"><font face="Times New Roman">CB</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">的信息量更大。这块PCB,即使用吹毛求疵的眼光去看,也没发现多少破绽,倒是越看越觉得转盘的完成度很高,电路设计、器件选择、布局、走线都可谓深思熟虑。从</span><span lang="EN-US"><font face="Times New Roman">CB</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">上就可以看出,设计者有着很高的理论水平,实践经验也很丰富。</span><span lang="EN-US"><font face="Times New Roman">&nbsp;</font></span></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">准备器件,按自己的想法一阵乱改,焊完板子,已是</span><span lang="EN-US"><font face="Times New Roman">12</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">月底了,</span><span lang="EN-US"><font face="Times New Roman">&nbsp;</font></span></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">一个不眠之夜后,光头发红光,上下动,不转。</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt;"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';"></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman';">看论坛上的经验,应该是排线的问题,来回
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
803 点
284 ¥
元老级
发表于 2007-2-12 00:57 | 显示全部楼层
<p>就是把74VHC74 9腳弄斷,然後第8腳接到第9腳銅泊</p><p>再來就是74HCU04 第一腳弄斷,從第一腳銅泊跳線到第3腳</p><p>是這樣嗎?[em04]</p><p>&nbsp;</p><img src="http://i163.photobucket.com/albums/t299/foryou1997/CDM12_up/cd018.jpg" border="0" alt=""/>
599 点
261 ¥
 楼主| 发表于 2007-2-12 00:25 | 显示全部楼层
<p></p><p>74VHC74</p><p>
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
<br/></p><p>74HCU04</p><p>
[原创] CDM12 RELOADED
[原创] CDM12 RELOADED
&nbsp;</p><p>板上原设计74VHC74 9脚输出,到74HCU04 1脚。</p><p>改成74VHC74 8脚输出,到74HCU04 3脚。(连线、划断的组合可以实现)</p><p>74HCU04 6反相器的分布见图,板上I2-I5的输入是并联的,如果只用其中的一部分,没用到的输入划开,接地或正电源。</p><p>前文说用I2、I3,就是因为划线方便,但I2、I3原设计是驱动平衡口的,把I2、I3输出用输出电容跨接到同轴口即可。</p><p>这样不知道说清楚了没有。</p>[em05][em05]
803 点
284 ¥
元老级
发表于 2007-2-11 23:56 | 显示全部楼层
<p>俺是菜鳥</p><p>剛好只用同軸,但不明白你的方法</p><p>能更簡易清晰指導一下嗎??</p>[em04]
599 点
261 ¥
 楼主| 发表于 2007-2-11 22:41 | 显示全部楼层
<p>下午写了前半部分,急着出差关机,晚上到地方住下,续完。</p>[em01][em01]
123 点
29 ¥
发表于 2007-2-11 19:57 | 显示全部楼层
谢谢楼主的经验,我的转盘也调试成功了。不光是光头排线,还要注意清除MCU管脚上的氧化层。
938 点
460 ¥
发表于 2007-2-11 17:23 | 显示全部楼层
石兄过奖了,我非电科出身,除了早年学了点理论外,其它电科知识均来自于实践,什么东西好不好,总是先要试试,再做评论,也希望论坛的各位仁兄,多把自己实践的经验说出来供大家分享,共同提高论坛DIY水平。
599 点
261 ¥
 楼主| 发表于 2007-2-13 13:17 | 显示全部楼层
乱改之一,附图说明
<p>黄线是建议跨接的地线,浅黄线是板子元件面已有的地线走线。黄线、浅黄线构成改后的电流返回路径。</p><p>红线、暗红线是原设计地线电流的返回路径。</p><p>
乱改之一,附图说明
乱改之一,附图说明
</p><p>[em05][em05]</p><p></p><p><br/></p>
542 点
171 ¥
发表于 2007-2-13 00:16 | 显示全部楼层
希望以后把这些有关的帖子开一个专栏就好
DIY达人
1105 点
251 ¥
发表于 2007-2-12 23:43 | 显示全部楼层
好!大家都来发挥自己的创意,让12转盘更好声.[em05]
803 点
284 ¥
元老级
发表于 2007-2-12 23:29 | 显示全部楼层
<div class="quote"><b>以下是引用<i>analog</i>在2007-2-12 11:13:00的发言:</b><br/><p>如果不划板子,不飞线就是这样。</p><p>把04的2脚也剪断。</p>[em27][em27]</div><p></p><p>LZ,我是使用Sony F717的</p><p>&nbsp;</p>[em07]
803 点
284 ¥
元老级
发表于 2007-2-12 23:27 | 显示全部楼层
<div class="quote"><b>以下是引用<i>david_hk</i>在2007-2-12 22:00:00的发言:</b><br/><p>很多謝樓主提供這些建議,要好好學習。</p><p>有沒有考慮換一換穩壓 IC 呢? LM317 換 LT317A, 7805 換 LT323,Linear Techology。</p><p>音效改善好明顯也直接,會錦上添花的。</p>[em07]</div><p></p><p>你換上的話會後悔,韻味、厚度、音樂感會少了一截</p><p>ON的LM317BTG和7805BTG是經調較指定使用的</p><p>LT的優勢在於:壓差少、誤差少、聲音相對要靜、細節要多點</p><p>但不是這台CDM12需要的</p>
76 点
2 ¥
发表于 2007-2-12 22:00 | 显示全部楼层
JBL死硬派
743 点
92 ¥
发表于 2007-2-12 12:12 | 显示全部楼层
先記下,還沒全看懂,要慢慢消化![em06][em04][em04]
599 点
261 ¥
 楼主| 发表于 2007-2-12 11:16 | 显示全部楼层
<p>什么相机、镜头?</p><p>微距这么清楚。</p>
599 点
261 ¥
 楼主| 发表于 2007-2-12 11:13 | 显示全部楼层
542 点
171 ¥
发表于 2007-2-14 00:45 | 显示全部楼层
这样的讨论对于我们装了CDM-12的朋友来说是非常正面滴,我已从中得到好处,等过完年,有空就会对我的机机改造一下
803 点
284 ¥
元老级
发表于 2007-2-13 23:33 | 显示全部楼层
<p>對了,機器我都先給它最少70小時才開始每個部份換零件測試</p><p>而測試要求是最少連續運作24小時作準</p><p>第一台轉盤都給我裝裝拆拆不少次了</p>[em06]
803 点
284 ¥
元老级
发表于 2007-2-13 23:30 | 显示全部楼层
<p>呵呵,就是補品不能亂補的意思</p><p>先要了解機器的特性,再按自己的聽感取向而作出調較</p><p>不是好零件就加進去,要是這樣,那不就是用上好零件就是好聲的機器?</p><p>因為論壇的轉盤特性是重於 背景零靜、分析好,細節多</p><p>相對於它的不足就是韻味和厚度(是相對於我手上的CDM4)</p><p>所以再用上LT系列(真品計算),會相對再提方(背景零靜、分析好,細節多)這個部份</p><p>所以我覺得加進去會進一步破壞它的平衡,我在DIGIKEY買一只LT1086要HK$20(量大)</p><p>我覺得LM317BTG比它還要來得好及平衡,在測試調聲時</p><p>我已把LT1086焊回出來換回LM317BTG</p>
76 点
2 ¥
发表于 2007-2-13 21:15 | 显示全部楼层
<div class="quote"><b>以下是引用<i>imagine</i>在2007-2-12 23:27:00的发言:</b><br/><p></p><p>你換上的話會後悔,韻味、厚度、音樂感會少了一截</p><p>ON的LM317BTG和7805BTG是經調較指定使用的</p><p>LT的優勢在於:壓差少、誤差少、聲音相對要靜、細節要多點</p><p>但不是這台CDM12需要的</p></div><p>好彩問問各位前輩,我用了兩粒 LT317於 1ppm 的時鐘上 (係三個月前CDM12未出 ,特別向網主訂購晶振的),真的如 imagine 所說細節、幼滑靚很多。</p><p>所以才想手癢癢想試改,第一次團購訂留了兩部CDM12高價版自用,一部原設計成品不會改,另一部專用來"實驗",A 或 B 比較用。</p><p>但用過 LT IC 後悔會否誇了點?不理想也最多各有所長、各有特式吧。我們一群初班友,用在合適之線路上,暫沒有這樣的反蝕........。好不好試用過後同大家分享。</p><p>[em07]</p>
