940 点
460 ¥
发表于 2007-2-8 19:33 | 显示全部楼层
<p class="MsoNormal" align="center" style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center;"></p><p class="MsoNormal" align="center" style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center;"></p><p class="MsoNormal" align="center" style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center;"><font face="黑体" size="4"><strong></strong></font></p><p class="MsoNormal" align="center" style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center;"><font size="4"><font face="黑体"><strong><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">千辛万苦,</span><span lang="EN-US">ASS1.0</span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">版前级修成正果</span></strong></font></font></p><p class="MsoNormal" align="center" style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center;"><span lang="EN-US"><p><font face="Times New Roman">&nbsp;</font></p></span></p><p><font face="Times New Roman">&nbsp;</font></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><font size="4"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">没想到一个不到</span><span lang="EN-US"><font face="Times New Roman">100</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">个原件的</span><span lang="EN-US"><font face="Times New Roman">ASS1.0</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">版前级从制版到调试成功要这么长时间,期间要费尽那么多周折,想想真是万事想着简单作着难啊!</span></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><font size="4"></font><span lang="EN-US"><p><font face="Times New Roman" size="4">&nbsp;</font></p></span></p><p><font face="Times New Roman" size="4">&nbsp;</font></p><p><font size="4"></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><font size="4"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">由于购买了黄兄的仿金嗓子和张兄的</span><span lang="EN-US"><font face="Times New Roman">KSA100</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">后级</span><span lang="EN-US"><font face="Times New Roman">CB</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">,就想着做好后级之后,前级怎么办,于是一直在网上找前级相关资料,发现各网站一窝蜂似的全以</span><span lang="EN-US"><font face="Times New Roman">ASS1.7</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">为主,给人感觉好象前级就是</span><span lang="EN-US"><font face="Times New Roman">ASS1.7</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">,真没个性,呵呵,想着我可不做这个</span><span lang="EN-US"><font face="Times New Roman">1.7</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">,偏找个其它的前级做做。东转西转,刚好遇到</span><span lang="EN-US"><font face="Times New Roman">DIY</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">-</span><span lang="EN-US"><font face="Times New Roman">M</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">(王兄)兄</span><
参与人数 1经验 +20 威望 +2 HD币 +50 贡献值 +2 收起 理由
wzy728 + 20 + 2 + 50 + 2
940 点
460 ¥
 楼主| 发表于 2007-2-9 08:45 | 显示全部楼层
<div class="quote"><b>以下是引用<i>analog</i>在2007-2-8 23:53:00的发言:</b><br/><p>blackgate NQ</p><p>&nbsp;</p><p>[em02][em02]</p><p>完了,我已经成了一个彻底的物料主义者了,看见好电容就流口水。</p></div><p></p>哈哈哈,石兄别急,回头送你电容,呵呵[em03][em03][em03]
4018 点
2282 ¥
发表于 2007-2-9 00:16 | 显示全部楼层
[em02][em02][em02]
599 点
261 ¥
发表于 2007-2-8 23:53 | 显示全部楼层
半烧
552 点
226 ¥
发表于 2007-2-8 23:34 | 显示全部楼层
[em01][em01][em03]不错,赞一个
68
晶体管配对
1278 点
93 ¥
发表于 2007-2-8 23:19 | 显示全部楼层
<p>我就是用在常温下配对好的管子,装机后在散热器温度为55度左右,管子静态电流在1A时各管的电流误差可以控制在10毫安左右,</p>
940 点
460 ¥
 楼主| 发表于 2007-2-8 22:27 | 显示全部楼层
<div class="quote"><b>以下是引用<i>sdpsc</i>在2007-2-8 21:35:00的发言:</b><br/>将左右声道的管装在一片散热器上不是更好吗?</div><p></p>就是在一起啊,老兄![em03]
940 点
460 ¥
 楼主| 发表于 2007-2-8 22:26 | 显示全部楼层
<div class="quote"><b>以下是引用<i>ligm</i>在2007-2-8 22:13:00的发言:</b><br/><p>看来我是天天在YY。</p><p>我测试过IRFP240 ,IRF610和IRF9610有上万只了,很多晶体管大电流和小电流下管子的输出曲线完全重合,我也不知道配对精度到多少,只知道我在调试A-X时,IRFP240用输出曲线完全重的管子,上机后管子电流在1000MA时误差点流可以控制在10MA以下,配对很好的IRF9610差分管可以使A-X输出的相对电压控制在10MV以下,而曲线不怎么重合(只有很小的误差)的9610做差分管,A-X输出的相对电压都快到500MV了。我测试的温度都是在室温下进行的,管子是脉冲扫描配对的,基本不受管子升温的影响。</p><p>补充说一下,你那前级管子根本不用配对。</p></div><p></p>老兄误解了,并无它意。因为朋友为我做了好几次实验,告诉我无论如何也做不到0.1%的配对精度,连1%都做不到,不是在常温下成功,升温后不成功,就是在升温时成功,但温度一变又不行了,所以才得出这前面的结论,当然,环境不同,结果不同。我非电科出身,很难在这个问题上做权威解答,也希望老兄能将在常温下配对的管子,设法加热到60-80度,差不多一般甲类功放工作的环境温度吧,看看这种情况下是否还是如常温下配对结果,如果一致,我先这里向老兄道歉。如果不一致也请老兄声明,让大家了解这一点。
68
晶体管配对
1278 点
93 ¥
发表于 2007-2-8 22:13 | 显示全部楼层
793 点
384 ¥
发表于 2007-2-8 21:35 | 显示全部楼层
73
肇庆索尼维修员
1503 点
434 ¥
发表于 2007-2-8 21:31 | 显示全部楼层
玩音响就是烧钱
133
4912 点
2799 ¥
元老级
发表于 2007-2-8 20:57 | 显示全部楼层
发烧就是不停的折腾,你这还不算辛苦!
75
音响仅是手段,音乐才是目的.
2345 点
1821 ¥
发表于 2007-2-8 20:49 | 显示全部楼层
<p>朱兄,手艺很好,文采也很好,你是我见过的非电子专业切发烧激情比我等还浓的烧友,也很专业,精神可嘉,顶一个.</p>[em01]
940 点
460 ¥
 楼主| 发表于 2007-2-8 20:15 | 显示全部楼层
<p>
[原创]千辛万苦,PASS1.0版前级修成正果
</p><p></p><p><br/><font size="4">最终制作完成的情况,注意,这个散热片小了,工作时太热了。</font></p>
940 点
460 ¥
 楼主| 发表于 2007-2-8 20:13 | 显示全部楼层
<br/><font size="4">制作过程中的照片,注意这里使用了尼龙螺丝和绝缘导热片。</font>
940 点
460 ¥
 楼主| 发表于 2007-2-8 20:10 | 显示全部楼层
<br/>
<br/>
940 点
460 ¥
 楼主| 发表于 2007-2-8 20:01 | 显示全部楼层
<p>
<br/>
<br/>
<br/></p><p>看看这些耦合电容。</p>
940 点
460 ¥
 楼主| 发表于 2007-2-8 19:54 | 显示全部楼层
<p>
</p><p>国产优质电容</p><p><br/>
<br/>原装黑金刚电容</p>
940 点
460 ¥
 楼主| 发表于 2007-2-8 19:50 | 显示全部楼层
<p>
<br/>
<br/></p><p>音色最关键的部件,场效应管和电容</p>
940 点
460 ¥
 楼主| 发表于 2007-2-8 19:44 | 显示全部楼层
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><font size="4"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">电路焊好后,检查无误即可通电试声,因为线路非常简单,不用调试即可一次出声。这里我先用耳机做负载,用两个</span><span lang="EN-US"><font face="Times New Roman">2.2K</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">电阻分流,原电路的电平输出用了</span><span lang="EN-US"><font face="Times New Roman">22</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">个电阻组成接力输出,累计阻值</span><span lang="EN-US"><font face="Times New Roman">3980.3</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">欧。交流电</span><span lang="EN-US"><font face="Times New Roman">60V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">输入,整流后约</span><span lang="EN-US"><font face="Times New Roman">85V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">,由于稳压管标值普遍高于实际输出电压,因此经稳压后输出电压约</span><span lang="EN-US"><font face="Times New Roman">58V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">,而非标值</span><span lang="EN-US"><font face="Times New Roman">60V</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">。音源用钳版的</span><span lang="EN-US"><font face="Times New Roman">CDM12</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">,找几张平时常听的</span><span lang="EN-US"><font face="Times New Roman">CD</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">,放出</span><span lang="EN-US"><font face="Times New Roman">CD</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">放音,随着音乐从耳机流出,我发现左声道无声,检查时发现输出线接反了,把地线当输出,把输出当地线了,等于给左声道短路了,还好有电容隔直,否则后果不堪设想。在调换输出后,重新按下</span><span lang="EN-US"><font face="Times New Roman">CDPLAY</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">键,随着陈洁丽那美妙的声音从耳机流出,这个</span><span lang="EN-US"><font face="Times New Roman">ASS1.0</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">正式宣告制作成功。</span></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0;"><font size="4"><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">回顾制作这</span><span lang="EN-US"><font face="Times New Roman">ASS1.0</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">前级的三周时间里,感慨良多,一个不到</span><span lang="EN-US"><font face="Times New Roman">100</font></span><span style="FONT-FAMILY: 宋体; mso-ascii-font-family: &quot;Times New Roman&quot;; mso-hansi-font-family: &quot;Times New Roman&quot;;">个原件的小东东,居然让我花费如此多时间和精力,数次讨论修改</span><sp
