223 点
291 ¥
发表于 2011-8-2 23:23 | 显示全部楼层
“宀亻她”美国AuraBass Shaker低音频振动器(AST-2B-04 4欧姆50瓦)能让您在:车箱内、椅子、桌子、沙发、地板...等空间里,用不同于寻常的方式、迅速的从空气中立体的弥漫环绕在您全身、让您【翻天复地】...
以下为英文网站的描述---概述
Bass Shakers work on the concept that low bass is mostly felt and not heard.低音振动器工作低音主要是觉得并没有听说过的概念。 The Aura Pro Bass Shaker literally sends sonic vibrations through the material it is attached to allowing you to feel the earth-shaking bass from your music, movies or video game soundtracks.灵气临低音振动器字面上发送声波振动通过它连接到让你觉得从你的音乐,电影或视频游戏原声音乐翻天覆地的低音的材料。
Highlights 亮点
Pro version bass shaker handles 50 watts for higher visceral experience Pro版本的低音振动筛处理50瓦较高的内脏经验
More driving force than a standard shaker to bring your theater chairs to life!!超过一个标准瓶的动力,带来影院椅子生活!!
Feel earth shaking bass from your music videos and games like the pros感觉像专业人员一样从你的音乐视频和游戏的翻天覆地的低音
Add deep bass where space is limited like small vehicles添加深沉的低音,就像是小型车在空间有限
There's no distortion while enhancing the bass energy delivered from your stereo有没有失真,同时提高低音能量从你的立体声交付
Utilize conventional series parallel wiring configuration for larger surface areas利用较大的表面积常规系列平行布线配置
Part #:零件编号:  299-028 299-028   Weight:重量:  3.75 lbs. 3.75磅。
灵气AST - 2B - 4 Pro的低音振动器
The Aura AST-2B-04 Pro Bass Shaker also known as a butt shaker, butt kicker, or tactile transducer works on the concept that low bass is mostly felt and not heard.灵气AST - 2B - 04 Pro的低音振动器也一屁股摇床,对接起脚,或低音主要是觉得并没有听说过的概念上的触觉传感器工程。 Feel the earth-shaking bass from your music, movies or video game soundtracks.从你的音乐,电影或视频游戏原声音乐感受翻天覆地的低音。 The Aura Pro Bass Shaker was originally designed for automotive applications to produce big car subwoofer bass without taking up valuable space in the trunk of your car.灵气临低音振动器最初设计用于汽车应用的产生,而不占用宝贵的空间,在汽车行李箱大汽车低音炮低音。 The Aura Pro Bass Shaker is ideal for convertibles and sports cars, where installing a large car stereo subwoofer is not practical.灵气临低音振动器是理想的敞篷车和跑车,安装一个大型的汽车音响低音炮是不实际的的。 Can also be used in the home to make your own movie or video game chair.也可以在家里使用,使自己的电影或视频游戏椅。 The Aura Bass Shaker simply mounts to the floorboard under the seat or to the bottom of a chair to send vibrations through the structure allowing you to feel awesome bass.灵气低音振动器只需安装在座位下的地板或椅子底部通过发送让你感觉真棒低音结构的振动。 The Pro version bass shaker handles 50 watts of power and produces more driving force than a standard shaker.专业版低音摇床处理50瓦的功率,产生超过一个标准瓶的推动力。 Connects to an amplifier like an ordinary speaker.像一个普通的扬声器连接到放大器。 Use an array of Bass Shakers for larger surface areas like couches or love seats by utilizing conventional series parallel wiring configuration.使用较大的表面区域通过利用常规的一系列平行布线配置,如沙发或座位爱低音振荡器阵列。 Aura part number AST-2B-04.灵气的一部分AST - 2B - 04。 Sold and boxed individually and come 16 units per case.单独销售和盒装,并提出16%的情况下单位。
  Specifications: 产品规格:
• Power handling: 50 watts RMS/100 watts max •功率:50瓦最大RMS/100瓦
• Impedance: 4 ohms •阻抗:4欧姆
• Usable frequency response: 20 to 80 Hz •可用频率响应:20至80赫兹
• Fs: 40 Hz •FS:40赫兹
• Force peak: 30 lbs. •部队高峰:30磅。 per ft. 每英尺
• Dimensions: 6.2" dia. x 2.5" H •尺寸:直径x 2.5“6.2 H
Want to feel your music? 想感受一下你的音乐吗 ? The Bass Shaker Pro products allow you to experience every thump, thrust and shake...the way bass sound was originally intended. 低音振动器Pro产品让您体验到每一个扑通,推力和动摇... ...原本打算方式的低音 。 Aura's patented technology preserves the sound pressure levels so there's no distortion while enhancing the bass energy delivered from your stereo. 灵气的专利技术,保留的声压水平,所以没有失真,同时提高低音能量从你的立体声交付。 We're taking surround sound to another level..... 我们到另一个层次的环绕声.....
Bass Shakers from Aura Systems add the exciting dimension of feeling to the sights and sounds of video arcade games, movies, stage shows and multimedia attractions! 从光环系统中的低音振动器添加视频街机游戏,电影,舞台表演和多媒体景点景点和声音的感觉令人兴奋的层面! By actively converting bass sound waves into spine-ringling vibrations, Bass Shakers turn entertainment into a "moving experience"! 通过积极低音声波转换成脊柱林林振动,低音振动器变成一个“感人的经历,”娱乐的 !
Bass Shakers bring coin-operated video arcade games to life by transforming a game's audio output into body-pulsing vibrations. 低音振动器带来的投币式视频街机游戏的生活,改变一场比赛的成体脉冲振动的音频输出。 With Bass Shakers installed into arcade seats or floor platforms, players can feel everything froma fighter's punch to the roaring engine of a formula one race car. 低音振动器安装到商场座椅或地板平台,玩家可以感受到一切froma战斗机的一拳的一级方程式赛车的轰鸣的发动机。
In movie theaters, the action jumps off the screen, the soundtrack comes to life and the entire experience is intensified. 在电影院,动作跳跃关闭屏幕,配乐来生活和整个体验是加剧。 Bass Shakers hook up like a speaker and easily mount directly to a standard theater seat. 低音振动器连接起来像一个扬声器,并轻松地直接安装到标准的影院座位。
Installed in seats, tables, booths, floors of showrooms and stage theaters, Bass Shakers provide audiences with a more complete entertainment experience. 座椅,桌子,亭,陈列室和舞台剧院的地板安装,低音振动器提供更完整的娱乐体验的观众。 Las Vegas stage extravaganzas, hit Broadway musicals, and rockin' concerts virtually jump off the stage into the audience. 拉斯维加斯的阶段extravaganzas,打了百老汇音乐剧,和摇滚音乐会几乎跳下观众的舞台。 Bass Shakers are ideal for bringing music, on-stage special effects and laser shows to life. 低音振动器带来的音乐,舞台上的特殊效果和激光表演,生活的理想 。
Bass Shakers turn up the revenue potential of any entertainment experience. 低音振动器任何娱乐体验的收入潜力 。 And thanks to low purchase, installation and maintenance costs, the Bass Shaker is a virtual winner in the race to provide affordable upgrades and enhancements to existing facilities. 得益于较低的采购,安装和维护成本,低音振动器是一个在比赛中,以提供负担得起的升级和增强现有设施的虚拟的获胜者。
559 点
548 ¥
发表于 2011-8-3 10:56 | 显示全部楼层
好玩的东西....
982 点
942 ¥
发表于 2011-8-3 13:05 | 显示全部楼层
这个一样的仓库也有几个,一直没试用过,不知效果如何 !
745 点
730 ¥
发表于 2011-8-3 13:23 | 显示全部楼层
有沒DX試過的給個評價啊?
7 点
7 ¥
发表于 2011-8-3 17:27 | 显示全部楼层
这个东东价格贵吗?
63
263 点
242 ¥
发表于 2011-8-4 00:47 | 显示全部楼层
这东西原理是贴在车的铁上的  利用车体产生共振的吧  只是知道大概原理 其他不详
18 点
16 ¥
发表于 2011-8-4 01:13 | 显示全部楼层
是否用了它就不需要低音炮了?是用软件翻译的吗?好怪...
223 点
291 ¥
 楼主| 发表于 2011-8-6 12:51 | 显示全部楼层
是直接从英文网站用网络翻译过来的...
没办法、个人英文水平有限.
菜鸟
57 点
62 ¥
发表于 2011-8-6 15:07 | 显示全部楼层
这个东东;价格贵不??
766 点
766 ¥
早期买了两个。。一直没有使用。。现在都不知道放哪里去了。。。
223 点
291 ¥
 楼主| 发表于 2011-8-6 16:20 | 显示全部楼层
回复 9# 中音
不贵,这东东能用到很多地方、只要您想给音响增强动感、就能用到“她”.......
223 点
291 ¥
 楼主| 发表于 2011-8-9 19:40 | 显示全部楼层
回复 11# 中国人!
用螺丝固定在车座下...
贫僧
797 点
793 ¥
发表于 2011-8-12 15:50 | 显示全部楼层
跟一种振动耳机里面的低音振动器着不多吧,听流行歌还可以,随低频出现震得耳朵很舒服。缺点是收不住尾,以致低频有点混不清晰。可能控制力强的功放会有改善吧。
13 点
13 ¥
发表于 2012-8-18 20:47 | 显示全部楼层
这个只有震动没有声音的
324 点
322 ¥
发表于 2012-8-18 21:27 | 显示全部楼层
用身体“听”声音吧..
223 点
291 ¥
 楼主| 发表于 2013-6-26 14:34 | 显示全部楼层
云之南 发表于 2012-8-18 21:27
用身体“听”声音吧..
动感影院的特效座椅效果就是这样的、同步影片音响的低频效果产生特效,在4D、5D影院里有这配置...
423 点
236 ¥
发表于 2013-6-26 21:37 | 显示全部楼层
人家还专门做减震,这个专门弄个震动,等下震震车子散架了,或掉个什么零件出来!
42 点
40 ¥
发表于 2013-7-20 07:16 | 显示全部楼层
不知道效果怎么样
禁言警告级 当前离线
Rank: 1
-20 点
40 ¥
发表于 2013-7-20 15:03 | 显示全部楼层
好玩啊
223 点
291 ¥
 楼主| 发表于 2013-9-17 10:16 | 显示全部楼层
qqxab 发表于 2013-7-20 15:03
好玩啊
好玩,要不也不会有人喜欢去4D影院体验了!
这就是4D影院特效动感座椅下面安装的、同步音响低频曲线值产生振动的“低频振动器”
