- 917
- 2320 小时
- 2025-6-20
- 50
- 36586
- 1519
- 917 点
- 879 ¥
- 2008-3-3
回复 4# sdteddy
哥们,你知道你这个车机的那个Telechips TCC8801 CPU有多么强大吗??难怪空焊了那么多零件!功能一半都没有用上
其实这玩艺不错,可以用来做 IPCamera,
H264 1080p 30fps 编码哟
Core / Technology
○ ARM Cortex-A8
○ CPU 800MHz @1.2v, up to 1GHz
○ L1 : 32KB/32KB, L2 : 256KB
○ 80KB SRAM
○ NEON signal processing extensions for media codecs acceleration
○ 45nm CMOS Process
Package
○ TCC8801 : 19x19mm2, 557Ball, FCBGA,0.65pitch
○ TCC8803 : 17x17mm2, 473Ball, FCBGA,0.65pitch
Video Processor (up to 1920x1080p 30fps)
○ H.264 BP/MP/HP @Level 5.0
○ MPEG-2 MP @ HL
○ MPEG-4 SP/ASP @ Level 5.1
○ DivX 3.x/4.x/5.x/6.x
○ H.263 profile3 @ Level 70
○ Sorenson Spark
○ VC-1 SP/MP/AP @ Level 3.0
○ Real Video 8,9,10 - Licensee only
○ AVS Jizhun @ Level 6.2
Video Encoding (up to 1920x1080p 30fps)
○ H.263 Profile 3 @ Level 70
○ H.264 BP @ Level 3.0
○ MPEG-4 SP @ Level 5.0
MJPEG/JPEG
○ Up to 32M pixel/s
○ Decoding : Max 8192 x 8192
○ Encoding : Max 4096 x 4096
Video Enhancement
○ Histogram Measurement
○ Contrast Enhancement
○ De-interlacer
○ Noise Reduction
○ Sharpness
Graphic Processor
○ Overlay Mixer
○ 3D / 2D Graphic Processor . Full OpenGL ES 1.1 / 2.0, Open VG 1.1 . 20M Polygon / 300M Fill Rate @ 300MHz Host Interfaces
○ EHI (External Host Interface) . 8, 16, 18bits . 2Ch
Camera Interface
○ Parallel I/F (8/10/12bit) -1Ch
○ MIPI CSI 4-Iane (TCC8801 only)
○ ITU-R BT601, ITU-R BT656
○ 12M pixel ISP
Display & Video Output
○ 2 Display controllers . Controller 0 - 3 Overlay channel . Controller 1 - 3 Overlay channel . Progressive or interlaced Digital
Video Output
○ LVDS (TCC8801 only)
○ MIPI DSI (TCC8801 only)
○ HDMI 1.3 (w/ D-PHY)
○ Composite TV-Out (NTSC/PAL)(TCC8801 only)
Audio Interfaces
○ I2S Master & Slave (up to 7.1Ch)
○ SPDIF Transmitter / Receiver (up to 5.1Ch)
○ CD I/F (I2S Slave)
Streaming Interface
○ Serial TS-2Ch
○ Parallel TS-2Ch
Memory Support
○ LP-DDR/LP-DDR2, DDR2/DDR3
Storage I/F Support
○ NAND Flash . SLC . MLC (4/6/12/16/24bit ECC)
○ SATA (TCC8801 only)
Cipher Engine
○ AES / DES / 3DES / Multi-2 / CSA
Peripherals & Other Features
○ USB 2.0 HS OTG - 1Ch
○ USB 2.0 HS Host - 1Ch
○ USB 1.1 FS Host - 1Ch (TCC8801 only)
○ UART - 6Ch
○ I2C - 4Ch
○ GPSB (SPI) - 6Ch
○ DMA - 12Ch
○ SDIO - 4Ch
○ 12-bit ADC - 16Ch
○ TSC (Resistive Touch Screen Controller)
○ RTC : Power Down Mode & Auto-Wakeup
○ Ethernet MAC - 1Ch (Host/Device)(TCC8801 only)
○ PCI Express - 1Ch (TCC8801 only)
Special Hardware
○ MPE-FEC
○ H/W TS Demux
Software
○ OS : Linux / Android, Win CE
○ Audio Format support . MP3 / OGG / PCM / ADPCM . WMA / WMA Lossless / WMA Pro . MPEG-1 / 2 Layers I and II . AAC / EAAC + / FLAC . DTS/ AC-3 - Licensee only
○ Bluetooth Stack / Profile
○ WiFi / Ethernet
○ Broadcasting : Mobile TV, Digital TV.
IP Streaming (IPTV)
○ NTFS
Target Application
○ MID
○ PMP / PND
○ IPTV / Set-top box
○ Home Media Player
○ AVN |
