- 439
- 334 小时
- 2023-3-20
- 50
- 340211
- 214
- 439 点
- 227 ¥
- 2011-5-25
楼主 |
发表于 2011-7-11 11:46
显示全部楼层
测试了那个佳讯QA-5100,发现其Q参数很杯具,下面是REW导出的参数文件内容:
TS Parameters file
Room EQ V5.01
Dated: 2011-7-10 15:01:07
From measurement Kasun-自由状态11.5cm
Zmin 5.69 ohm
fmin 277 Hz
f3 2049 Hz
Le(f3) 0.295 mH
Motional impedance parameters
RES 19.05 ohm
LCES 4.337 mH
CMES 601.8 uF
RAMS 19049.110 mohm
Blocked impedance parameters
RDC 5.00 ohm
dR 0.48 ohm
Re 5.48 ohm
Leb 24.3 uH
Le 0.579 mH
Rss 149.5 ohm
Ke 0.0677 S-H
Thiele-Small parameters
fs 98.4 Hz
Qms 5.162
Qes 2.040
Qts 1.462
Fts 67.3
Mms 9.00 g
Cms 0.291 mm/N
Rms 1.077 kg/s
Vas 4.45 litres
Bl 3.867 Tm
Eta 0.20 %
Lp (1W/1m) 85.03 dB
Dd 11.50 cm
Sd 103.9 cm^2
Added mass 10.64 g
Secondary measurement: Kasun-配重10.64
Air temperature 27.0 C
Air pressure 1013.25 mB
Air density 1.1760 kg/m^3
Speed of sound 347.3 m/s |
